chachdog
Everything posted by chachdog
  1. Thanks for your reply. I opened a case. udx 3.5.5 freebsd 13.
  2. My networking broke also but I did not upgrade anything. I am on 5.8. I was in the gui and had plugged in some usb stick\hard drives when this all stopped working. I ran the dhcp command and it gave me an ip but it did not work upon a reboot. When running the dhcp command it does say unknown dhcp option value 0x7d but gets an ip. Should I run that script also even though I didn't upgrade to 5.9? I also did not see my plm in the diagnostics menu. Thanks
  3. i just found this.. https://irdb.globalcache.com/Home/Database
  4. format looks different. how do you convert it? Device Code: 7.7 Function: 67DTV 0000 006D 0000 0022 00AC 00AC 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0689
  5. Is it possible to build the sendir commands manually without the ilearn app? can i look on the internet for discreet codes and modify them or is it different format?
  6. I hadn't' hit save i guess outside the resource editor. It works!
  7. test is grayed out
  8. Trying to follow the steps to setup a resource to turn the tv ON. i have ilearned it, and send IR in the tool turns on the tv. I copied it to the body, added /r/n to the end hit update and save. sendir,1:1,2,37993,1,1,171,170,21,64,21,64,21,64,21,22,21,22,21,22,21,22,21,22,21,64,21,64,21,64,21,22,21,22,21,22,21,22,21,22,21,22,21,64,21,22,21,22,21,22,21,22,21,22,21,22,21,64,21,22,21,64,21,64,21,64,21,64,21,64,21,64,21,1782,171,170,21,64,21,64,21,64,21,22,21,22,21,22,21,22,21,22,21,64,21,64,21,64,21,22,21,22,21,22,21,22,21,22,21,22,21,64,21,22,21,22,21,22,21,22,21,22,21,22,21,64,21,22,21,64,21,64,21,64,21,64,21,64,21,64,21,1781/r/n Changed to tcp,ip port 4998 timeout 500ms mode C Escaped set up new program , assigned resource to then (The drop down arrow next to resource it is blank.) tried to run then but no activity on the IR lights on the tv. Am I missing something. Is it a ilearn repeat or connector or module setting? and my test button is grayed out.
  9. so if the battery is low you have to put it in linking mode to see that? I see a motion sensor batt low in the isy but not sure when or if it does anything.
  10. I have 8 insteon switches within 10 of each other and the plm is right there too. They are all new and dual band. The lights are low voltage and LED, not sure if that matters.
  11. I thought I had this motion sensor set to only trigger ON. IE not turn anything off. The off is handled with a 10 min wait > turn scene off Guest Bath Motion 1 - [iD 0021][Parent 0020] If Control 'Guest Bath / Guest Bath-Sensor' is switched On Then Set Scene 'Guest Bath / Guest Bath Lights All' On Wait 10 minutes Set Scene 'Guest Bath / Guest Bath Lights All' Fade Down Else - No Actions - (To add one, press 'Action')
