Deane Johnson
  1. I have my Portal back, but when I try to have it connect to Alexa, it messages me the ISY is not on line. Everything else about eisy seems to work normally. (Programs, Administrative Console, etc.)
  2. Still down in Omaha. Hopefully will hear something soon from UDI.
  3. Thanks everyone for the enlightenment. You saved me a lot of hassle. As "they" say, knowledge is king.
  4. The title says it all. I'm wondering if anyone has found one. I have a need and haven't been able to locate one. I'm building my Z-Wave network for use with my new eisy.
  5. Thank you Guy for your response. It did the job of getting me focused on what would work best. You did a great job putting the whole thing in perspective with only a few words.
  6. I've used the ISY 994i for about 15 years with my Z-Wave with total joy. I recently had some sort of powerline glitch that took out my router and apparently took out my ability to connect ISY to Alexa. This indicates it's time for me to move ahead. I'm seeking opions on what I need to purchase from UDI to do the same Z-Wave installation as I had before, but of course updated to a new model. I just do lighting. No door locks, no sensors. I use the ISY built in timers to turn lights on and off at specific times, and also use Alexa to control lighting as desired. I'd also probably like to use some sort of mobile screen, perhaps the one from UDI. I have no need to communicate from outside of my home. No mobile use whatsoever. The sort of questions I could use your thoughts on would be something on the order as to whether or not the new devices are as good as the exceptional ISY 994i with Z-Wave. My Z-Wave with the 994i was so stable I can't think of a single shortcoming it had in 15 years of usage. Hopefully, this gives you a picture of my rather simple requirements. I'm not a technical guy or a programmer, but I didn't have need to be with the ISY 994i. I'm hoping to duplicate that simplicity and stability. Thanks for anything you can offer. I'm ready to order. I should also mention that I use Leviton Z-Wave components of varying age exclusively.
  7. I've had enough time to not only check things, but observe performance. All of the Programs executed on time as expected. I also checked and the DHCP has always been on automatic, and remains there. I repeatedly looked at varous parts of the software, and everything was in place as it has always been. The only thing that gltiches is trying to activate the Connect to Alexa and that's when the No data pop-up happens. One thing that got messed up is that I followed the directions to do a factory reset on the ISY. It went according to plan, but the ISY no long executes the Programs on the scheduled time. I think I've had time to conclude that it's time for me to abandon ISY and move on to something else. At my age of 90, it's no longer practical to fight the battels described in this thread. I only use ISY for a controller for Z-Wave lighting. I also separelty use Hue for lighting, which works very well. It's a simple task for me to replace the bulbs with Hue and simply expand that. I didn't want to bail out of this without an explantion. I continue to believe that the UDI products are the most reliable and professional on the market, they just need a person a little younger than 90 to deal with issues. Thanks for your help.
  8. I've been down with a bad case of the flu. I'll respond to the Geddy post tomorrow (Sunday). Please don't close.
  9. Installed a new Asus RT-AX58U Wi-Fi 6 router. My previous router had been connected to ISY for years with no issues ever. In the Portal drop down I'm shown as resistered and Online. The registration name is correct, and has been used for years on that form. When I bring up my.isy.io in my browser it shows the correct UUID entry along with my Alias that shows in the Portal drop down form. Everything so far looks correct. The trouble starts when I click on the "Select Tool . . . button to select Connectivity and then Amazon Echo. It brings up the Amazon Echo Device List form. In the heading it shows the correct UUID entry and the correct Alias that appears in the software Portal dropdown form. However, this is where the trouble starts. The bottom line has the notation "No data available in table". The blue rectangle at the bottom of the form says "Showing 0 to 0 of 0 entries" This is where I am stopped. Any suggestions on how to get this to connect to the LAN will be appreciated. By the way I believe the router is a dual band.
