rlav
Everything posted by rlav
  1. LeeG, A couple of week later, time to troubleshoot, to order, and to replaced the defective X10 PSC-04 module. Everything is working fine. Thank You, Robin
  2. I just replaced my ISY 99i for the 994i. Everything seems to work fine until I discover X10 receiving issue. I follow the recommended process. Downgrade the new ISY (994i) to latest 99i firmware. Restore from backup. Upgrade to 4.2.4. Transfer the modules (Weather, Networking, A10/X10) to the new 994i. ISY is able to send X10 messages. I see the messages in the Event Viewer. I have a few buzzers and the work fine. But ISY is not receiving X10 message. Nothing in the Event Viewer (level 3). My alarm system send X10 messages when doors are open and close. I have a X10 console to generate X10 message to confirm the problem in different home outlets. I upgrade to 4.2.5 this morning. Same problem. I suspected the PLM (2412S v85). Factory Reset and restore. Same problem. The PLM has 474 links. Total of 125 Insteon devices. I have a spare PLM (2412S v72) that I try. Factory Reset without a restore just to see X10 message. Still no X10 message. I also install the local power to 994i. With or without, same problem. Everything has been stable and fine for years with 99i. What else should I try? Do I have a defective PLM? Shall I reset and restore ISY? Thank you in advance for your help. Robin
  3. Updated from .13 to .14, no problem Robin
  4. No problem to upgrade from 2.8.11 to 2.8.13 following all the instructions. Robin L.
  5. Thank You Michel, I will communicate with support this week. Since I had to restore from Factory Reset for the first time, I notice a few configurations that did not restore from the backup. - Clock / Time Zone. I use custom location - System / Wait while busy and Send compact - SMTP Setting / I use custom setting Network settings, I use a static IP and the restore process asks before restoration. This is great. Robin L.
  6. Followed procedure. Upgrade from 2.8.11 failed. Only http://www.universal-devices.com/99i/2.8.12 works but to access the SLL Certificates mode. Factory Reset, Restore 2.8.11, Restore ISY from backup. I am back up and running. I initially try to restore 2.8.12 after the factory reset. It came back with 2.8.12 working. After reloading my backup, I was back to SSL Certificates. I started over again. Let me know what information you need to help troubleshoot the problem. Robin L.
  7. rlav replied to oskrypuch's topic in ISY994
    Rain Today is one of the field that is not working. Beside it is pretty cold today and we had some snow. All the fields with Rate, Light, and Rain do not work. R. Lavoie
  8. rlav replied to oskrypuch's topic in ISY994
    Yes it works from Canada, but with some limitation. I am locate in Montreal area. Here are the fields that I get. Those at 0 are not available. Temperature -7 °C Temperature High -4 °C Temperature Low -7 °C Feels Like -15 °C Temperature Rate 0 °C Humidity 73 % Humidity Rate 0 %/h Pressure 1011.18 Pa Pressure Rate 0 Pa/h Dew Point -11 °C Wind Speed 23 km/h Wind Average Speed 23 km/h Wind Direction NNE Wind Average Direction NNE Gust Speed 40 km/h Gust Direction NNE Rain Today 0 mm Light 0 %/h Light Rate 0 %/h Rain Rate 0 mm/h Max Rain Rate 0 mm/h R. Lavoie
  9. I did the upgrade, no problem with the download. I followed the 8 steps then tested a few scenes and programs. No issue so far. Robin L.