  12. this time nothing came on Fri 12/25/2015 11:30:00 AM : [iNST-SRX ] 02 50 36.93.D7 00.00.01 CB 13 01 LTOFFRR(01) Fri 12/25/2015 11:30:00 AM : [std-Group ] 36.93.D7-->Group=1, Max Hops=3, Hops Left=2 Fri 12/25/2015 11:30:00 AM : [D2D EVENT ] Event [36 93 D7 1] [DOF] [1] uom=0 prec=-1 Fri 12/25/2015 11:30:00 AM : [ 36 93 D7 1] DOF 1 Fri 12/25/2015 11:30:00 AM : [D2D EVENT ] Event [36 93 D7 1] [sT] [0] uom=0 prec=-1 Fri 12/25/2015 11:30:00 AM : [ 36 93 D7 1] ST 0 Fri 12/25/2015 11:30:00 AM : [iNST-SRX ] 02 50 2D.47.F5 38.FF.95 41 11 01 LTONRR (01) Fri 12/25/2015 11:30:00 AM : [std-Cleanup ] 2D.47.F5-->ISY/PLM Group=1, Max Hops=1, Hops Left=0 Fri 12/25/2015 11:30:00 AM : [D2D EVENT ] Event [2D 47 F5 1] [DON] [0] uom=0 prec=-1 Fri 12/25/2015 11:30:00 AM : [ 2D 47 F5 1] DON 0 Fri 12/25/2015 11:30:00 AM : [D2D-CMP 0015] CTL [2D 47 F5 1] DON op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Fri 12/25/2015 11:30:00 AM : [iNST-SRX ] 02 50 36.93.D7 00.00.01 CB 13 01 LTOFFRR(01) Fri 12/25/2015 11:30:00 AM : [std-Group ] 36.93.D7-->Group=1, Max Hops=3, Hops Left=2 Fri 12/25/2015 11:30:00 AM : [D2D EVENT ] Event [36 93 D7 1] [DOF] [1] uom=0 prec=-1 Fri 12/25/2015 11:30:00 AM : [ 36 93 D7 1] DOF 1 Fri 12/25/2015 11:30:00 AM : [iNST-SRX ] 02 50 36.93.D7 38.FF.95 41 13 01 LTOFFRR(01) Fri 12/25/2015 11:30:00 AM : [std-Cleanup ] 36.93.D7-->ISY/PLM Group=1, Max Hops=1, Hops Left=0 Fri 12/25/2015 11:30:00 AM : [iNST-DUP ] Previous message ignored. Fri 12/25/2015 11:30:00 AM : [iNST-SRX ] 02 50 36.93.D7 13.01.01 CB 06 00 (00) Fri 12/25/2015 11:30:00 AM : [std-Group ] 36.93.D7-->13.01.01, Max Hops=3, Hops Left=2 Fri 12/25/2015 11:30:00 AM : [iNST-INFO ] Previous message ignored. Fri 12/25/2015 11:30:01 AM : [iNST-SRX ] 02 50 36.93.D7 13.01.01 C3 06 00 (00) Fri 12/25/2015 11:30:01 AM : [std-Group ] 36.93.D7-->13.01.01, Max Hops=3, Hops Left=0 Fri 12/25/2015 11:30:01 AM : [iNST-INFO ] Previous message ignored. Fri 12/25/2015 11:30:01 AM : [iNST-SRX ] 02 50 2D.47.F5 38.FF.95 47 11 01 LTONRR (01)
  13. I wired a new bathroom fixture in, I stole power from a near by junction box. All the devices in question (kitchen and bathroom) are within 10 feet of each other. The isy shows the light is on but is not. I captured the log when it happened. When the motion kicked sensor fired, the shower LED is the only one that came on even though they are in a scene together. Motion Sensor 36.93.D7 bath light 32.92.B6 shower LED 32.97.60 Wall LED 3B.A5.38 Fri 12/25/2015 10:23:40 AM : [iNST-SRX ] 02 50 36.93.D7 00.00.01 CB 11 01 LTONRR (01) Fri 12/25/2015 10:23:40 AM : [std-Group ] 36.93.D7-->Group=1, Max Hops=3, Hops Left=2 Fri 12/25/2015 10:23:40 AM : [D2D EVENT ] Event [36 93 D7 1] [DON] [1] uom=0 prec=-1 Fri 12/25/2015 10:23:40 AM : [ 36 93 D7 1] DON 1 Fri 12/25/2015 10:23:40 AM : [D2D-CMP 0021] CTL [36 93 D7 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Fri 12/25/2015 10:23:41 AM : [iNST-TX-I1 ] 02 62 00 00 11 CF 11 00 Fri 12/25/2015 10:23:41 AM : [D2D EVENT ] Event [36 93 D7 1] [sT] [255] uom=0 prec=-1 Fri 12/25/2015 10:23:41 AM : [ 36 93 D7 1] ST 255 Fri 12/25/2015 10:23:41 AM : [iNST-SRX ] 02 50 36.93.D7 00.00.01 C7 11 01 LTONRR (01) Fri 12/25/2015 10:23:41 AM : [std-Group ] 36.93.D7-->Group=1, Max Hops=3, Hops Left=1 