bernieb
Everything posted by bernieb
  1. bernieb replied to Ajax's topic in ISY994
    Please keep us posted, I did get an email about being a tester as well, but passed on it since I can't program to save my life. I just didn't want to waste their time. Will be curious to see how to integrate it with ISY
  2. Well, seems like I have a lot of reading to do ... haven't had a chance to catch up. I will most likely try to upgrade first, then work on getting a little more from my battery with some of the suggestions that you mentioned above ( will read a little later) I'll then give it a good shot testing with OpenHAB and see where this leads me. I may need a little help on the configuration. Quick question for out (out of left field) ... have you ever taken a look at Home Assistant? https://home-assistant.io It's been discussed on this board and actually has a component that hooks to the ISY. I had seen it before, but someone from the OpenHAB community sent me to take a look in regards to a wifi module for my new Roomba vacuum cleaner. Seems like Python is popular with this system. So I'll be building a Pi3 next weekend and will run it in conjunction with ISY and OpenHAB. They both have their pluses and minuses ... but more than likely I will choose between the 2 to complement the ISY.
  3. I have to say that this works very well, I was able to successfully, without any issues my location and home presence. But am I the only one that sees severe battery draining issues? I've tested this for several days. When the script is running, not only my phone but my Apple watch drains way before the end of day. My phone dies mid afternoon and my watch goes into low power consumption mode around 6PM. I left it running for a couple of days and same issue. I stop the script and everyhting goes back to normal and get a full day of use from both my phone and my watch. I decided to repeat the process again and be mindful of using my phone ... and then I see the same battery issue. Stopped the script a couple of days ago and back to normal. It may just be me.
  4. Thanks to your helpful posts and patience, seems like I have your script working perfectly and starts automatically with supervisor. I've also tweaked my GPS location and changed the multiplier to 1000. I also think that I will try tripling my geofence radius to 900 ft. Your comments made a lot of sense and I should just give it a shot to see if I like it. What I haven'd done so far: - Create a geofence variable (for testing) in the the ISY and test the home away. I can later move it to the one that I am currently using. - I also need to read through this thread to get the entire concept so that I can use this at it's fullest. Such as WiFi etc. Questions for you: - Are you planning that at some point and time you will add the functionality of multiple devices that can be tracked? - Also I am assuming that the database my start getting to be pretty sizable after a while. Will there be an automatic method to purge information from it? Looking forward to the new version and testing with OpenHAB as well. For now I am still using OpenHAB 1 (ver. 1.8.3) I am hoping that your method will work as well in version 1 as it does in ver. 2 Also wanted to point out the misspelling in step 4 of your Github readme file ... it shows: pip install -r requrements.txt As you can see requirements needs to be corrected so that other copy/paste wizards like me don't get stumped. Awesome work Steven .... Thanks
  5. Thanks Steven, Happy to see that I am well on my way, this will be great. Currently I am running version 4.5.0 on the ISY, not planning to move to 5.0 until it's pretty stable. Can you dumb it down a bit for the programs that assist with autostart? Remember ... newbie here Also currently I am using the geofence in Mobilinc to trigger events. I really like that it has a 300 ft radius to the house. It's never failed for me to trigger precisely at the same place every time. Didn't work so well for my wife, that's why I am looking at a different solution. And this could satisfy both my ISY and OpenHAB. Is there a way to be able to accomplish the same thing with your script? Right now, if I am in the geofence, I have a variable that changes to "1", if I leave, it goes to "0" and I can build my logic around that. Can you give me examples on how you are triggering events on change?
  6. well, I was able to make my way through the install ... I think. I am seeing results on the pi with a distance of 0.108813 .... But my ISY still shows "0" for my distance ... this may be normal, not exactly sure if it should show the decimals or not. Also, how would you recommend to start this script automatically at startup? Thanks
  7. Thanks for the explanation Steven, I wasn't really pointing a finger and I hope that you didn't take it personally. You are right, I don't know you, but I am usually the guy that think that everyone are "nice guys" and most just plainly want to help out. Take it from someone that's really not a coder and have no clue of what any of this does. After I posted, I thought that it would have been best for me if I would have read up a little bit on iCloud API. Haven't had the chance, but I may. In any case, I don't think now, after your explanation, that this will stop me from installing your script. I also have to be honest with you that I also don't know if my raspberry pi can be accessed from the web. On this "pi" I have an install of OpenHab and although i can only access it internally at this time, i plan to subscribe to my.openhab in order to get access from remote location with my mobile app. I think that I prefer using this method than punching a hole in my firewall. I also have installed a version of "nginx" as a light weight web server. I was trying to play around with a python script that would allow remote start of my car, but I haven't been successful at all with it. Too bad as I had all sorts of ideas on how to trigger remote start of my car for the upcoming winter months. Anyway, I may have created some sort of access from the web ... not sure. I am a bit puzzled of my my configuration file was empty ... now I know that I could copy the content from yours in mine and I should be all set, but this puts doubt in my mind that I may have done something weird and other files may be empty as well. In any case, I plan to continue working on this this evening ... I'll keep you posted. I honestly appreciate all your work and talent on this nice utility. Hope you forgive me from being a little paranoid, and my apologies if I offended you.
