Scott847
Everything posted by Scott847
  1. Wow, thanks for the quick work! I started using the new version and am also using the new direct local query for a PurpleAir sensor. For a couple of locations I'm using the median of three nearby sensors so don't have a local sensor to query. It's great that the API call is now using 25 points per API call instead of 155. When I let PurpleAir know about the change they said they're "working on a process to automatically assign points to sensor owners but we are not quite there" and to email them in the meantime as I need more free points. Not sure if it's unique to my system but FYI I had to update a program line that uses the plugin perhaps because a "μg/m3" unit of measure was added at some point.
  2. PurpleAir is starting to charge for API usage and sent me an email to let me know this would take effect for me on 11/28/2023. There is a cost per point and the number of points used is based on the number of API calls as well as the fields that are returned for each call. In looking at the code I realized that the current PG3x PurpleAir plugin isn't specifying the "fields" parameter, which defaults to returning all data fields for the sensor even though most aren't sent to IoX. As a result each API call is currently using 155 points. I've been pulling data from seven PurpleAir sensors at the default short poll time of 600 seconds, which means I would be getting charged for about 4,700,000 points per month. PurpleAir will be charging $1 per 100,000 points so this means my monthly charge if nothing changes would be about $47.00. @bpwwer, could you look into using the "fields" parameter in the API calls to reduce points usage? FYI PurpleAir support also provided this link that had more info about efficiently using their API calls: https://community.purpleair.com/t/how-to-make-efficient-api-calls/6906 Also FYI they'll be giving points credits to owners of PurpleAir sensors to offset any usage for API access to their devices. In an email to me they said "We don't want sensor owners to pay for API access for purchased sensors if the point use is reasonable and the API pulls are optimized." I originally obtained an API key from them by email but since then they've created an API account management system where you can manage API keys and monitor usage at https://develop.purpleair.com/
  3. As a test I modified the text-to-speech TTS0 "Message 0" to "testing 1 2 3 testing 1 2 3" and didn't have to restart my Polisy nor IoX. The change showed up in the IoX admin console after restarting the YoLink node server and closing/opening the admin console. One other "secret" I noticed is to wait a sufficient amount of time for the YoLink node server to fully restart. In my case it takes nearly 2 minutes to complete the restart. Thanks for your work on the YoLink node server!
  4. Using a Polisy with a YoLink Speaker Hub the following steps worked for adding new text-to-speech messages: In YoLink node server increase configuration key NBR_TTS by the number of new text-to-speech messages, in my case increased from 1 to 5 Restart YoLink node server and new keys TTS1 through TTS4 appeared and I added the text I wanted it to say (for example, "side gate opened" for TTS3) Restart YoLink again, which I think may be needed to make the new text-to-speech messages active Close and reopen the IoX admin console so that the new messages appeared as an option for the Speaker Hub device "Select Message" function (I didn't have to restart Polisy nor IoX, only the admin console) Added the Set 'Speaker Hub' Select Message "side gate opened" and Set 'Speaker Hub' Play Message to a program Thanks @whywork, @Bumbershoot and @Panda88 for your notes on this!
  5. Some answers based on my experience but others may have better info.... Q: Exclude and re-include Schlage lock... Not sure what you mean here, are you referring to removing the lock completely from the controller and adding it back in? Yes, in admin console I did a "Z-Wave / Remove a Z-Wave Device" followed by a "Z-Wave / Add a Z-Wave Device." Q: "The reason is even if I remove it, it will still have ghost objects reappear under certain circumstances and the only way to clear those and not have them come back is to do a reset on the ZWave controller." I haven't often seen ghost objects but there's a "Z-Wave / Synchronize / New & Deleted" that might get rid of them. Restarting the admin console is also a good step between significant changes. It's been a few years since I've had to do a Z-Wave reset. For my ISY to Polisy conversion I was able to restore from the ISY but excluded/included a few devices. Q: BTW - I used to have an BE469NX and changed it out to the one I have now. Your old one is on S0, isn't it? Yes, I believe my old BE469NX security setting is S0. Q: When you did your include did use the standard old school ZWave include or scan the DSK via UDM? I used the old school "Add a Z-Wave Device." I believe my lock was manufactured before there was a scan code.