  10. Greak work Michel, Everything is back to normal running 2.8.4 with this latest version. Very hard to understand why anly a few of us had this problem. What is it that we have that is different? Thank You, Robin
  11. Hello Michel, I try the firmware only. It did not work. Try it again, samething. I reinstalled 2.8.4 completly. It did not work. I retried the firmware only twice. Samething, I can see the program folders. Just out of luck with this version. Let me know if you want to access remotely. Robin
  12. Hello Michel, Just upgraded to 2.8.4 from 2.8.2. Clear Java before restarting the console. - Good news; Current state is there, WeatherBug data is there, MobiLinc on iPad is working. Tested device on/ff via the console having the Event Viewer open. Triggered a program by changing the status of a SwitchLinc. This is fine. - Bad news; Impossible to access the Program Summary and Program Details folder via the console. The folder title does not even change, it remains Main or Configuration. Reboot the ISY, reboot my PC, clear Java, and try again. Same result, everything looks it is working fine, but impossible access the two Program folders. At least I don't need to downgrade. Thank You again, Robin
  13. Hi Michel, Just not stable. Console is back to no State and no Weatherbug. Programs are not running. Took me a few reboot to be able to downgrade back to 2.8.2. Thank you again, Robin
  14. Hello, Here is my results after upgrading from 2.8.2 to 2.8.4 since I had issues trying to upgrade to 2.8.3. I did the upgrade, no error message and clear Java. When I restarted the console, I got the username password twice from the console (plus once from Java before the console start) State of devices is not display. WeatherBug is empty. Event viewer level 3, try a query, nothing. From System folder, I reboot. Did not clear Java. I restarted the console. Got the username password once (not from Java). Query at start is running. State of devices are visible. WeatherBug is ok. Event viewer level 3, try a query, working fine. Try to use MobiLinc on my iPad. State of devices, not visible. Try to sync with ISY, could not. Via previously open Console, try a query again. Error Message: [-5011]Change of state failed: SID not found [uuid] Try the query again, working fine. Try to use MobiLinc, failed. Try to query from console, Request Failed. Look at the log in Excel. It looks like the Query at restart did work the first time even if there was not state result in the console. Waiting for further instruction to try to debug this. More than 100 devices on ISY. PLM v85. 4 modules (Open 010, Weather 020, Networking 040, A10/X10 060). Static IP address. Robin
  15. Michel. Yes, I am using a static IP address. Thank You for your support. Robin
  16. Michel, Yes I cleared the Java Cache. I just try to use the console mode again. All the Current State are now empty again. Got out and come back, same results. I then try Mobilinc on iPad without luck. No more access from console. I had to unplug the ISY to reboot. Back to console mode, samething. I try to downgrade, I got the error message. I reboot from the console, clear the Java Cache, try to downgrade to 2.8.2 and 2.8.1, error message. A few time after entering the username/password from the console, a few second later I get an Authenticate screen again while there are ! beside all devices list. I try to play with a simple scene with 2 devices, just On and Off. The lights react about 10 sec later. No Current State. Then I waited for 15 min with the console open, and try to downgrade again. I got it and I am back to 2.8.2 and working. Robin
  17. Hello, I try to upgrade this morning from 2.8.2 to 2.8.3 and had some issues. The first try I got an error message toward the end "Upgrade Failed :Failed uploading file (reported written size is invalid). I then reboot the ISY and try again. This time the upgrade is complete. I did not run the backup this time, if this could have an impact. Usually, after the ISY restart, the "Query at restart" is visible. This time nothing was visible but the interface was very slow. I assume the Query was running in the background. Stange also that 2 of my KeypadLinc (2486D) status are not reported. I then reboot again. This time the query is visible at restart. I got the disclaimer message and all my KP are reported properly. Look like everything is back to normal. I will let you know if this change. RLav
