GTench
  1. I also have a ZSE70 installed on eisy 6.0.5 with the ZMatter board and it shows temperature
  2. I also use the DSC polyglot plugin. I have 64 zones with many of them integrated as triggers in various ISY programs. I am extremely happy with the performance
  3. So you can see the zones in eisy but not in EyezON? If so, do they change state properly in eisy when activated?
  4. If you cannot see zones in EyezON, then I am guessing that is why it is not working with the plugin
  5. My setup is not exactly like yours. I have a DSC panel with 64 zones and the EnvisaLInk 4 and it is working well with the plugin. Does not the Neo come with 8 zones? Just wondering why you needed the UNO4 expansion board to make EnvisaLInk work? Is the UNO4 (UNO 8?)board properly registered with the motherboard?
  6. I assume the XXXXX are just to hide real values?
  7. @jim_ I have a number of hardwired alarm PIR motion sensors throughout the house all connected to a DSC alarm panel. I use the DSC plugin to connect these to the eisy to control insteon lighting via a number of different programs depending on the locations needs. Once the PIR has detected motion (as indicated by the red LED illumination), the triggering of the lights is very quick. The only delay that I notice in this setup is with the PIR sensors. Sometimes they activate very quickly, sometimes slower. The PIRs have sensitivity adjustment and I could adjust those but so far any delays have not bothered me
  8. GTench replied to Techman's topic in eisy
    Update from 6.0.4 to 6.0.5 went smoothly. No issues for me
  9. Sorry to hear it is not working for you. I found that I needed the 1 minute wait because a number of my disconnects occurred when the computer running blue iris did an automatic windows update. This 1 minute delay gave the computer time to reboot and restart blue iris allowing the rediscover command time to see blue iris
  10. I have 10 or 12 motion sensors used for both alarming and triggering room lights when not armed and they work fine with the plugin... no problems Gary
  11. This is how I handle it: If 'Blue Iris' Server Status is Disconnected Or 'Blue Iris' Server Status is Red Then Send Notification to 'Gary' content 'Blue Iris Disconnected' Wait 1 minute Set 'Blue Iris' Re-Discover Else - No Actions - (To add one, press 'Action') Followed by a second program: If 'Blue Iris' Server Status is Green Then Wait 1 minute Send Notification to 'Gary' content 'Blue Iris Node Server Reconnected' Else - No Actions - (To add one, press 'Action')
  12. I realize not all devices can be direct linked but I checked with Yolink about direct linking the relay before buying it. I believe Yolink promoted this direct link capability in particular for their water shutoff valve as a means to overcome criticism about their system depending upon the cloud. In my case, it came down to a choice of direct connecting the relay or replacing my Z-wave shutoff valve with the Yolink one, which was considerably more expensive than the relay. Also, I had already mechanically attached the Z-wave shutoff valve to my water shutoff valve. The speaker hub can not be triggered locally without an internet connection. I tried it and it did not work. Not sure if the local hub gets around this issue. The reason I used the alarm panel was because the relay needs to be powered (12V I believe). So, I mounted the relay on the alarm panel and powered it from that... just easier for me
  13. I relaced all my Z-wave leak sensors with Yolink leak sensors because the reporting from the Z-wave sensors was spotty and battery life was poor. Since Yolink has the capability to direct connect wirelessly devices together, I made use of that capability so I would not have to depend on the internet/cloud being available. This way they are operating in a local mode as well. I direct connected all the leak sensors to a Yolink relay which then connects to a home automation zone in my alarm panel which is being monitored by eisy (although I could have used an insteon sensor instead of an alarm panel zone). The eisy then triggers a Z-wave water shutoff value (which I originally got with the Z-wave leak sensors) when a leak is detected. It will also send an email if the internet is up. I set this up before the Yolink local hub was available. This has operated/triggered 2 or 3 times successfully over the past year or so. I don't use Alexa but I do have 4 speaker hubs scattered through the house. They are used to announce various events like garage door being left open and water being shutoff due to a leak. @Panda88 It looks like you can have more than 10 messages. I believe you suggested earlier in the year to try more; so, I did. I tried 11 messages and that worked. Not sure what the limit would be Gary
  14. @sjenkinsso far everything is working just fine. I will let you know if I run across any problems. Here are the logs from the non production install HunterDouglas_10-9-2025_124159_PM.zip
  15. @sjenkinsthanks again for looking into this. The reinstall worked without raising the error message. I am running on eisy and have been since it was introduced