  8. Hi Steve, Started last night installing you proximity script. I'm about half way. most work correctly but did have a bump or two. First I got an error message trying to run pip install -r requrements.txt I've notice the misspelling, but different variations did not work, (also used sudo) no luck. I was, however able to install Click. Then copied my iphonelocation.ini and when I opened it, it was blank, so was the source file iphonelocation.ini.sample. I found it strange as your file on github has all the info in it. But the bigger issue I see, and that's for me to sort out, but in the .ini file, I see that we need to supply our credentials to iCloud (username, password). This is in plain text and having access to iCloud gives access to my Apple account, credit card number etc. If I recall, you had stated in a previous post that your script "called home" for some reason, maybe just to see the different location of users of this script. But I have to say that I have some security concerns. Please don't take this personally, but also being a newbie with a Raspberry PI, I may very well not have all the security in place. someone gets in my network and now have my Apple account information. Can you share your thought on this please? Thanks
  9. Hi Steve, I haven't forgot about this one either, I have been a little bit busy these past few weekends helping a family member in need, so not a whole lot of time playing with toys. I will however do my best to try and implement the ISY side this coming weekend. I'll surely keep you posted. Also interested in knowing how you passed information from the ISY to Openhab. One thing missing in Openhab is the "Light" value from the Weather module. All of the free services does not offer this information. I would love to pass this info from the ISY to a variable in Openhab somehow.
  10. bernieb replied to Paulk8's topic in Amazon Echo
    Stu, can you explain how this works? I thought that I needed one account for each unit?
  11. Hi Steve, Just rebuilt my instance of OpenHab on a new Raspberry Pi 3, so I wanted to see if I can get this started, I have to say that I only skimmed part of this thread and did have a few questions. Can this allow to follow more than one device? Can it track my phone and my wife's phone as well? Also I did see your pre-requisites, but does this need an Apache server as well? I may be the one that would need a "for dummies" step by step install instructions unless I can refer to standard install of these dependencies on RPi. I did look at the config file and saw that there is only 1 port to setup. My ISY does not run on the standard port 80 and even my https port is not standard as well, can your script accommodate non-standard ports for both http and https? On my OpenHab, these are not standard either, it runs on port 8080 for http. Also curious about your script that runs on your router. I have an Asus as well and wouldn't have an issue installing a new firmware if I can get some benefits from that as well. One of the things that I am looking for is a way to see if some devices are connected to the router (via MAC address i assume) One of my goals is to be able to let my ISY (Openhab) know if I am working from home. Detecting the MAC address of my work laptop and updating a variable would work fine. Any ideas if this could be accomplished with such a script? Thanks Bernie
  12. bernieb replied to Paulk8's topic in Amazon Echo
    Thanks Stu ... at this point this is a deal breaker for me, I just don't want to have 6 Amazon accounts just to manage these Dots. I am sure that in the future, they'll have a way around this.
  13. bernieb replied to Paulk8's topic in Amazon Echo
    I am wondering the same, can all these Dots used the same account as my Echo? I haven't seen anything yet that states that it would or would not. I am just waiting on confirmation before I pull the trigger on some. Anyone knows?
  14. Hi Steve, Thanks for the quick reply. I am not much of a programmer, but from reading your original description, my thought were exactly the same, it shouldn't be too hard to attempt this to support another home automation platform. Being able to support both the ISY and something else, (in this case OpenHab) would be great. this way it would be consistent across the board. Let me look at the requirements and dependencies of your package and see if I can't get that running in the between now and next weekend. This way it will give me a baseline. I am still very green with Openhab, just beep playing with it for the last 10 days or so and already had to start from scratch 3 times, but I am getting there. They do have several APIs and binding that can be used, not sure what would be the best, but here's a few references that may give you a better idea. I would think that you'd want to keep it as close to the same method used to update the ISY JSON https://github.com/openhab/openhab/wiki/JSON-Transformations REST API https://github.com/openhab/openhab/wiki/REST-API HTTP Binding https://github.com/openhab/openhab/wiki/Http-Binding The right had column of this wiki may give you other ideas/methods to explore as well. I love my ISY and plan to stick with it for my "mission critical" items. Lighting, heating and security. But the other fun stuff, like Hue, Kodi, outdoor landscaping lighting, RFXCOM drape and shades automation, I'd like to explore OpenHAB. Maybe in the future Polyglot will offer all of these services, but for now it's fun to learn another platform.
  15. This looks like a really good way to do geo location. I may very well try this in the near future. Question though: How hard would it be to modify the script to use with another home automation software. I am gearing up to run OpenHab in conjunction with my ISY to supplement a few less important processes. I would be nice to have a similar way to track presence on both platforms, even share an RPi for the task.
