n8ur9irl
  1. I have eisy Iox 5.6.2. Upgrading Polyglot Version 3x 3.1.36. I get message to restart but i cant get it to update. What is the correct way to restart it? I rebooted the eisy. l Logged out and logged back in to Polyglot.
  2. I restarted the eisy and it worked. phew!
  3. I updated PG3 and lost the iox finder. Tried running a new launcher. then In IoX Launcher, click on the Add button Enter https://192.168.1.122:8443/desc into the dialog. Note 192.168.1.122 is an example. You should use the IP address for your eisy. Click on the OK button still not working says not found
  4. I can report the light is not coming on during the day now.
  5. do I remove the parking pad light from my sunset program? or is it okay to have it in both programs?
  6. The light i am working with is the parking pad light only. So should i forget using the sunset program and just make a new program like you showed? Right?
  7. Im using an insteon motion sensor II for the program. even after the change to the only at night it didnt help . i did the search and it didn't come up with any thing else. I did change the timing Parking Pad Light - [ID 000D][Parent 0001][Run At Startup] If From 8:15:00PM To Sunset (next day) And 'Outdoor / Parking Pad Sensor.1 Motion' is switched On Then Set 'Outdoor / Parking Pad' Fade Up Wait 5 minutes Run Program 'Outdoor Lights' (Then Path) Else - No Actions - (To add one, press 'Action') Outdoor Lights - [ID 0025][Parent 0001][Run At Startup] If From Sunset + 1 hour To Sunrise - 1 hour (next day) Then Set 'Sunrise' On Else Set 'Sunrise' Off
  8. I meant night only.
  9. Yes i do want the motion switch to activate all night. We are in the country with bears. 😗 Thank you Geddy for the program advice I changed some other multiple folders to 1 on/off. One thing I am having a problem with the outdoor lights is that the 100% is activating in the daytime also. I have the scheduled times in "If" and I also changed the motion sensor to day only. See anything that would cause that Parking Pad Light - [ID 000D][Parent 0001] If From Sunset To 11:45:00PM (same day) And 'Outdoor / Parking Pad Sensor.1 Motion' is switched On Then Set 'Outdoor / Parking Pad' On 100% Wait 5 minutes Run Program 'Outdoor Lights' (Then Path) Else - No Actions - (To add one, press 'Action')
  10. so if i want it to return to the original 35% do i still need to put the "else" in? thanks for the copy trick! Parking Pad Light - [ID 000D][Parent 0001] If From Sunset To 11:45:00PM (same day) And 'Outdoor / Parking Pad Sensor.1 Motion' is switched On Then Set 'Outdoor / Parking Pad' On 100% Wait 5 minutes Run Program 'Sunset' (Then Path) Else - No Actions - (To add one, press 'Action')
  11. Thank you I also added that i want it between the hours Sunset and 12:00
  12. Ohhhhh! I think i understand. that what I am changing is not temporary but every time i I turn it on at the switch, right? I fixed it to
  13. Im not clear on what you are saying. Sunset comes on and the parking area is 35% and when motion is detected I want it to be 100% so how would i write it correctly? How would that look? Thanks
  14. Thanks I will try that. I didnt know what information was needed. My sunset program turns all the out door lights on at sunset off at sunrise. I added the 2nd program like this: is that right? thank you for the help!
  15. I have Eisy 5.5.9 and i need some direction writing a program for my outdoor parking area. The parking area comes on at sunset everyday at 35% and i would like it to have it brighten to 100% when motion is triggered then dim back down to 35% after 5 minutes. Could someone give me some pointers please? Thanks
