nadler
Members-
Posts
124 -
Joined
Last visited
Everything posted by nadler
Matter 1.3 has been released. Google seems to be all in now with matter with an open API for smart devices just announced. When will matter come to EISY? We've heard "soon" for a while now. I know I am iimpatient, but without a clearer definition of "soon" I might have to move on, and that's not what I want. Hopefully @Michel Kohanim will surprise us. Regards, Noel
- 1 reply
- 1
Yes, None of my overnight programs ran last night. All the programs that were enabled yesterday were not enabled today. I changed nothing! Quite annoying.
Thanks @Michel Kohanim. It's good to know that Matter is a top priority at UDI. Regards, Noel
Here's the back story. You can skip it if you want and go to paragraph 4. I've been spending a lot of time with ZWave and eisy trying to do things with Zwave that Insteon could do with little problem. The zwave devices from ZOOZ have been a bit of a challenge and I was waiting for firmware updates for fix some of the issues I've had. In order to do OTA firmware update on ZooZ sensors and devices I've had to remove the devices from IoX and add them back. When they're added back they get a new ZY number and all programs which reference the device have to be changed. It's only when the old zwave devices are added back with a new device number that the OTA update option appears in the IoX device menu.. The actual updating of the firmware for each device using eisy takes a least 30 minutes. So it can take many hours to update even a moderate zwave installation. It then takes many more hours to update the related programs and test them. Well, I've done that, but just to give one example, the firmware update to Zooz Zen72 dimmer made the dimmer worse in the dimming department. For some reason the brightness cannot to be dimmed past 40%(subjective - could be a lower). Although I am dimming the device to 1% the lower brightness is still very bright and significantly brighter that it was with the original firmware version (Version 1.0 and 1.1 vs version 1.4). When I contacted Zooz about this, they basically said that's the way it has to be. I postulate that they changed it to stop the buzzing or flickering from some bulbs at the lower dim level. I tried this on numerous ZEN 72 dimmers and numerous bulbs in different locations. Because for my applications I need lower dim level I decided to try other dimmers and I came across the Leviton decora smart dimmer 2nd generation (D26HD) (wifi) which has a early access beta download for matter. I just installed it and it easily dims to 1%. BTY the wifi firmware update for the Leviton took about a minute. I have a new Samsung TV with a Smarthings Hub built in which is matter enabled as well. It was a simple task to get the TV to find the matter dimmer. It also asked if I wanted Alexa to control the dimmer. It hooked that up as well, WITHOUT having to ask Alexa to discover devices. It worked instantly and automatically. The downside is that athough you can do some schedules and routines with this dimmer using Smartthings or Alexa it does not enable the type of sophisticated programming that we could always do with ISY, Polisy and EISY. For example, it doesn't do double tap of the on or off switch (it does have a limited form of double tap but not what I need). Right now, in addition to eisy and UDImobile for zwave devices and smartthings for matter. I am using the August app for locks (since the August node server doesn't work for me), the powerview for my Hunter Douglas shades, ring app for my doorbell, nest app for my camera, ev juicenet app for my ev car charger, alladdin connect app for my garage door opener, total connect app for home security. Of those I use the Total Connect node server and also Ecobee node server both of which work well. Previously, I had insteon thermostats, insteon lights, insteon water leak sensors, insteon garage door, insteon automatic water shut off valve, etc. All worked well for many years with minimal time spent troubleshooting. So that leads me to my question.... What is the ETA for Matter on the Zmatter board? I think that will help me in my quest to be able to control most devices from one application and have a level of programming sophistication and ease of use I had for some many years with ISY. I know there are some detractors who say that Matter will never be what is promised, so far, for me at least, it has that potential and I would like it to be a part of EISY sooner rather than later.