  6. Don't know if these steps would help but my Schlage BE469NX (purchased 2015, firmware MAIN_6.8) so far seems to be reporting reliably after I upgraded from my ISY to a Polisy with ZMatter a few days ago. After some initial problems it's working now after some combination of the following: - In admin console: Z-Wave / Network / Communication Speed = 100 (Slowest) - In admin console: Z-Wave / Network / Interview Timeout = 30 Seconds - In admin console: Z-Wave / Network / Heal Network -- Network Heal can take a long time, watch progress in Tools / Diagnostics / Event Viewer - Exclude and re-include Schlage lock - Right click on lock and Z-Wave / Update Neighbors - Right click on lock and Z-Wave / Synchronize / Update with interview It still shows "Interview Not Done" when looking at Z-Wave / X-Ray / DH All Devices / Go but I'm not seeing any side effects. These are the nodes showing up for the lock: - ZY 022 Door Lock -- ZY 022 Access Control Alarm -- ZY 022 Hardware Failure Alarm -- ZY 022 Home Security Alarm -- ZY 022 Intrusion Alarm -- ZY 022 Power Alarm -- ZY 022 System Alarm
  7. My understanding is that for battery operated devices like the ZSE44 there's no way for IoX to wake it up after restarting and it doesn't remember the last reading before restart. So there won't be any reading in IoX until either a threshold is crossed (e.g., a 2 degree temperature change from last report) or the maximum reporting interval is exceeded (e.g., every 4 hours for temperature). If you leave your AC running for awhile you can look at Tools / Diagnostics / Event Viewer and download that to a file. Scanning through that I found that my ZSE44 device reported temperature changes at the following times today for device ID ZY023_118: 12:28:57 AM 04:31:11 AM 08:33:31 AM 09:10:49 AM
  8. One possibility is the battery-friendly default settings for the ZSE44. For example, the default for temperature reporting is to update only for changes > 2 degrees, or every 4 hours. The manual has info about the default settings, how to force wake the sensor and more: https://www.getzooz.com/downloads/zooz-z-wave-plus-700-series-temperature-humidity-xs-sensor-zse44-manual.pdf I installed one recently for humidity monitoring. It's been working great after I changed the humidity threshold from the default of a 10% change triggering reporting.
  9. It hasn't successfully updated all devices for the initial YoLink installation on this Polisy. I sent you the debug log from the time I did a restart just now.
  10. I'm installing the YoLink node server on a 2nd Polisy. Although it seems to install correctly and finds all devices, it starts reporting "not online" messages from initNode for all devices after the 9th device. The 10th device is a motion sensor, but not sure if that has anything to do with the problem. In this log the "4GD Leak Sink" device successfully reports status to IoX but nothing after that. 2023-03-23 14:37:52,703 Thread-4 udi_interface INFO udi-YoLink:addNodes: adding/checking device : 4GD Leak Sink - LeakSensor 2023-03-23 14:37:52,704 Thread-4 udi_interface INFO udi-YoLink:addNodes: Adding device 4GD Leak Sink (LeakSensor) as 8b4c0200006ec5 2023-03-23 14:37:52,716 Thread-4 udi_interface.interface INFO interface:addNode: Adding node 4GD Leak Sink(8b4c0200006ec5) [None] 2023-03-23 14:37:52,718 Thread-4 udi_interface.custom INFO custom:_save: Sending data customparams to Polyglot. 2023-03-23 14:37:52,872 Thread-161 udi_interface INFO udi-YoLink:handleLevelChange: New log level: {'name': 'INFO', 'level': 20} 2023-03-23 14:37:52,883 Thread-162 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2023-03-23 14:37:52,963 Thread-163 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2023-03-23 14:37:52,967 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customparams 2023-03-23 14:37:53,011 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2023-03-23 14:37:53,053 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2023-03-23 14:37:53,156 Thread-165 udi_interface INFO udiYoLeakSensorV2:start: start - YoLinkLeakSensor 2023-03-23 14:37:53,161 Thread-165 udi_interface INFO yoLink_init_V3:subscribe_mqtt: Subscribing deviceId d88b4c0200006ec5 to MQTT 2023-03-23 14:37:56,528 MQTT udi_interface.interface INFO interface:_message: Successfully set 8b4c0200006ec5 :: GV0 to 0 UOM 25 2023-03-23 14:37:56,624 MQTT udi_interface.interface INFO interface:_message: Successfully set 8b4c0200006ec5 :: GV1 to 4 UOM 25 2023-03-23 14:37:56,760 MQTT udi_interface.interface INFO interface:_message: Successfully set 8b4c0200006ec5 :: ST to 1 UOM 25 2023-03-23 14:37:57,123 MQTT udi_interface.interface INFO interface:_message: Successfully set 8b4c0200006ec5 :: CLITEMP to 13 UOM 4 2023-03-23 14:37:58,507 Thread-6 udi_interface ERROR yoLink_init_V3:on_disconnect: Unintentional disconnect - Reacquiring connection 2023-03-23 14:37:58,900 Thread-4 udi_interface INFO udi-YoLink:addNodes: adding/checking device : 4GD Motion Living Room - MotionSensor 2023-03-23 14:37:58,902 Thread-4 udi_interface INFO udi-YoLink:addNodes: Adding device 4GD Motion Living Room (MotionSensor) as 8b4c01000260ea 2023-03-23 14:37:58,915 Thread-4 udi_interface.interface INFO interface:addNode: Adding node 4GD Motion Living Room(8b4c01000260ea) [None] 2023-03-23 14:37:58,917 Thread-4 udi_interface.custom INFO custom:_save: Sending data customparams to Polyglot. 