GTench
  1. Sorry to hear it is not working for you. I found that I needed the 1 minute wait because a number of my disconnects occurred when the computer running blue iris did an automatic windows update. This 1 minute delay gave the computer time to reboot and restart blue iris allowing the rediscover command time to see blue iris
  2. I have 10 or 12 motion sensors used for both alarming and triggering room lights when not armed and they work fine with the plugin... no problems Gary
  3. This is how I handle it: If 'Blue Iris' Server Status is Disconnected Or 'Blue Iris' Server Status is Red Then Send Notification to 'Gary' content 'Blue Iris Disconnected' Wait 1 minute Set 'Blue Iris' Re-Discover Else - No Actions - (To add one, press 'Action') Followed by a second program: If 'Blue Iris' Server Status is Green Then Wait 1 minute Send Notification to 'Gary' content 'Blue Iris Node Server Reconnected' Else - No Actions - (To add one, press 'Action')
  4. I realize not all devices can be direct linked but I checked with Yolink about direct linking the relay before buying it. I believe Yolink promoted this direct link capability in particular for their water shutoff valve as a means to overcome criticism about their system depending upon the cloud. In my case, it came down to a choice of direct connecting the relay or replacing my Z-wave shutoff valve with the Yolink one, which was considerably more expensive than the relay. Also, I had already mechanically attached the Z-wave shutoff valve to my water shutoff valve. The speaker hub can not be triggered locally without an internet connection. I tried it and it did not work. Not sure if the local hub gets around this issue. The reason I used the alarm panel was because the relay needs to be powered (12V I believe). So, I mounted the relay on the alarm panel and powered it from that... just easier for me
  5. I relaced all my Z-wave leak sensors with Yolink leak sensors because the reporting from the Z-wave sensors was spotty and battery life was poor. Since Yolink has the capability to direct connect wirelessly devices together, I made use of that capability so I would not have to depend on the internet/cloud being available. This way they are operating in a local mode as well. I direct connected all the leak sensors to a Yolink relay which then connects to a home automation zone in my alarm panel which is being monitored by eisy (although I could have used an insteon sensor instead of an alarm panel zone). The eisy then triggers a Z-wave water shutoff value (which I originally got with the Z-wave leak sensors) when a leak is detected. It will also send an email if the internet is up. I set this up before the Yolink local hub was available. This has operated/triggered 2 or 3 times successfully over the past year or so. I don't use Alexa but I do have 4 speaker hubs scattered through the house. They are used to announce various events like garage door being left open and water being shutoff due to a leak. @Panda88 It looks like you can have more than 10 messages. I believe you suggested earlier in the year to try more; so, I did. I tried 11 messages and that worked. Not sure what the limit would be Gary
  6. @sjenkinsso far everything is working just fine. I will let you know if I run across any problems. Here are the logs from the non production install HunterDouglas_10-9-2025_124159_PM.zip
  7. @sjenkinsthanks again for looking into this. The reinstall worked without raising the error message. I am running on eisy and have been since it was introduced
  8. @sjenkinsOK here it is HunterDouglas_10-6-2025_110206_AM.zip
  9. @sjenkinsOK here is the log file. AC shows it as connected but programs not working HunterDouglas_10-5-2025_102538_AM.zip
  10. @sjenkinsSeems to be running according to the AC but PG3 shows this message
  11. @sjenkins Glad to help. I was initially delaying testing because I thought IOX 6 was about to be released and I was hoping to install it first before testing. I installed your production version and it is working well.
  12. @sjenkinsYes everything appears to be working normally. Thanks for your help. You were correct about the app. it did not show status either. I refreshed the battery status and it now appears in both the app and your plugin. I suspect the AC lockup issue that occurs with both plugin versions installed might just be a problem with the AC
  13. @sjenkinsOK thanks. No matter what I do/try I cannot get the AC programs tab to open if I have both the production and beta versions installed at the same time in different slots even with one or the other stopped - the AC just freezes; so I deleted the beta version and installed the beta version into the production slot. This seems to be working o.k. I can open the AC programs tab and a test of one of my programs worked successfully. I can also manually open and close a shade from the AC. I notice one of my shades battery status says "no status". All the other shades show battery status
  14. @sjenkinsJust a follow up. I tried manually opening and closing one of the shades from the AC using both the beta and production versions once I identified the shade using the number and that worked ok. Both beta and production were installed. I still cannot load programs with both beta and production installed.
  15. @sjenkinsI was thinking of biting the bullet and just install the beta version as a replacement for the production version and test it that way but first I thought I would see if I could manually operate the shades from the beta version in the AC; however, I noticed that the names are not correct now. Just wondering if you changed anything.