Fri 12/25/2015 10:23:41 AM : [iNST-DUP ] Previous message ignored. Fri 12/25/2015 10:23:41 AM : [iNST-ACK ] 02 62 00.00.11 CF 11 00 06 LTONRR (00) Fri 12/25/2015 10:23:41 AM : [D2D EVENT ] Event [3B A5 38 1] [sT] [109] uom=0 prec=-1 Fri 12/25/2015 10:23:41 AM : [ 3B A5 38 1] ST 109 Fri 12/25/2015 10:23:41 AM : [D2D EVENT ] Event [38 92 B6 1] [sT] [153] uom=0 prec=-1 Fri 12/25/2015 10:23:41 AM : [ 38 92 B6 1] ST 153 Fri 12/25/2015 10:23:41 AM : [D2D EVENT ] Event [32 97 60 1] [sT] [102] uom=0 prec=-1 Fri 12/25/2015 10:23:41 AM : [ 32 97 60 1] ST 102 Fri 12/25/2015 10:23:42 AM : [iNST-SRX ] 02 50 36.93.D7 38.FF.95 4A 11 01 LTONRR (01) Fri 12/25/2015 10:23:42 AM : [std-Cleanup ] 36.93.D7-->ISY/PLM Group=1, Max Hops=2, Hops Left=2 Fri 12/25/2015 10:23:42 AM : [iNST-DUP ] Previous message ignored. Fri 12/25/2015 10:23:42 AM : [iNST-SRX ] 02 50 36.93.D7 11.01.01 CB 06 00 (00) Fri 12/25/2015 10:23:42 AM : [std-Group ] 36.93.D7-->11.01.01, Max Hops=3, Hops Left=2 Fri 12/25/2015 10:23:42 AM : [iNST-INFO ] Previous message ignored. Fri 12/25/2015 10:23:42 AM : [iNST-SRX ] 02 50 36.93.D7 11.01.01 CB 06 00 (00) Fri 12/25/2015 10:23:42 AM : [std-Group ] 36.93.D7-->11.01.01, Max Hops=3, Hops Left=2 Fri 12/25/2015 10:23:42 AM : [iNST-INFO ] Previous message ignored. Fri 12/25/2015 10:23:45 AM : [iNST-SRX ] 02 50 36.A6.77 00.00.01 CF 11 01 LTONRR (01) Fri 12/25/2015 10:23:45 AM : [std-Group ] 36.A6.77-->Group=1, Max Hops=3, Hops Left=3 Fri 12/25/2015 10:23:45 AM : [D2D EVENT ] Event [36 A6 77 1] [DON] [1] uom=0 prec=-1 Fri 12/25/2015 10:23:45 AM : [ 36 A6 77 1] DON 1 Fri 12/25/2015 10:23:45 AM : [D2D-CMP 001A] CTL [36 A6 77 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Fri 12/25/2015 10:23:45 AM : [ Time] 10:23:47 0(0) Fri 12/25/2015 10:23:46 AM : [iNST-SRX ] 02 50 36.A6.77 00.00.01 CF 11 01 LTONRR (01) Fri 12/25/2015 10:23:46 AM : [std-Group ] 36.A6.77-->Group=1, Max Hops=3, Hops Left=3 Fri 12/25/2015 10:23:46 AM : [iNST-DUP ] Previous message ignored. Fri 12/25/2015 10:23:46 AM : [iNST-SRX ] 02 50 36.A6.77 38.FF.95 45 11 01 LTONRR (01) Fri 12/25/2015 10:23:46 AM : [std-Cleanup ] 36.A6.77-->ISY/PLM Group=1, Max Hops=1, Hops Left=1 Fri 12/25/2015 10:23:46 AM : [iNST-DUP ] Previous message ignored. Fri 12/25/2015 10:23:46 AM : [iNST-SRX ] 02 50 36.A6.77 11.01.01 CF 06 00 (00) Fri 12/25/2015 10:23:46 AM : [std-Group ] 36.A6.77-->11.01.01, Max Hops=3, Hops Left=3 Fri 12/25/2015 10:23:46 AM : [iNST-INFO ] Previous message ignored. Fri 12/25/2015 10:23:47 AM : [iNST-SRX ] 02 50 36.A6.77 11.01.01 CF 06 00 (00) Fri 12/25/2015 10:23:47 AM : [std-Group ] 36.A6.77-->11.01.01, Max Hops=3, Hops Left=3 Fri 12/25/2015 10:23:47 AM : [iNST-INFO ] Previous message ignored. Fri 12/25/2015 10:23:47 AM : [iNST-TX-I1 ] 02 62 38 A6 13 0F 11 77 Fri 12/25/2015 10:23:47 AM : [iNST-ACK ] 02 62 38.A6.13 0F 11 77 06 LTONRR (77) Fri 12/25/2015 10:23:48 AM : [iNST-SRX ] 02 50 38.A6.13 38.FF.95 2F 11 77 LTONRR (77) Fri 12/25/2015 10:23:48 AM : [std-Direct Ack] 38.A6.13-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Fri 