2023-03-23 14:37:59,165 Thread-189 udi_interface INFO udi-YoLink:handleLevelChange: New log level: {'name': 'INFO', 'level': 20} 2023-03-23 14:37:59,182 Thread-190 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2023-03-23 14:37:59,256 Thread-191 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2023-03-23 14:37:59,260 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customparams 2023-03-23 14:37:59,304 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2023-03-23 14:37:59,346 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2023-03-23 14:37:59,441 Thread-193 udi_interface INFO udiYoMotionSensorV2:start: start - udiYoLinkMotionSensor 2023-03-23 14:37:59,444 Thread-193 udi_interface INFO yoLink_init_V3:subscribe_mqtt: Subscribing deviceId d88b4c01000260ea to MQTT 2023-03-23 14:38:00,541 Thread-6 udi_interface INFO yoLink_init_V3:connect_to_broker: Connecting to broker... 2023-03-23 14:38:00,966 Thread-6 udi_interface INFO yoLink_init_V3:connect_to_broker: Retrieving YoLink API info 2023-03-23 14:38:04,504 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c0200003985 2023-03-23 14:38:04,507 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c02000853dd 2023-03-23 14:38:04,510 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c0200005e4a 2023-03-23 14:38:04,512 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c02000853ef 2023-03-23 14:38:04,514 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c02000039f5 2023-03-23 14:38:04,516 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c0200006fbd 2023-03-23 14:38:04,519 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c0200006eb0 2023-03-23 14:38:04,521 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c02000067ab 2023-03-23 14:38:04,523 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c0200006ec5 2023-03-23 14:38:04,526 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c01000260ea 2023-03-23 14:38:05,697 Thread-6 udi_interface ERROR yoLink_init_V3:on_connect: Authentication error 2 - Token no longer valid - Need to reconnect 2023-03-23 14:38:05,699 Thread-6 udi_interface INFO yoLink_init_V3:refresh_token: Refreshing Token 2023-03-23 14:38:07,511 Thread-193 udi_interface ERROR yolink_mqtt_classV3:initNode: MotionSensor not online 2023-03-23 14:38:08,043 Thread-4 udi_interface INFO udi-YoLink:addNodes: adding/checking device : 4GD TH Basement - THSensor 2023-03-23 14:38:08,044 Thread-4 udi_interface INFO udi-YoLink:addNodes: Adding device 4GD TH Basement (THSensor) as 8b4c010002acc7 2023-03-23 14:38:08,058 Thread-4 udi_interface.interface INFO interface:addNode: Adding node 4GD TH Basement(8b4c010002acc7) [None] 2023-03-23 14:38:08,061 Thread-4 udi_interface.custom INFO custom:_save: Sending data customparams to Polyglot. 2023-03-23 14:38:08,138 Thread-6 udi_interface INFO yoLink_init_V3:connect_to_broker: Connecting to broker... 2023-03-23 14:38:08,139 Thread-6 udi_interface INFO yoLink_init_V3:connect_to_broker: Retrieving YoLink API info 2023-03-23 14:38:08,226 Thread-217 udi_interface INFO udi-YoLink:handleLevelChange: New log level: {'name': 'INFO', 'level': 20} 2023-03-23 14:38:08,245 Thread-218 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2023-03-23 14:38:08,322 Thread-219 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2023-03-23 14:38:08,324 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customparams 2023-03-23 14:38:08,335 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2023-03-23 14:38:08,418 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2023-03-23 14:38:08,493 Thread-221 udi_interface INFO udiYoTHsensorV2:start: Start udiYoTHsensor 2023-03-23 14:38:08,495 Thread-221 udi_interface INFO yoLink_init_V3:subscribe_mqtt: Subscribing deviceId d88b4c010002acc7 to MQTT 2023-03-23 14:38:11,696 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c0200003985 2023-03-23 14:38:11,700 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c02000853dd 2023-03-23 14:38:11,702 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c0200005e4a 2023-03-23 14:38:11,704 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c02000853ef 