  18. rlav replied to Steven's topic in ISY994
    I have a similar program. It works but you will need to isolate to two sections like this: If ( Time is Sunset + 30 minutes And From 7:00:00PM To 11:59:00PM (same day) ) Or ( Time is 7:00:00PM And From Sunset + 30 minutes To 11:59:00PM (same day) ) Then Set 'Dining Room' On Else - No Actions - (To add one, press 'Action') RLav
  19. On my side I use a mix of dry contacts and X-10 from the alarm system. Dry contacts for the system states (Away, Stay, Disarm). Those are connected to EZIO6I. Not perfect, since there is a bug with the query of EZIO6I, but On to Off and Off to On are reported properly for me. (thanks to the Universal Devices' team) X-10 for doors and windows. I did not enable X-10 for motion sensor since it generates too much traffic from the alarm system. This enables many possibilities. If I open the patio door after the sunset with the alarm set off, the patio light will come On. RLav
  20. Michel, I upgraded to 2.7.11 without any issue so far. EZIO6I is working fine. I will keep you posted if I find anything. Merci Beacoup, RLav
  21. Michel, I went back to 2.7.7 from 2.7.10. I did not reload the old backup from 2.7.6. My EZIO6I connect to my alarm system is working as before with 2.7.6. Normal operation is recorded in ISY as before. Query is not working as before (this is not a problem for my confirguration). I tested adding my spare EZIO6I. I got the same error message as with 2.7.10 posted before: [-200000] Node not added - failed restoring device [1 70 EF 1] [-100002] Couldn't open file [/CONF/170EF.REC] Here is the log: Sun 01/31/2010 03:00:04 PM : ---- Initializing the linked devices ---- Sun 01/31/2010 03:00:04 PM : ---- All Linked Devices are now initialized ---- Sun 01/31/2010 03:00:04 PM : ---- Add remaining devices ---- Sun 01/31/2010 03:00:04 PM : [ 1 70 EF 1] Removing all links Sun 01/31/2010 03:00:42 PM : [1 70 EF 1] i2 data transfer commands do not work. Reverting to i1 Sun 01/31/2010 03:00:44 PM : [ 1 70 EF 1] Adding device to ISY Sun 01/31/2010 03:00:44 PM : [test - 9] Start : Adding device to ISY Sun 01/31/2010 03:01:24 PM : [1 70 EF 9] i2 data transfer commands do not work. Reverting to i1 Sun 01/31/2010 03:01:26 PM : [test - 9] Finish : Adding device to ISY was Successful Sun 01/31/2010 03:01:36 PM : [test - 9] Making PLM a Responder to group 9 Sun 01/31/2010 03:01:47 PM : [test - A] Start : Adding device to ISY Sun 01/31/2010 03:01:47 PM : [test - A] Finish : Adding device to ISY was Successful Sun 01/31/2010 03:01:48 PM : [test - A] Making PLM a Responder to group 10 Sun 01/31/2010 03:01:58 PM : [test - B] Start : Adding device to ISY Sun 01/31/2010 03:01:58 PM : [test - B] Finish : Adding device to ISY was Successful Sun 01/31/2010 03:01:59 PM : [test - B] Making PLM a Responder to group 11 Sun 01/31/2010 03:02:08 PM : [test - C] Start : Adding device to ISY Sun 01/31/2010 03:02:08 PM : [test - C] Finish : Adding device to ISY was Successful Sun 01/31/2010 03:02:09 PM : [test - C] Making PLM a Responder to group 12 Sun 01/31/2010 03:02:19 PM : [test - D] Start : Adding device to ISY Sun 01/31/2010 03:02:19 PM : [test - D] Finish : Adding device to ISY was Successful Sun 01/31/2010 03:02:19 PM : [test - D] Making PLM a Responder to group 13 Sun 01/31/2010 03:02:29 PM : [test - E] Start : Adding device to ISY Sun 01/31/2010 03:02:29 PM : [test - E] Finish : Adding device to ISY was Successful Sun 01/31/2010 03:02:29 PM : [test - E] Making PLM a Responder to group 14 Sun 01/31/2010 03:02:39 PM : [ 1 70 EF 1] ** Not Added ** Restore node Failed Sun 01/31/2010 03:02:39 PM : ---- All Remaining Device Added ---- Even if there were some errors, the test unit is working. Thank you, RLav
