xgfreon
  1. xgfreon replied to xgfreon's topic in VenstarCT
    Finally got the SD card from Venstar and got all the 7900's up to date. All is well.
  2. xgfreon replied to xgfreon's topic in VenstarCT
    yea they are shipping me one as well.....guess we will see if the magic card works
  3. xgfreon replied to xgfreon's topic in VenstarCT
    As luck would have it, neither of my 7900's will recognize any sd card. My 2 5800's recognize and read/write to the sdcard just fine. I guess i'll have to contact venstar and see if they have any ideas. do any of you happen to have the older colortouch connect software that you used to be able to actually program the stats in the software and then upload the schedule to the cards? The only version on the site no longer does that. The old version also used to have an sd initialization wizard. Not sure that would help or not.
  4. xgfreon replied to xgfreon's topic in VenstarCT
    Actually looking at this non workin 7900 the firmware is older but using the built in firmware updater says its up to date. these things are a pain to update lol, cant find a small enough sd card so waiting for the amazon delivery to try and update manually. Will report back after that!
  5. xgfreon replied to xgfreon's topic in VenstarCT
    the living room which is the problem is the t7900 firmware says its up to date. looks like the quickest fix for my case is just swap these 2 stats and call it a day.
  6. xgfreon replied to xgfreon's topic in VenstarCT
    also I have 5 of these thermostats, only 2 of them have Humidity option and I notice the other one seems to be importing correctly though this is not the one connected to my humidifier.
  7. xgfreon replied to xgfreon's topic in VenstarCT
    after changing that dehumidity setpoint i can confirm that value is what is being imported to the humidifier active box.
  8. xgfreon replied to xgfreon's topic in VenstarCT
    I do and here is the dash for humidity. I see there is a dehumidify options and there is a 99% in that box, i wonder if that is the data being populated there.
  9. xgfreon replied to xgfreon's topic in VenstarCT
    Yes I was hoping it would just report status off or On. Just stays 99 when off or on though I have had these for years but never messed with humidity settings in ISY until recent so I cant say how it reported in the past.
  10. xgfreon posted a topic in VenstarCT
    I am trying to trigger a program based on the humidifier running. The humidifier active always just shows a 99 running or not.
  11. setting clear_hubs to 1, then wait a few seconds and run discover again has fixed this issue.
  12. I do have .13 reserved in the router. It did used to be .12 when it wasnt static and it had changed maybe a couple weeks ago while i was messing around with some vpn stuff. But since this morning i have updated polisy to 5.7 and upgraded to pg3x. and have restarted the system a few times all while having static ip of the harmony at .13 so not sure why the logs would ever be showing the unable to connect to the .12 nag since.
  13. any ideas why its trying to connect to when my harmony hub ip ends with 13?
  14. Is there a way to make my slider or switch to OFF only? I have a scene for all lights off and don't want to accidently turn them all back on. Maybe there is a way in the scene to set all the devices to never be allowed on?
  15. Thanks, I have yet to play with variables. I realize now that I do have most these in scenes, especial to get keypad Linc status to change. I didn't realize that in most cases I should have my Alexa command just switch on the scene rather than the switch. That will probably fix the few that are giving me the issues. Thanks for leaving me some ideas, now I will have to mess with getting those dimmer status to sync as well.