2023-03-23 14:38:11,707 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c02000039f5 2023-03-23 14:38:11,709 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c0200006fbd 2023-03-23 14:38:11,711 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c0200006eb0 2023-03-23 14:38:11,714 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c02000067ab 2023-03-23 14:38:11,716 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c0200006ec5 2023-03-23 14:38:11,719 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c01000260ea 2023-03-23 14:38:11,721 Thread-6 udi_interface INFO yoLink_init_V3:update_mqtt_subscription: update_mqtt_subscription d88b4c010002acc7 2023-03-23 14:38:12,595 Thread-234 udi_interface ERROR yoLink_init_V3:transfer_data: Error 4 during publishing {'time': '1679596691560', 'method': 'THSensor.getState', 'targetDevice': 'd88b4c010002acc7', 'token': 'E8867B438B4D0193CB6C9C85618B907A'} 2023-03-23 14:38:14,616 Thread-221 udi_interface ERROR yolink_mqtt_classV3:initNode: THSensor not online 2023-03-23 14:38:17,219 Thread-4 udi_interface INFO udi-YoLink:addNodes: adding/checking device : 4GD TH Dining Room - THSensor 2023-03-23 14:38:17,220 Thread-4 udi_interface INFO udi-YoLink:addNodes: Adding device 4GD TH Dining Room (THSensor) as 8b4c010002b356 2023-03-23 14:38:17,235 Thread-4 udi_interface.interface INFO interface:addNode: Adding node 4GD TH Dining Room(8b4c010002b356) [None] 2023-03-23 14:38:17,237 Thread-4 udi_interface.custom INFO custom:_save: Sending data customparams to Polyglot. 2023-03-23 14:38:17,395 Thread-247 udi_interface INFO udi-YoLink:handleLevelChange: New log level: {'name': 'INFO', 'level': 20} 2023-03-23 14:38:17,413 Thread-248 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2023-03-23 14:38:17,484 Thread-249 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2023-03-23 14:38:17,488 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customparams 2023-03-23 14:38:17,573 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2023-03-23 14:38:17,576 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2023-03-23 14:38:17,669 Thread-251 udi_interface INFO udiYoTHsensorV2:start: Start udiYoTHsensor 2023-03-23 14:38:17,672 Thread-251 udi_interface INFO yoLink_init_V3:subscribe_mqtt: Subscribing deviceId d88b4c010002b356 to MQTT 2023-03-23 14:38:20,696 Thread-265 udi_interface ERROR yoLink_init_V3:transfer_data: Error 4 during publishing {'time': '1679596700694', 'method': 'THSensor.getState', 'targetDevice': 'd88b4c010002b356', 'token': '29A682732F75E02A910E4D9C7379E1E7'} 2023-03-23 14:38:22,733 Thread-251 udi_interface ERROR yolink_mqtt_classV3:initNode: THSensor not online
  11. While you're looking into this could you also check leak sensors? In the YoLink app the leak sensor details show temperatures, which could be useful.
  12. VUE installed successfully after doing the "Install Dev. Packages." Thanks for the quick response. FYI after clicking the option to install dev packages the 2nd and 3rd Polisy lights continued to flash. I waited ~30 minutes and then did a Polisy Reboot from the admin console. It booted successfully and then I installed the VUE node server.
  13. @bpwwer I'm getting an error when I try to install the VUE node server on a Polisy. Perhaps related to the python-jose[cryptography]==3.3.0 requirement? It looks like it tries to build pycryptodome and runs into a compile error when it can't find stdint.h. Following are some log excerpts showing the problem: 1/27/2023, 12:46:35 [pg3] info: NSChild: VUE(7) /bin/sh: Collecting python-jose[cryptography]==3.3.0 1/27/2023, 12:46:35 [pg3] info: NSChild: VUE(7) /bin/sh: Downloading python_jose-3.3.0-py2.py3-none-any.whl (33 kB) <snip> 1/27/2023, 12:46:54 [pg3] info: NSChild: VUE(7) /bin/sh: Collecting pycryptodome<3.4.0,>=3.3.1 1/27/2023, 12:46:55 [pg3] info: NSChild: VUE(7) /bin/sh: Downloading pycryptodome-3.3.1.tar.gz (3.1 MB) 1/27/2023, 12:46:55 [pg3] info: NSChild: VUE(7) /bin/sh: ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.1/3.1 MB 16.2 MB/s eta 0:00:00 1/27/2023, 12:46:55 [pg3] info: NSChild: VUE(7) /bin/sh: 1/27/2023, 12:46:55 [pg3] info: [00:0d:b9:53:2a:14_7] Retrieved customparams 1/27/2023, 12:46:55 [pg3] info: [00:0d:b9:53:2a:14_7] Retrieved oauth 1/27/2023, 12:46:56 [pg3] info: NSChild: VUE(7) /bin/sh: Preparing metadata (setup.py): started 1/27/2023, 12:46:58 [pg3] info: NSChild: VUE(7) /bin/sh: Preparing metadata (setup.py): finished with status 'done' 1/27/2023, 12:46:59 [pg3] info: NSChild: VUE(7) /bin/sh: Requirement already satisfied: pycparser in /usr/local/lib/python3.9/site-packages (from cffi>=1.12->cryptography>=3.4.0->python-jose[cryptography]==3.3.0->-r requirements.txt (line 6)) (2.21) 1/27/2023, 12:47:01 [pg3] info: NSChild: VUE(7) /bin/sh: Building wheels for collected packages: pycryptodome 1/27/2023, 12:47:01 [pg3] info: NSChild: VUE(7) /bin/sh: Building wheel for pycryptodome (setup.py): started 1/27/2023, 12:47:05 [pg3] info: NSChild: VUE(7) /bin/sh: Building wheel for pycryptodome (setup.py): finished with status 'error' <snip> running build_ext warning: no support for Intel AESNI instructions building 'Crypto.Hash._MD2' extension creating build/temp.freebsd-13.1-RELEASE-p5-amd64-cpython-39 creating build/temp.freebsd-13.1-RELEASE-p5-amd64-cpython-39/src cc -pthread -Wno-unused-result -Wsign-compare -Wunreachable-code -DNDEBUG -O2 -pipe -fstack-protector-strong -fno-strict-aliasing -fPIC -DLTC_NO_ASM -Isrc/ -I/usr/local/include/python3.9 -c src/MD2.c -o build/temp.freebsd-13.1-RELEASE-p5-amd64-cpython-39/src/MD2.o In file included from src/MD2.c:28: src/pycrypto_common.h:47:10: fatal error: 'stdint.h' file not found #include <stdint.h> ^~~~~~~~~~ 1 error generated. error: command '/usr/bin/cc' failed with exit code 1 [end of output] note: This error originates from a subprocess, and is likely not a problem with pip. ERROR: Failed building wheel for pycryptodome 1/27/2023, 12:47:05 [pg3] info: NSChild: VUE(7) /bin/sh: Running setup.py clean for pycryptodome 1/27/2023, 12:47:05 [pg3] info: set to expire on 2023-02-20T00:39:32.000Z 1/27/2023, 12:47:05 [pg3] info: set to expire on 2023-02-16T22:03:49.000Z 1/27/2023, 12:47:06 [pg3] info: [XX:XX:XX:XX:XX:XX_X] controller reporting command DOF 1/27/2023, 12:47:07 [pg3] info: NSChild: VUE(7) /bin/sh: Failed to build pycryptodome
  14. Not sure if something like this would be useful but Initial State is great for data visualization: https://www.initialstate.com/ This is one tile showing voltages on an Initial State dashboard. Following are the network resource settings for voltage from an Aeotec Smart Switch 6. Protocol Information: https POST Host = groker.initialstate.com Port = 443 Path = /api/events Encode URL = unchecked Use SNI = unchecked Timeout (ms) = 5,000 Mode = Raw Text Headers: Content-Type = application/json X-IS-AccessKey = [your Initial State access key] X-IS-BucketKey = [your key for an Initial State "bucket" you create] Body: [ {"key": "Sump Pump Volts", "value": ${sys.node.ZW005_143.CV.raw}}, {"key": "Sump Pump Watts", "value": ${sys.node.ZW005_143.ST.raw}}, {"key": "Sump Pump Amps", "value": ${sys.node.ZW005_143.CC.raw}}, {"key": "Sump Pump kWh", "value": ${sys.node.ZW005_143.TPW.raw}} ]
  15. I had the same symptom due to psutil not being found during YoLink installation. The solution was to connect using SSH (using PuTTY for example) and installing psutil: sudo pkg install py39-psutil This is the thread about this:
  16. I was able to get YoLink installed and it appears to be working great! Temp/humidity sensors and leak sensors are all reporting normally. The problem I was experiencing during installation was a failure when automatically compiling psutil after the PG3 YoLink node server couldn't find psutil 5.9.2. I'm not sure if this is a workaround in need of a permanent solution, or a solution that should be documented. Anyway, the solution was to install the psutil package: sudo pkg install py39-psutil
  17. I noticed you're specifying "psutil==5.9.2" in requirements.txt and now I'm getting the previous error again. It appears PG3 isn't finding psutil so it tries to run the c compiler to build psutil and runs into an error because it can't find "limits.h". I assume this limits.h include file must be somewhere on your system but not mine. Do you know where limits.h is located on your system? Or what I can install that would include this file? This is the log showing the psutil compile failure: cc -pthread -Wno-unused-result -Wsign-compare -Wunreachable-code -DNDEBUG -O2 -pipe -fstack-protector-strong -fno-strict-aliasing -fPIC -DPSUTIL_POSIX=1 -DPSUTIL_BSD=1 -DPSUTIL_SIZEOF_PID_T=4 -DPSUTIL_VERSION=592 -DPSUTIL_FREEBSD=1 -I/usr/local/include/python3.9 -c psutil/_psutil_bsd.c -o build/temp.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil/_psutil_bsd.o In file included from psutil/_psutil_bsd.c:22: /usr/local/include/python3.9/Python.h:11:10: fatal error: 'limits.h' file not found #include <limits.h> ^~~~~~~~~~ 1 error generated. error: command '/usr/bin/cc' failed with exit code 1