  16. bernieb replied to Ajax's topic in ISY994
    I'm in for 5 of them ... curious to see what I can do with them.
  17. I personally like that it reverts back to white. My wife could care less for Home Automation, so when she flips the switch, she wants to see something, that wouldn't work well if it would remember the last scene as sometimes I have a dim multicolored scheme. It's up to me to control my lights and change scenes without disturbing her ability to get light.
  18. Hi DualBandAid, Yes, your changes to the instructions in regards to the debug screen for the URL to reflect "/api" is correct. This was the only way that I could make it work. In addition, I really got caught up with the expression to call up a scene from your instructions. You state putting in the following in the body: {"on": true, "scene": “YOUR-SCENE-NAME”} For me, this didn't work and kept giving me errors, not even triggering a scene. I ended up searching the web and someone stated the the "on" statement is not required when calling scenes. So my only expression in the body to call a scene is: {"scene": “YOUR-SCENE-NAME”} and that works perfectly. Just wanted to bring this up in case others had issue. Except for that .. your tutorial in invaluable. I had tried before without any success, now it works perfectly. Thanks for your efforts
  19. starmanj .... I had the same issue and it took me a little while to find the solution. When you use the debug page, take a look at the URL. Mine originally, by default, showed "/api/1234" Just make sure that the URL only contains: "/api" Press the hub button and get your results.
  20. I was reading the enhancements of version 4.5.2 Can someone explain to me what this feature is all about? wouldn't it check for the presence of a certain device (almost like a ping) Enhancements: [OADR] - /rest/oadr/status - retrieve network connection/online status If not, can anyone give ideas of usage of this OADR?
  21. bernieb replied to Bekowies's topic in ISY994
    I can also speak on this topic. I also was an HS user since Ver. 1 and went up to the upgrades up to Ver. 3. I think that Ver.1 was the best out there at the time and was a breakthrough with home automation software. It served me well for a good amount of time, but towards the end, I felt like lack of communication from the developer and and lack of a rod map made me loose a lot of interest. Software bugs were not addressed in a timely manner, and one thing fixed, broke something else. Personally, I also felt that the developer was getting a little over their head with the new technology, both software and hardware. But more to the topic at hand. For me, several times, due to the fact that the application sat on top of a workstation running MS Windows, I had to rebuild this dedicated box several times and some of these times came at the most importunate time. Twice I had to rebuild a few days before heading out for vacation, time that you need it the most. I also had relied on 3rd party plugins that became unsupported, outdated and broken for various reasons. Lastly, the newer version excluded the support of hardware that I had invested in and was previously supported by the vendor. This lead me to research an alternative and this is where I landed. I am pretty satisfied with my choice. No underlying OS, updates are made frequently and well communicated and the company also has the same belief that this technology should reside within your network and not farmed out to "the cloud". From what I am reading in your original post, most of your request is to build IF - THEN - ELSE events. The ISY handles this beautifully and keep in mind that HS does not provide this feature easily (that I know of, things may have changed). But lastly, for me, the mobile interface for HS was getting to be a pain, every time that I wanted to add a light switch, I had to redesign a good portion of my mobile app and then have to collect all of my devices to publish the new design. I am currently using Mobilinc and even if I am not a fan of the design, the applicaiton works really well on iOS. I am not pushing one way or the other, as I think that both projects are great, just hat for me, ISY is the way to go.
  22. bernieb replied to Jason Miller's topic in ISY994
    Had to send the other one back ... but nevertheless, pretty decent customer support.
  23. In my bachelor days, I had another home automation system that would read the weather, say what happened on this day in history, would notify me of friends and relatives' birthday seven days in advance so that i would have time to buy greeting cards, etc etc, I also had an event that would chime in at anytime with the CNN Breaking News .... well .... my girlfriend, who is now my wife ... did not care much for "another" female voice in the house. I am looking to do something similar now, but will try to base the announcements on who is present at home
  24. bernieb replied to Jason Miller's topic in ISY994
    I purchased a Ring doorbell just before Xmas this year and installed it right away. It worked perfectly (and still is) last week, I noticed that the doorbell button cover (a small piece the size of a nickle) had fallen off. I contacted their support desk and inquired if I could purchase a replacement for it, so that I could glue it back in place. I had a reply within an hour asking me for my address stating that they would replace my entire doorbell free of charge and provide a post paid envelope to return my existing doorbell. I received the unit 2 days later and also had 2 follow up emails to make sure that I was satisfied with the resolution. So overall, I am very happy with the new company and their response from customer service. I also love the unit, no issues with functionality.
  25. Thanks for posting this, I have a Ring doorbell installed and I am sure that I can put this to good use. One thing that comes to mind, is that I like the motion notification, but it alerts me whether I am away or home. I wanted to find a way to stop the notifications when I am home and only keep them when I am away. So now I can turn off notifications for my phone, I have a variable that knows when I am home, so I can write logic to send me a pushover notification only is I am away. So again, thank you for posting your steps here, much appreciated.