  22. Michel, I upgraded from 2.7.9 to 2.7.10 succesfully. But I still have the same problem with EZIO6I. I have a spare unit that I know was working that I also try. I needed to add it to ISY. I got the following error message: [-200000] Node not added - failed restoring device [1 70 EF 1] [-100002] Couldn't open file [/CONF/170EF.REC] Here is the Log: Fri 01/29/2010 06:23:25 PM : ---- Initializing the linked devices ---- Fri 01/29/2010 06:23:25 PM : ---- All Linked Devices are now initialized ---- Fri 01/29/2010 06:23:25 PM : ---- Add remaining devices ---- Fri 01/29/2010 06:23:25 PM : [ 1 70 EF 1] Removing all links Fri 01/29/2010 06:24:04 PM : [1 70 EF 1] i2 data transfer commands do not work. Reverting to i1 Fri 01/29/2010 06:24:05 PM : [ 1 70 EF 1] Adding device to ISY t=07.07.0000 Fri 01/29/2010 06:24:05 PM : [test - 9] Start : Adding device to ISY Fri 01/29/2010 06:24:44 PM : [1 70 EF 9] i2 data transfer commands do not work. Reverting to i1 Fri 01/29/2010 06:24:45 PM : [test - 9] Finish : Adding device to ISY was Successful Fri 01/29/2010 06:24:46 PM : [test - A] Start : Adding device to ISY Fri 01/29/2010 06:24:46 PM : [test - A] Finish : Adding device to ISY was Successful Fri 01/29/2010 06:24:46 PM : [test - B] Start : Adding device to ISY Fri 01/29/2010 06:24:46 PM : [test - B] Finish : Adding device to ISY was Successful Fri 01/29/2010 06:24:47 PM : [test - C] Start : Adding device to ISY Fri 01/29/2010 06:24:47 PM : [test - C] Finish : Adding device to ISY was Successful Fri 01/29/2010 06:24:47 PM : [test - D] Start : Adding device to ISY Fri 01/29/2010 06:24:47 PM : [test - D] Finish : Adding device to ISY was Successful Fri 01/29/2010 06:24:47 PM : [test - E] Start : Adding device to ISY Fri 01/29/2010 06:24:47 PM : [test - E] Finish : Adding device to ISY was Successful Fri 01/29/2010 06:24:47 PM : [ 1 70 EF 1] ** Not Added ** Restore node Failed Fri 01/29/2010 06:24:47 PM : ---- All Remaining Device Added ---- Fri 01/29/2010 06:24:47 PM : [ 1 70 EF 9] ST 0 Fri 01/29/2010 06:24:47 PM : [ 1 70 EF A] ST 0 Fri 01/29/2010 06:24:47 PM : [ 1 70 EF B] ST 0 Fri 01/29/2010 06:24:47 PM : [ 1 70 EF C] ST 0 Fri 01/29/2010 06:24:48 PM : [1 70 EF 9 ] Link 0 : 0FF8 [E2010FD840FF1F01] Writing [E2010FD840FF1F01] Fri 01/29/2010 06:24:56 PM : [PLM ] Group 1 : Writing Responder Link matching [1 70 EF 9 ] Link 0 : 0FF8 [E2010FD840FF1F01] Fri 01/29/2010 06:24:56 PM : [1 70 EF 9 ] Memory : Write dbAddr=0x0045 [0E] Fri 01/29/2010 06:24:57 PM : [1 70 EF 9 ] Memory : Write dbAddr=0x0044 [0D] Fri 01/29/2010 06:24:58 PM : [1 70 EF 9 ] Memory : Write dbAddr=0x0043 [0C] Fri 01/29/2010 06:24:59 PM : [1 70 EF 9 ] Memory : Write dbAddr=0x0042 [0B] Fri 01/29/2010 06:25:00 PM : [1 70 EF 9 ] Memory : Write dbAddr=0x0041 [0A] Fri 01/29/2010 06:25:01 PM : [1 70 EF 9 ] Memory : Write dbAddr=0x0040 [09] So now what should I do or try. Revert back to 2.7.6, 2.7.7, or 2.7.8? Will I need to reload a backup from 2.7.6? Or shall I wait for the fix in the next release? If the fix is only 1 or 2 weeks away, I can wait. Thank you again, RLav
  23. Here is the situation with my EZIO6I. I am using the 4 input ports to monitor the status on my alarm system. I have 4 output relays on my alarm that are connected with the EZIO6I: Port 1 is Alarm Stay Port 2 is Alarm Away Port 3 is Alarm Disarm Port 4 is Aralm Burglar With version 2.7.6 everything was working fine. Now with version 2.7.9, whatever the mode of my alarm system, I only have the Stay mode to On. To explain differently, the status of the 4 input ports on EZIO6I are reported as port 1. Should I try to load Alpha 2.7.10 or revert back to previous version? Thank you for your help.
  24. Hello, Sorry if this has been reported. Running 2.7.9, I have a problem with the EZIO6I. Whatever input port is closed it always reports as port 1 being use. Thu 01/28/2010 06:12:34 PM : [ 1 70 FD 9] DON 0 Thu 01/28/2010 06:13:37 PM : [ 1 70 FD 9] DOF 0 I was running 2.7.6 for a long time without this problem. Thank You, RLav
  25. Hello, I use the Trend tool regularly, in particular to quickly analyse the Status of device. But I still don’t understand the logic involve in the “Choose – By Scene/Deviceâ€. They are never in a good sorting order. Is this something that could be fixed? For deeper analysis, I use the Log file in Excel. By adding extra column to properly get the date and time, I can get all the pivot table and chart that I need. Thank you, RLav