  18. I'm getting a different error: "NSChild: YoLink(1) /bin/sh: ERROR: Invalid requirement: 'psutil=5.9.2' (from line 4 of requirements.txt) Hint: = is not a valid operator. Did you mean == ?" Here's the complete log: 12/21/2022, 18:10:23 [pg3] info: [XX:XX:XX:XX:XX:XX_1] :: Creating Node Server 'YoLink' 12/21/2022, 18:10:23 [pg3] info: Adding customparams entries to custom database 12/21/2022, 18:10:23 [pg3] info: Adding nsdata, oauth entries to custom database 12/21/2022, 18:10:23 [pg3] info: [XX:XX:XX:XX:XX:XX_1] Set nsdata 12/21/2022, 18:10:23 [pg3] info: [XX:XX:XX:XX:XX:XX_1] Set oauth 12/21/2022, 18:10:23 [pg3] info: checkLicense:: Updaing YoLink subscription expiration to 2023-01-01T05:24:10.000Z 12/21/2022, 18:10:23 [pg3] info: checkLicense:: YoLink Valid subscription license found. Expires: 2023-01-01T05:24:10.000Z 12/21/2022, 18:10:23 [pg3] warn: YoLink home directory exists already. 12/21/2022, 18:10:23 [pg3] info: [XX:XX:XX:XX:XX:XX_1] :: Cloning repository... https://github.com/Panda88CO/udi-yolink into /var/polyglot/pg3/ns/XXXXXXXXXXXX_1 12/21/2022, 18:10:31 [pg3] info: [XX:XX:XX:XX:XX:XX_1] :: Installation Complete. Added 'YoLink' to database... 12/21/2022, 18:10:31 [pg3] info: [XX:XX:XX:XX:XX:XX_1] 'YoLink' installed into ISY successfully... 12/21/2022, 18:10:34 [pg3] info: NSChild: YoLink(1) /bin/sh: Defaulting to user installation because normal site-packages is not writeable 12/21/2022, 18:10:35 [pg3] info: NSChild: YoLink(1) /bin/sh: Requirement already satisfied: pip in /usr/local/lib/python3.9/site-packages (22.2.2) 12/21/2022, 18:10:36 [pg3] info: NSChild: YoLink(1) /bin/sh: Collecting pip 12/21/2022, 18:10:36 [pg3] info: NSChild: YoLink(1) /bin/sh: Using cached pip-22.3.1-py3-none-any.whl (2.1 MB) 12/21/2022, 18:10:37 [pg3] info: [XX:XX:XX:XX:XX:XX_1] Retrieved customparams 12/21/2022, 18:10:37 [pg3] info: [XX:XX:XX:XX:XX:XX_1] Retrieved oauth 12/21/2022, 18:10:38 [pg3] info: NSChild: YoLink(1) /bin/sh: Installing collected packages: pip 12/21/2022, 18:10:51 [pg3] error: NSChild: YoLink(1) /bin/sh: WARNING: The scripts pip, pip3 and pip3.9 are installed in '/var/polyglot/.local/bin' which is not on PATH. Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location. 12/21/2022, 18:10:51 [pg3] info: NSChild: YoLink(1) /bin/sh: Successfully installed pip-22.3.1 12/21/2022, 18:10:55 [pg3] error: NSChild: YoLink(1) /bin/sh: ERROR: Invalid requirement: 'psutil=5.9.2' (from line 4 of requirements.txt) Hint: = is not a valid operator. Did you mean == ? 12/21/2022, 18:10:55 [pg3] info: NSChild: YoLink(1) /bin/sh: exited with cause code: 1 12/21/2022, 18:10:55 [pg3] error: installNs: Error: Non-zero exit code: 1 at ChildProcess.<anonymous> (/var/polyglot/node_modules/@universaldevices/pg3/lib/services/node servers.js:53:30) at ChildProcess.emit (node:events:513:28) at maybeClose (node:internal/child_process:1091:16) at ChildProcess._handle.onexit (node:internal/child_process:302:5) 12/21/2022, 18:10:55 [pg3] info: startNs:: YoLink 12/21/2022, 18:10:55 [pg3] info: startNs:: YoLink is valid 12/21/2022, 18:10:56 [pg3] info: checkLicense:: YoLink Valid subscription license found. Expires: 2023-01-01T05:24:10.000Z 12/21/2022, 18:10:56 [pg3] info: startNs:: YoLink finished update check 12/21/2022, 18:10:56 [pg3] info: [YoLink(1)] :: Starting Node Server - Version 0.7.3 12/21/2022, 18:10:56 [pg3] info: startNs:: YoLink updating database (enabled, timestarted) 12/21/2022, 18:10:57 [pg3] info: startNs:: YoLink starting polls 12/21/2022, 18:10:57 [pg3] info: Checking if ${Node Server.name} has expired 12/21/2022, 18:10:57 [pg3] info: Starting Node Server Info timer 0 12/21/2022, 18:10:57 [pg3] error: [YoLink(1)] :: STDERR: Traceback (most recent call last): File "/var/polyglot/pg3/ns/XXXXXXXXXXXX_1/./udi-YoLink.py", line 11, in <module> 12/21/2022, 18:10:57 [pg3] error: [YoLink(1)] :: STDERR: from yoLink_init_V3 import YoLinkInitPAC File "/var/polyglot/pg3/ns/XXXXXXXXXXXX_1/yoLink_init_V3.py", line 5, in <module> import psutil ModuleNotFoundError: No module named 'psutil' 12/21/2022, 18:10:57 [pg3] info: [YoLink(1)] :: Exit cause code: 1 - signal: null
  19. @Michel Kohanim - FYI I'm getting the same psutil build errors using yesterday's updated IoX 5.5.0 on a Polisy that I reinstalled on Tuesday with the Polisy FreeBSD 13.1 mSATA image. 12/17/2022, 12:26:15 [pg3] info: NSChild: YoLink(1) /bin/sh: Building wheels for collected packages: psutil 12/17/2022, 12:26:15 [pg3] info: NSChild: YoLink(1) /bin/sh: Building wheel for psutil (pyproject.toml): started 12/17/2022, 12:26:18 [pg3] info: NSChild: YoLink(1) /bin/sh: Building wheel for psutil (pyproject.toml): finished with status 'error' 12/17/2022, 12:26:19 [pg3] error: NSChild: YoLink(1) /bin/sh: error: subprocess-exited-with-error × Building wheel for psutil (pyproject.toml) did not run successfully. │ exit code: 1 ╰─> [48 lines of output] running bdist_wheel running build running build_py creating build creating build/lib.freebsd-13.1-RELEASE-p5-amd64-cpython-39 creating build/lib.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil copying psutil/__init__.py -> build/lib.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil copying psutil/_pslinux.py -> build/lib.