12/25/2015 10:23:57 AM : [iNST-SRX ] 02 50 36.A6.77 00.00.01 CF 11 01 LTONRR (01) Fri 12/25/2015 10:23:57 AM : [std-Group ] 36.A6.77-->Group=1, Max Hops=3, Hops Left=3 Fri 12/25/2015 10:23:57 AM : [D2D EVENT ] Event [36 A6 77 1] [DON] [1] uom=0 prec=-1 Fri 12/25/2015 10:23:57 AM : [ 36 A6 77 1] DON 1 Fri 12/25/2015 10:23:57 AM : [D2D-CMP 001A] CTL [36 A6 77 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Fri 12/25/2015 10:23:57 AM : [ Time] 10:23:58 0(0) Fri 12/25/2015 10:23:58 AM : [iNST-TX-I1 ] 02 62 38 A6 13 0F 11 77 Fri 12/25/2015 10:23:58 AM : [iNST-SRX ] 02 50 36.A6.77 00.00.01 CF 11 01 LTONRR (01) Fri 12/25/2015 10:23:58 AM : [std-Group ] 36.A6.77-->Group=1, Max Hops=3, Hops Left=3 Fri 12/25/2015 10:23:58 AM : [iNST-DUP ] Previous message ignored. Fri 12/25/2015 10:23:58 AM : [iNST-ACK ] 02 62 38.A6.13 0F 11 77 06 LTONRR (77) Fri 12/25/2015 10:23:59 AM : [iNST-SRX ] 02 50 38.A6.13 38.FF.95 23 11 77 LTONRR (77) Fri 12/25/2015 10:23:59 AM : [std-Direct Ack] 38.A6.13-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Fri 12/25/2015 10:23:59 AM : [iNST-SRX ] 02 50 36.A6.77 38.FF.95 4B 11 01 LTONRR (01) Fri 12/25/2015 10:23:59 AM : [std-Cleanup ] 36.A6.77-->ISY/PLM Group=1, Max Hops=3, Hops Left=2 Fri 12/25/2015 10:23:59 AM : [D2D EVENT ] Event [36 A6 77 1] [DON] [0] uom=0 prec=-1 Fri 12/25/2015 10:23:59 AM : [ 36 A6 77 1] DON 0 Fri 12/25/2015 10:23:59 AM : [D2D-CMP 001A] CTL [36 A6 77 1] DON op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Fri 12/25/2015 10:23:59 AM : [ Time] 10:24:00 0(0) Fri 12/25/2015 10:24:00 AM : [iNST-SRX ] 02 50 36.A6.77 11.01.01 CF 06 00 (00) Fri 12/25/2015 10:24:00 AM : [std-Group ] 36.A6.77-->11.01.01, Max Hops=3, Hops Left=3 Fri 12/25/2015 10:24:00 AM : [iNST-INFO ] Previous message ignored. Fri 12/25/2015 10:24:00 AM : [iNST-TX-I1 ] 02 62 38 A6 13 0F 11 77 Fri 12/25/2015 10:24:00 AM : [iNST-SRX ] 02 50 36.A6.77 11.01.01 CF 06 00 (00) Fri 12/25/2015 10:24:00 AM : [std-Group ] 36.A6.77-->11.01.01, Max Hops=3, Hops Left=3 Fri 12/25/2015 10:24:00 AM : [iNST-INFO ] Previous message ignored. Fri 12/25/2015 10:24:00 AM : [iNST-ACK ] 02 62 38.A6.13 0F 11 77 06 LTONRR (77) Fri 12/25/2015 10:24:00 AM : [iNST-SRX ] 02 50 38.A6.13 38.FF.95 2F 11 77 LTONRR (77) Fri 12/25/2015 10:24:00 AM : [std-Direct Ack] 38.A6.13-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
  14. I have 2 scenes that have this issue that I know of. Lately they have both been missing a device or 2 when the scenes are called by motion but if you hang out long enough to trigger another motion, it eventually comes on and some times it works as it should. I have rebooted the isy and it didn't help. Is there any way I can see why this maybe happening? thanks
  15. I factory reset it, removed it and readded it. seems to be turning off now. weird
  16. because it is the only program that calls kitchen motion 2. if 2 can't run on its own due to being disabled. something is making the If run. must be the sensor on/off status and it is checking after enabling it or so it seems.
