polo2883
  1. I was usig the old IoX user, all set.
  2. I cant seem to login with my admin user. It keeps saying
  3. Wow, ISY support is quick. All set
  4. I updated the EISY, and now the IoX launcher cannot find it. I tried adding https://eisy.local:8443/desc and it says not found. I can ssh to the IP and login with the admin account so I know the device is up. But I am lost where to go from here.
  5. Thanks for the advise. A restore of the switches worked.
  6. Fri 03/22/2024 09:53:32 PM : [ Time] 21:53:32 1(0) Fri 03/22/2024 09:54:01 PM : [D2D EVENT ] Event [n003_controller] [CPW] [958] uom=73 prec=0 Fri 03/22/2024 09:54:01 PM : [n003_controller ] CPW 958 (uom=73 prec=0) Fri 03/22/2024 09:54:02 PM : [ Time] 21:54:02 1(0) Fri 03/22/2024 09:54:25 PM : Create REST U7 [/rest/nodes/51%20F8%20DB%201/cmd/DON] Fri 03/22/2024 09:54:25 PM : U7 Rest: submitCmd([51 F8 DB 1],[DON],[<NULL>]) Fri 03/22/2024 09:54:25 PM : [INST-TX-I1 ] 02 62 51 F8 DB 0F 11 FF Fri 03/22/2024 09:54:25 PM : [INST-ACK ] 02 62 51.F8.DB 0F 11 FF 06 LTONRR (FF) Fri 03/22/2024 09:54:25 PM : [INST-SRX ] 02 50 51.F8.DB 34.E7.24 2F 11 FF LTONRR (FF) Fri 03/22/2024 09:54:25 PM : [Std-Direct Ack] 51.F8.DB-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Fri 03/22/2024 09:54:25 PM : [D2D EVENT ] Event [51 F8 DB 1] [ST] [255] uom=100 prec=0 Fri 03/22/2024 09:54:26 PM : [51 F8 DB 1 ] ST 255 (uom=100 prec=0) Fri 03/22/2024 09:54:27 PM : Create REST U7 [/rest/nodes/51%20F8%20DB%201/cmd/DOF] Fri 03/22/2024 09:54:27 PM : U7 Rest: submitCmd([51 F8 DB 1],[DOF],[<NULL>]) Fri 03/22/2024 09:54:27 PM : [INST-TX-I1 ] 02 62 51 F8 DB 0F 13 00 Fri 03/22/2024 09:54:27 PM : [INST-ACK ] 02 62 51.F8.DB 0F 13 00 06 LTOFFRR(00) Fri 03/22/2024 09:54:27 PM : [INST-SRX ] 02 50 51.F8.DB 34.E7.24 2F 13 00 LTOFFRR(00) Fri 03/22/2024 09:54:27 PM : [Std-Direct Ack] 51.F8.DB-->ISY/PLM Group=0, Max Hops=3, Hops Left=3 Fri 03/22/2024 09:54:27 PM : [D2D EVENT ] Event [51 F8 DB 1] [ST] [0] uom=100 prec=0 Fri 03/22/2024 09:54:27 PM : [51 F8 DB 1 ] ST 0 (uom=100 prec=0) Fri 03/22/2024 09:54:32 PM : [ Time] 21:54:32 1(0) Thats from the event viewer. I turned the fan on from the switch and the app and IoX shows off. Tapped on the fan in the app and the status updated to on. Tap it again and it turned off.
  7. The logs just show: I went into the room and the lights were on. The app showed it was off. Turned off the light then back on and the app never updated the status. I even relaunched the app. Looks like the two entries there are when I turned the light on and off from the app. Did not register any of the physical on and offs from the switch itself.
  8. If that device status does not update, I dont think re-creating the scenes will help. Right now if the garage door is open, the app and IoX shows its closed. I have to manually trigger a query and then it will update the status to show its open. Or I just have to tap the icon twice.
  9. Yes, its showing the wrong status on both UDM App and iox. I am using the same PLM I had with my ISY. As of now, it will show the master bedroom fan on but it actually is not. I have to tap it twice if I wanted it on.
  10. I upgraded my old 994i to eisy. Since the upgrade, my insteon device status is usually not accurate when I one the UD app. It might show the fan controller on but it actually off. My garage door sensor doesnt update the status so it wont trigger the garage lights to come on. Is this something that is a known issue?
  11. polo2883 replied to polo2883's topic in ISY994
    How do I switch out of latching mode? edit: Found the settings in option. Do I want Momentary C: Trigger based on sensor input?
  12. polo2883 replied to polo2883's topic in ISY994
    From the manual I connected it to terminal 3&4.
  13. polo2883 replied to polo2883's topic in ISY994
    Yup I basically just shoved the two wires from the IOLinc into the same terminals in the unit itself.
  14. polo2883 replied to polo2883's topic in ISY994
    I connected the wires to the same terminals as where the wall button is connected to.
  15. polo2883 replied to polo2883's topic in ISY994
    So I finally got around to putting the extender in. I am now able to detect the IOLinc. But when I try to tie it to my garage door opener, using the same terminals as the wall opener, It does not work. It actually makes the wall opener stop working as well. Here is the link to the opener I have: http://lib.store.yahoo.net/lib/yhst-16416632405890/Sommer-Opener-manual.pdf