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil copying psutil/_psaix.py -> build/lib.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil <snip> copying psutil/tests/test_testutils.py -> build/lib.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil/tests copying psutil/tests/test_aix.py -> build/lib.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil/tests copying psutil/tests/test_process.py -> build/lib.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil/tests running build_ext building 'psutil._psutil_bsd' extension creating build/temp.freebsd-13.1-RELEASE-p5-amd64-cpython-39 creating build/temp.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil creating build/temp.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil/arch creating build/temp.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil/arch/freebsd cc -pthread -Wno-unused-result -Wsign-compare -Wunreachable-code -DNDEBUG -O2 -pipe -fstack-protector-strong -fno-strict-aliasing -fPIC -DPSUTIL_POSIX=1 -DPSUTIL_BSD=1 -DPSUTIL_SIZEOF_PID_T=4 -DPSUTIL_VERSION=594 -DPSUTIL_FREEBSD=1 -I/usr/local/include/python3.9 -c psutil/_psutil_bsd.c -o build/temp.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil/_psutil_bsd.o In file included from psutil/_psutil_bsd.c:22: /usr/local/include/python3.9/Python.h:11:10: fatal error: 'limits.h' file not found #include <limits.h> ^~~~~~~~~~ 1 error generated. error: command '/usr/bin/cc' failed with exit code 1 [end of output] note: This error originates from a subprocess, and is likely not a problem with pip. 12/17/2022, 12:26:19 [pg3] error: NSChild: YoLink(1) /bin/sh: ERROR: Failed building wheel for psutil 12/17/2022, 12:26:19 [pg3] info: NSChild: YoLink(1) /bin/sh: Failed to build psutil 12/17/2022, 12:26:19 [pg3] error: NSChild: YoLink(1) /bin/sh: ERROR: Could not build wheels for psutil, which is required to install pyproject.toml-based projects
  20. I'm getting an error trying to install YoLink on Polyglot 3.1.16 with Polisy IoX 5.4.5. Perhaps a problem during installation while building psutil, related to limits.h not being found? Following is the main part of the log, full log attached: 12/17/2022, 09:12:44 [pg3] info: NSChild: YoLink(1) /bin/sh: Building wheels for collected packages: psutil 12/17/2022, 09:12:44 [pg3] info: NSChild: YoLink(1) /bin/sh: Building wheel for psutil (pyproject.toml): started 12/17/2022, 09:12:48 [pg3] info: NSChild: YoLink(1) /bin/sh: Building wheel for psutil (pyproject.toml): finished with status 'error' 12/17/2022, 09:12:48 [pg3] error: NSChild: YoLink(1) /bin/sh: error: subprocess-exited-with-error × Building wheel for psutil (pyproject.toml) did not run successfully. │ exit code: 1 ╰─> [48 lines of output] running bdist_wheel running build running build_py creating build creating build/lib.freebsd-13.1-RELEASE-p5-amd64-cpython-39 creating build/lib.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil copying psutil/_psposix.py -> build/lib.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil copying psutil/_pswindows.py -> build/lib.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil copying psutil/_pssunos.py -> build/lib.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil <snip> copying psutil/tests/test_sunos.py -> build/lib.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil/tests copying psutil/tests/test_system.py -> build/lib.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil/tests copying psutil/tests/test_osx.py -> build/lib.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil/tests running build_ext building 'psutil._psutil_bsd' extension creating build/temp.freebsd-13.1-RELEASE-p5-amd64-cpython-39 creating build/temp.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil creating build/temp.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil/arch creating build/temp.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil/arch/freebsd cc -pthread -Wno-unused-result -Wsign-compare -Wunreachable-code -DNDEBUG -O2 -pipe -fstack-protector-strong -fno-strict-aliasing -fPIC -DPSUTIL_POSIX=1 -DPSUTIL_BSD=1 -DPSUTIL_SIZEOF_PID_T=4 -DPSUTIL_VERSION=594 -DPSUTIL_FREEBSD=1 -I/usr/local/include/python3.9 -c psutil/_psutil_bsd.c -o build/temp.freebsd-13.1-RELEASE-p5-amd64-cpython-39/psutil/_psutil_bsd.o In file included from psutil/_psutil_bsd.c:22: /usr/local/include/python3.9/Python.h:11:10: fatal error: 'limits.h' file not found #include <limits.h> ^~~~~~~~~~ 1 error generated. error: command '/usr/bin/cc' failed with exit code 1 [end of output] note: This error originates from a subprocess, and is likely not a problem with pip. 12/17/2022, 09:12:48 [pg3] error: NSChild: YoLink(1) /bin/sh: ERROR: Failed building wheel for psutil 12/17/2022, 09:12:48 [pg3] info: NSChild: YoLink(1) /bin/sh: Failed to build psutil 12/17/2022, 09:12:48 [pg3] error: NSChild: YoLink(1) /bin/sh: ERROR: Could not build wheels for psutil, which is required to install pyproject.toml-based projects 2022-12-17 YoLink Installation Log.txt