I recently upgraded from Polisy to eisy and I'm have difficult getting August NS to work. It worked fine on Polisy. I have uninstalled it and reinstalled it many times in various orders. Now, after many attempts I'm receiving the emailed August authenication code . When sending the validation code through IoX I'm receiving an Invalid Authorization code in the log. I've probably made a simple error but I can't find it. Any help to avert my continuing frustration would be appreciated. Here is some info: IoX version 5.7, PG3xversion 3.2.4 By the way the tokenFilePath is a little different for PG3x version: I think it should be like this: /var/polyglot/pg3x/ns/0021b9026739_19 (unless that's my mistake, but without the /pg3x/ I get an invalid file path error) After I restart the node disappears. Here is the log: August_9-19-2023_123751_PM.zip
Setting the parameters by adding Custom Parameters eventually worked. I had to reboot policy a number of times, watch for emails, install and uninstall the node server several times but eventually it worked. Thanks @DennisC and @dpwwer.
Thanks Bob
I just installed a gen 4 August wifi lock and am trying to get the August nodeserver to work with it. ver 3.1.1, Polisy 5.52, Polyglot 3.1.10. I get the controller in PG3 (1 node) but there is no place to input the parameters indicated in the instructions (email, password, install_id, tokenFilePath). I attached a log file. In the admin console in IoX I do get the controller and an August Lock node to add but since I don't have node address I am not able to add it. Any help appreciated. August_3-21-2023_122222_PM.zip
Zooz battery devices don't regularly report battery level
nadler replied to Steve L's topic in Z-Wave - Series 300/500
I also have this issue with Zooz ZSE42. They also seem to go through batteries quickly. I much preferred the Insteon leak sensors but alas I didn't setup insteon in my new condo. I'll check out YoLink. I also have an aerotec which seems much better but it's also more than double the price. It has heat and humidity as well as a leak sensor. -
This is pretty straight forward and you're half way there. Edit your master bedroom group. You'll get a drop down list with all your lights (for example). Under that list is another list with all your echo devices. Check the echo device in the master bedroom and save. That's it. When you're in the bedroom say Alexa lights on our something similar. That's it. Do the same for the garage. Note: each echo can only be attached to one group in this manner.
I too installed the zmatter board. I have the zooz stick and all is working. The tip about installing the antenna leads before installing the boards saved some time, so thanks to all who mentioned it. I had to login to PG3 from the administrative console and restart ecobee and total connect node servers and both are working. I didn't have to restart the holiday node server. Can't wait until tomorrow!
Try this or some variation thereof. ${sys.node.ZW014_118.CLITEMP} Humidity: ${sys.node.ZW014_118.CLIHUM}
I just installed my 5th zooz ZSE42 ver 1.0 firmware 1.4 Here are the nodes that come up in IoP. Basic Control 2 Notify Sensor Water Alarm 1 Water Detected 1 Leak Detected Alarm When water is detected When water is detected Basic Control reports 255 (from 0) Water Alarm 1 blank Water Detected 1 ON Leak Detected Alarm On Notify Sensor 100% (battery)
Just wanted to share this in case others are looking for similar information. I wanted to email to myself a daily status reports of the nodes on my honeywell Pro alarm. The node server works great and wanted the zone status information for email purposes. I was able to get the values from each device using the variable such that 1 = OK and 3 = faulted. Here is the result: SECURITY STATUS: (1=Closed 3 = OPEN)Kensington - Front Door 1 Kensington - Rear Door 1Kensington - Front Motion Se 1Kensington - Basement Motion 1Kensington - Garage Door 1Kensington - Master Bedroom R 1Kensington - Master Bedroom M 3Kensington - Master Bedroom L 1 Here are the variables: SECURITY STATUS: (1=Closed 3 = OPEN) ${sys.node.n007_z_XXXXXX_1.NAME} ${sys.node.n007_z_XXXXX_1.GV0} ${sys.node.n007_z_XXXXXX_2.NAME} ${sys.node.n007_z_XXXXX_2.GV0} ${sys.node.n007_z_XXXXXX_3.NAME} ${sys.node.n007_z_XXXXX_3.GV0} ${sys.node.n007_z_XXXXXX_4.NAME} ${sys.node.n007_z_XXXXXX_4.GV0} ${sys.node.n007_z_XXXXXX_5.NAME} ${sys.node.n007_z_XXXXX_5.GV0} ${sys.node.n007_z_XXXXXX_6.NAME} ${sys.node.n007_z_XXXXX_6.GV0} ${sys.node.n007_z XXXXXX_7.NAME} ${sys.node.n007_z_XXXXX_7.GV0} ${sys.node.n007_z_XXXXXX_8.NAME} ${sys.node.n007_z_XXXXXX_8.GV0} (Change the XXXXX as appropriate) There may be other ways of doing this but this worked for me.
