RonnieB
  1. Thanks Paul, You have been very helpful. Ron
  2. Hello, I am attempting to add several Insteon Devices to my Eisy. There are no identifying addresses on the Insteon Devices and there are no "Set Buttons". How can I add these devices without a device address or set button? Thank You
  3. Hi Dennis, Yes the PDF refers to a "set button" which is non-existent on any of my Insteon Devices. That's my problem. How to add an Insteon Device to my Eisy without a "set button".
  4. Specifically: #2473 Receptacle #2663-2 Double Receplace, each plug switched
  5. Wall receptacle with upper switched and lower on all the time.. Has an on/off switch but nothing else. Also the double receptacle, individually switched.
  6. Hi Again, I've decided to abandon the X10 platform and convert to all Insteon. Tried everything I could and still no success, so goodbye. One problem I am having: How can I add an Insteon Device when there is no identifiable address? Also no "setup" button. Any ideas? Thanks again to all. Ron
  7. Thank you. I'm trying all things suggested and will report how it goes.
  8. No they did not. All Insteon devices work though so would not think that necessary.
  9. No. I replaced it as a result of the problem I am having. Universal Devices went through the process with me. They had no answers for me.
  10. No. Just finished. No response at plain x10 module. Tried same circuit and plug as PLM. I'm lost
  11. Did all the PLM items. Thank you for the help!
  12. Sorry, II am a rookie so lost in what you said. Not sure what you are asking about 2 HV/UC combinations. I have the devices installed and then turn them on or off with Eisy or UD Mobile. Nothing fancy, no scenes or anything else. Just direct on/off activation
  13. This is what I m getting on the Event Viewer. Not sure what it means. X-10 (B-3 FF 02 03 1) is the last thing I attempted to turn on.
  14. Hi Paul, installed a new PLM as per instructions on Wikileaks and from Universal Devices Support. No luck
  15. Hello, I have a blended system with INSTEON AND X-10 DEVICES. All were working fine together about a month ago. The Insteon devices do work with Eisy and UD Mobil. Now, no X-10 devices operate when signal is sent from Eisy unit. UD Mobil no longer works with X-10 as well. The X-10 hand held remote Does Work with the installed X-10 devices. Running Mac OS Sequoia 15.5. Have 15 Insteon devices and 12 X-10 devices installed. Eisy Version 5.9.1, OpenADR, Networking Module, Portal Integration, Z-Wave module. A10/X10 module. Any help or ideas to resolution available? Thank you, Ron