  21. I'm getting the same error messages you are on some of your Schlage locks. Following are all details for the lock. Z-Wave node #3 shows as a Siren but it's actually an Aeotec Doorbell. Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] ---------------------------------------------- Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] ZW 008 Schlage Door Lock Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] ZW008_1 uid=8 type=4.64.3 mid=59 tid=25409 pid=20548 model=2 Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - x22 V1 APPLICATION_STATUS Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - x72 V1 MANUFACTURER_SPECIFIC Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - x7A V2 FIRMWARE_UPDATE_MD Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - x98 V1 SECURITY Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - x86 V1 VERSION Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - Secure Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - x5D V2 ANTITHEFT Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - x85 V1 ASSOCIATION Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - x20 V1 BASIC Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - x80 V1 BATTERY Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - x70 V1 CONFIGURATION Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - x62 V2 DOOR_LOCK Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - x71 V3 NOTIFICATION Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - x63 V1 USER_CODE Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - xEF V0 MARK Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] Last working route from ISY to Node 8 - ZW 008 Schlage Door Lock Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - Node 3 - ZW 003 Siren Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] Node 8 - ZW 008 Schlage Door Lock has the following neighbors Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - Repeater - Node 2 - ZW 002 Siren Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - Repeater - Node 3 - ZW 003 Siren Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] - Repeater - Node 17 - ZW 017 Energy Meter Mon 08/13/2018 04:22:08 PM : [ZW-SHOW ] Mon 08/13/2018 04:22:15 PM : [ZW-TX-FAILED] enc=Ok uid=8.0 cmd=0x85.05 ASSOCIATION Mon 08/13/2018 04:22:22 PM : [ZW-TX-FAILED] enc=Ok uid=8.0 cmd=0x85.05 ASSOCIATION Mon 08/13/2018 04:22:29 PM : [ZW-TX-FAILED] enc=Ok uid=8.0 cmd=0x85.05 ASSOCIATION Mon 08/13/2018 04:22:29 PM : [ZW-SHOW ] Node 8 - ZW 008 Schlage Door Lock cannot retrieve association groups Mon 08/13/2018 04:22:29 PM : [ZW-SHOW ] Mon 08/13/2018 04:22:29 PM : [ZW-SHOW ] ----------------------------------------------
  22. Thanks for the feedback. Is it safe to do Heals to fix the routing from the Schlage locks and/or other recommendations on how to fix?
  23. @Michel Kohanim, do you need any additional info to diagnose this problem?
  24. Is it safe to do a Heal? Or should I wait for a new release? Sent from my SM-T820 using Tapatalk
  25. An update... The Schlage manual lock/unlock status updates aren't getting to the ISY because of some kind of routing error. Below is a packet trace from a Z-Wave Toolbox showing this. Device #45 is the Schlage BE469NX lock and Device #7 is an Aeotec DSB28-ZWUS Energy Meter and both are securely included. The "Routed Error" message is coming from the Energy Meter back to the lock and it appears nothing is coming from the ISY. Michel, what should I do to troubleshoot further? I haven't done a heal yet per your note above. Z-Wave Toolbox Packet Trace *** 2018-07-15 13:29:10.417 RSSI 50, Source 45, Destination 1, Route (45)>7-(1), Command "Z-Wave Protocol Command 60" *** 2018-07-15 13:29:11.212 RSSI 57, Source 7, Destination 45, Route (7)>(45), Command "ACK" *** 2018-07-15 13:29:12.711 RSSI 58, Source 45, Destination 1, Route (45)-7>(1), Command "Z-Wave Protocol Command 60" *** 2018-07-15 13:29:13.727 RSSI 57, Source 45, Destination 1, Route (45)-7>(1), Command "Z-Wave Protocol Command 60" *** 2018-07-15 13:29:13.757 RSSI 58, Source 45, Destination 1, Route (45)-7>(1), Command "Z-Wave Protocol Command 60" *** 2018-07-15 13:29:13.785 RSSI 57, Source 1, Destination 45, Route (45)<7-(1), Command "Routed Error (2nd hop)" *** 2018-07-15 13:29:13.812 RSSI 57, Source 1, Destination 45, Route (45)<7-(1), Command "Routed Error (2nd hop)" *** 2018-07-15 13:29:13.840 RSSI 57, Source 1, Destination 45, Route (45)<7-(1), Command "Routed Error (2nd hop)"