  17. i enabled the program from the isy across the house way after a 5 minute window. I think the motion sensor is stuck "on" status maybe. it shuts off the light after x minutes though but the console always says on. so maybe after enabling it, it says hey motion is on. go to then.
  18. Actually what I think is happening is that the program becomes enabled, runs the If, finds that the motion sensor is "on" and then goes on. I have another motion sensor and it says off but this one always says on. it has a 1 min timeout but never seems to say off.
  19. The find found just the Kitchen Motion 1 which calls the kitchen 2 upon motion. . I was testing some more and found that If the kitchen 1motion is disabled and then enabled, it runs the "then" which fires kitchen2. (unless it is running the if and thinking motion was detected which it shouldn't be) I canreplicate this issue. Why would enabling a program cause it to run? there is no motion in the kitchen when enabling it. Is it skipping the if and running the then? Any way to capture the logs to see if this is what is happening? Kitchen Motion 1 - [iD 001A][Parent 0014][Not Enabled] If Control 'Kitchen / Motion-Sensor' is switched On Then Run Program 'Kitchen Motion 2' (If) Else - No Actions - (To add one, press 'Action') xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx Kitchen Motion 2 - [iD 0013][Parent 0014][Not Enabled] If Status 'Living / Living Room Lights' is not Off Then Set Scene 'Kitchen / Kitchen Lights' On Wait 5 minutes Set Scene 'Kitchen / Kitchen Lights' Off Else Set Scene 'Kitchen / ~Kitchen Cabs' On Wait 5 minutes Set Scene 'Kitchen / ~Kitchen Cabs' Off
  20. here is a event viewer on 3 starting from an OFF to the living room lights. Tue 12/08/2015 01:07:00 PM : [iNST-TX-I1 ] 02 62 38 8E 0E 0F 13 00 Tue 12/08/2015 01:07:00 PM : [iNST-ACK ] 02 62 38.8E.0E 0F 13 00 06 LTOFFRR(00) Tue 12/08/2015 01:07:00 PM : [iNST-SRX ] 02 50 38.8E.0E 38.FF.95 2F 13 00 LTOFFRR(00) Tue 12/08/2015 01:07:00 PM : [std-Direct Ack] 38.8E.0E-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Tue 12/08/2015 01:07:00 PM : [D2D EVENT ] Event [38 8E E 1] [sT] [0] uom=0 prec=-1 Tue 12/08/2015 01:07:00 PM : [ 38 8E E 1] ST 0 Tue 12/08/2015 01:07:00 PM : [D2D-CMP 0013] STS [38 8E E 1] ST op=6 Event(val=0 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> false Tue 12/08/2015 01:07:00 PM : [D2D-CMP 0008] STS [38 8E E 1] ST op=6 Event(val=0 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> false Tue 12/08/2015 01:07:00 PM : [D2D-CMP 000E] STS [38 8E E 1] ST op=6 Event(val=0 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> false Tue 12/08/2015 01:07:00 PM : [D2D-CMP 0010] STS [38 8E E 1] ST op=6 Event(val=0 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> false Tue 12/08/2015 01:07:00 PM : [D2D EVENT ] Event [38 8E E 1] [RR] [27] uom=0 prec=-1 Tue 12/08/2015 01:07:00 PM : [ 38 8E E 1] RR 27 Tue 12/08/2015 01:07:00 PM : [All ] Writing 1 bytes to