gages97
Everything posted by gages97
  1. gages97 replied to TAH's topic in eisy
    I purchased an RTI driver from this guy a long time ago and it still works w/ my EISY setup https://www.coupeautomation.com/mm5/merchant.mvc?Screen=PROD&Store_Code=C&Product_Code=ISYXDS&Attributes=Yes&Quantity=1 From a button on the RTI i can call an EISY scene for lighting
  2. UD fixed my issue on the backend. All working properly now.
  3. Same thing happened today. Opening a ticket
  4. I am not logged into the portal. We shall see what happens tmrw when my weekly notification comes in. For now I have deleted all notifications in the app.
  5. on Sat morning - I get a test alert - so will document what happens
  6. for me, the count reverts back to the big number, after a new notification is received. So I clear out notifications, get a new notification, it shows the big number on the app icon, until I go into the app itself, then it gets corrected.
  7. I have the same issue
  8. I am having the same issue after upgrading to 1.1.61 and the prior version. Some of my favorites show fine, some take a few mins to update, and some don't at all but sometimes they do. Also my zwave devices take a long time to show properly.
  9. Mine are slow to respond, sometimes they all come back, sometimes they don't. Started happening after I upgraded the app to latest this evening.
  10. Seems to be working fine this morning for me.
  11. gages97 replied to bmercier's topic in UD Portal
    I think this is my issue
  12. I am having the same issue I opened ticket 23434 as a portal issue
  13. gages97 replied to bmercier's topic in UD Portal
    ok done. Anyone else experiencing the same issue?
  14. gages97 replied to bmercier's topic in UD Portal
    same issue again - 2 minutes later
  15. gages97 replied to bmercier's topic in UD Portal
    ok reboot seemed to do the trick - will report back if any issues
  16. gages97 replied to bmercier's topic in UD Portal
    ok I was able to log in remotely and hit the reboot button - let's see
  17. gages97 replied to bmercier's topic in UD Portal
    it came back last time (a few hrs ago w/o a reboot). Any way to reboot remotely?
  18. gages97 replied to bmercier's topic in UD Portal
    My unit was offline then online, now offline again as of 3:56PM EST. Unit is based in NY.
  19. Wait - its back! Maybe not a Unifi issue?
  20. I did not do any of the Unifi updates (mine are set to manual) and my eisy cannot access the portal.
  21. you have to open and save any network resources if you had any
  22. @Michel KohanimInteresting. I wonder if some networks are more sensitive on the discovery than others, but if on the same subnet should really matter.
  23. Curious, is there an doco on how the discovery process works? As in how does ISY/EISY advertise itself to the discovery service? I have been using ISY/EISY for 10+ years, the discovery works 99% of the time, but sometimes it doesn't and I have to manually add in the URL of the device.
  24. Make sure to disable the program, then do the run then from UD Mobile I have this for 2 garage doors.
  25. i do not have the notification node server installed. I am using network resources for notifications within programs Am I confusing what I am doing with "notifications"?