- 1
Thanks. Just a note to say that the event viewer indicates unrecognized zwave firmware. This makes sense considering you didn't test yet with the newest version. Everything works in zwave even with this message.
UPDATE: After turning off Polisy I switched the ZOOZ stick and the USBPLM ports in the Polisy. I also cleared the java cache. Now the sticks and devices work again in Polisy. I don't know which did the trick but I'm now good to go. @Michel Kohanim After zooz stick update to 7.17 reinserting the stick when polisy was off, that I am also getting the "Z-wave dongle not responding" error. I have a USB PLM installed. I unchecked the Insteon box in configuration, rebooted and still have the same error.
@mmb Here is the response from ZOOZ: Hi Noel, Thank you for sharing the screenshot. We haven't seen that error before, but after doing some research, other users have suggested it means that the Z-Wave device being updated does not contain signing and encryption keys - however, our technicians were able to update the firmware just fine, and to the best of my knowledge, did not need to perform any additional steps with 'signing and encryption keys'. So we're not sure what would be needed to resolve the issue here. We would recommend reaching out to Silicon Labs support for additional input since they've provided the firmware and maintain the PC Controller software. They may be better able to assist here. Looking forward to hearing back from you. Maggie ZooZ is certainly responsive. I would say their customer service is almost as good as UDIs!
I'm going to send you message to zooz and see if they have anything to say about it.
Attached is the updated file for the stick. ZW_SerialAPI_Controller_7_17_1_344_ZGM130S_REGION_US.gbl
I have 3 Bali honeycomb shades that I purchased from Costco. You are actually buying from Bali directly. Costco is the middleman. They came quickly and work well. I use(d) smartthings for zwave at the time and although the pairing took a while, everything worked perfectly from day one. I use Alexa and Google Home to control them along with the remote. When I move to a condo in a month I'm planning on purchasing Bali and using polisy and zwave. Costco regularly has 15% off items from Bali.
I thought this might help others. From Zooz support: The process for updating the ZST10 700 will be the same as the one described in this article, however at the main screen you'll need to pick OTW instead of OTA: https://www.support.getzooz.com/kb/article/253-how-to-perform-an-ota-firmware-update-on-zooz-devices/Attached is the firmware that should help resolve the issue of the devices dropping offline.You may need to try to have Simplicity Studio install the Z-Wave PC Controller by choosing "Manage installed packages" instead of "Install by technology type".Please give the update a try and let us know if you have any questions about the process. Note: I haven't tried this yet. I will try to attach the firmware to this message when I receive it from ZOOZ
@larryllix Here's the part about the PC Controller. It was in the quick guide for the stick at SLlabs. I think OTW might be in the software, but I haven't downloaded it yet. I also don't know what OTW means (over the WAN?) Link to silabs quick documentation
@io_guy Thanks for the advice. I think I will get the SLUSB stick and experiment on that. That way I have a backup to play with.
Wow, from reading the thread it seems there are quite a lot of problems, many above my understanding at this point. Does the SLUSB001A not have these problems or is it easier to update? They seem to be in stock and for $20 seems worth it to avoid the hassle. Or is it the same hassle and just a better stick?