  10. Javi, good to have you in the communication loop. My only goal is to get back to where I was before I lost my Z-Wave. Too be clear, I'm not a tech guy. I'm 88 years old, and can't remember crap. I live alone, run my own company, and have 5 PC running in my home 24/7, 3 iPads, an MS Surface and a new Lenova Verizon Laptop. I do this with limited knowledge and even less memory (human). In the case of my issue at hand, I can only relay what happened in front of me to the best of my knowlege. I want to be as clear as possible with the facts as I remember them. The ISY is around 10 years old, so it was not shipped with 5.3.0. It's been running with 4.x.x until when this occured. It has been my Z-Wave Controller for all that time, and worked very well with Alexa. Glitches just never happened. The ISY has been solid as a rock in my use. I saw the promotion for UD Mobile and thought I should look at it. I've been using CQC for a number of years and now that it's bitten the dust, I'm looking for something else to control my home automation. That's why I was downloading it to my iPad Pro while sitting in an adjoining room away from the ISY. In the process of downloading UD Mobile, the notice flashed that UD Mobile couldn't complete the installation with ISY without a firmware update. I clicked the go ahead button. As it proceeded, within seconds it flashed that it could not complete the installation of the 5.3.0 and closed out of it. I then moved to the ISY and discovered all of my Z-Wave programming was gone, but later tried a direct firmware update and got flagged that it has an incomplete 5.3.0 firmware installation and it couldn't continue. That's the point when I began this thread to simply find out how to revert back to my previous firmware and once again have my Z-Wave functioning. At this point, I have no idea how to move ahead, or what version firmware should be installed in my ISY. Deane
  11. Actually, it has changed. Finder is showing the new version in the ISY is 5.3.0. UD Mobile indicated it needed to change or UD Mobile couldn't access it the ISY. I clicked the button and it proceeded. The end result is that 5.3.0 is in my ISY, I got a reply at one point it was not workable in my IZY and it indeed isn't. That is verified by the drop down box in the Administratikon Console now indicating that the Z-Wave dongle is not working.
  12. OK, some advancement. I had a 7.5v @ 1 amp power supply that fit the socket, so I tried that . It appeared the lighting came up normal, the lights for the eithernet feed began normal flashing, and nothing smoked. Fing Software showed the ISY alive and at the same URL as before. I then got iox Finder loaded on another computer (I have 3 PC's all located together). Finder came up normal and connected to the ISY. Type: ISY994i Version: 5.3.0 The old Version number had a 4. as the first number. The Administration Console opened normally. The z-Wave dropdown shows the "Z-Wave dongle not responding". That's a result of the wrong Firmware, I'm certain and something I expected. It also shows all of my programming gone, which I also expected. I guess what I need now is to find out how to get the earlier Firmware version back in so I have a normal functioning ISY to start rebuilding with. Deane
  13. Techman, you mentioned the 12v. power supply in your post. I note that the PS it's been running on, which is most likely the original supplied with the ISY, is 5v.
  14. I may have called the iPad software by the wrong name. I believe this was new software from UDI that showed up on the site promoting it's introduction. I still have the mobile software on my iPad Pro. It's called UD Mobile. Version 0.0.9 It's on this page, toward the bottom. Large photo of the screen. https://www.universal-devices.com/#cloud In addition to the Power led light blinking at 1 second intervals, there is a small led on the back that also blinks at the same time. The Leds on the eithernet socket are not blinking. I will go through my box of power supplies and see if I have one that will work to substitute.
  15. I cleared the Java cache and have the ISY Finder open, but it's still blank since it isn't yet communicating with the ISY. I have previously unplugged the ISY and removed in from the Ethernet. When I plugged it back in, it just sits there, the left hand blue light blinking about once per second. I tried a complete reset, but that didn't change anything. So, I've got my work cut out for me heading into the weekend. I'm not a computer tech guy, so I just have to keep hammering away until I find things. The response on the forum are very helpful. I'm suspicious that there is currently no firmware in the ISY so it's just searching thin air for something that isn't there. Deane