devices Tue 12/08/2015 01:07:00 PM : [38 8E E 1 ] Memory : Write dbAddr=0x0021 [1B] cmd1=0x2E cmd2=0x00 Tue 12/08/2015 01:07:01 PM : [iNST-TX-I2CS] 02 62 38 8E 0E 1F 2E 00 01 05 1B 00 00 00 00 00 00 00 00 00 00 B1 Tue 12/08/2015 01:07:01 PM : [iNST-ACK ] 02 62 38.8E.0E 1F 2E 00 01 05 1B 00 00 00 00 00 00 00 00 00 00 B1 06 (00) Tue 12/08/2015 01:07:01 PM : [iNST-TX-I1 ] 02 62 00 00 2D CF 11 00 Tue 12/08/2015 01:07:01 PM : [iNST-ACK ] 02 62 00.00.2D CF 11 00 06 LTONRR (00) Tue 12/08/2015 01:07:01 PM : [Ext MH ] Unexpected Ack imCmd=62 cmd1=LTONRR 0x11 Tue 12/08/2015 01:07:01 PM : [iNST-SRX ] 02 50 38.8E.0E 38.FF.95 2F 2E 00 (00) Tue 12/08/2015 01:07:01 PM : [std-Direct Ack] 38.8E.0E-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Tue 12/08/2015 01:07:06 PM : [iNST-TX-I2CS] 02 62 38 8E 0E 1F 2E 00 01 05 1B 00 00 00 00 00 00 00 00 00 00 B1 Tue 12/08/2015 01:07:06 PM : [iNST-ACK ] 02 62 38.8E.0E 1F 2E 00 01 05 1B 00 00 00 00 00 00 00 00 00 00 B1 06 (00) Tue 12/08/2015 01:07:07 PM : [iNST-SRX ] 02 50 38.8E.0E 38.FF.95 2F 2E 00 (00) Tue 12/08/2015 01:07:07 PM : [std-Direct Ack] 38.8E.0E-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
  21. I don't have that many programs what do you mean with FInd?
  22. I was under the impression that if you disable a program it can't run on its own. I have a motion #2 program that is disabled but still runs the else. Is this by design or am I missing something? This program is disabled but runs the else when I turn off the living room lights. But when I turn the living room lights on, it doesn't trigger the "then" Kitchen Motion 2 - [iD 0013][Parent 0014][Not Enabled] If Status 'Living / Living Room Lights' is not Off Then Set Scene 'Kitchen / Kitchen Lights' On Wait 5 minutes Set Scene 'Kitchen / Kitchen Lights' Off Else Set Scene 'Kitchen / ~Kitchen Cabs' On Wait 5 minutes Set Scene 'Kitchen / ~Kitchen Cabs' Off Is this by design? I thought if it was disabled it would not run with triggers unless something told it to run from a program.
  23. I was thinking an else if would do it which is essentially what you have there. 2 programs will also do it. Just trying to make sure I wasn't missing something easy. thanks
  24. Is there a way or a better way to do this with 1 program? It works but it also triggers on time events as false due to the motion not being triggered but the time changed. motion sensor on a fan/light on an fanlinc day- motion triggers fan only. night - motion triggers light and fan. If 1.5 hr from sunset to sunrise next day. and control motion sensor is on. then set outside fan on set outside lights on wait 5 min set outside fan off set outside lights off Else set outside fan on wait 5 min set outside fan off
  25. haha that is pretty funny. I went to the extreme to test a theory and I went a bit too far. That doesn't make sense from a UI perspective. why not take that out ? or is that the point if for some reason you want to ignore the ramp rate.
