Variables not Changing after update to 5.9.1
@Geddy, sorry for the long delay but yes, that did it. Since the last update I also simplified the house down to five different states. Because of the dual zone AC, I had 10 different states for energy savings. The longer we were gone the less the HVAC was on, and less lights that couldn't be seen from outside the house came on. That's my favorite trick btw is keeping the neighbors guessing when I am home. Since reducing the number of state variables in programs, that seemed to help with some other issues. If the IF statement had too many requirements, the program didn't always run. I verified the variables where correct, and after shrinking half of them and removing the checks from the IF, those scenes have worked correctly for the last two weeks. My wife set of the alarm and didn't tell me when she was late for work yesterday. I woke up to find some odd lights on. I thought I was back to some randomness issues. She manually turned off a few so the lights that were on made zero sense. One look at the log, and I realized the eisy was working correctly.
Family room lights rapidly flicker when dimmed
First Question, Do the led dim at all? You said you have to go to full brightness to get them to stop. Second, Brand of LED and how old? Older LED's don't like digital dimming, they were made for rotary resistance dimmers. The way you describe the problem, that isn't flickering that the eliminators can fix Third question: Are all of the bulbs on the switch the same brand, series and dimmable? Just one different bulb can kill the circuit sometimes due to differences in control circuits. I started testing LED bulbs with insteon and leviton switches in 2006 and many of the brands that don't work are somewhere in this forum. In the past four years I have only found one brand at Home Depot to be an issue, ecosmart, and some work, some don't so it isn't consistent for the brand. The newest eco smarts appear to be ok. The biggest cause of flickering as you describe it was caused by non-dimmable LED on an Insteon (or Leviton or Lutron) dimmer. Older dimmers were good down to 5 or 6 watts. In my office for example, I only use a 6 Watt LED on one of the lamps. With a non dimming bulb it flickers. Yes, I had the same problem when I upgraded to the i3 switches so I could get the engraved. And yes the Eliminator in the above post by @Brian H worked. I got lucky and the blue one worked first try. I have a patio light that is an 8 Watt LED on a single i3 switch and it had a slight glow all the time when the switch was off. That was fixed with the Flicker-Glow Eliminator. I installed the flicker-glow eliminator behind the patio lamp since there was no way it was fitting behind the switch in the box. Suggestions are first to try a different brand of dimmable LED bulb and make sure the load is at least 20 watts total, i.e. 4 x 5 watt bulbs. or 2 x 10 watt bulbs or more. Second is to try the flicker glow eliminators.
I just got around to updating to 5.9.1 as I try and find a way for the eisy to control my new "permanent" LED holiday lights by HYSRT. Yesterday the house didn't shift modes, I use three state variables, sNight, sEarly_Morning and sSunrise_Daytime. Most of the motion based automatic light scenes should not come on is sNight = 0 or sSunrise_Daytime = 1. The code is unchanged for several years, here is the sunrise one. Sunrise Set Day - [ID 002D][Parent 0048] If Time is Sunrise Then $sSunrise_Daytime = 1 $sEarly_Morning = 0 Else - No Actions - (To add one, press 'Action') The state variables are changing but the programs are ignoring the lines in the program so this works even is sSunrise_Daytime = 1 Auto Kitchen - [ID 0014][Parent 0001] If 'Din SliderActivity' Status is On And $sSunrise_Daytime is not 1 And 'Kitchen Main Master' Status is Off Then $sKitchen_Motion = 1 Set 'Night Kitchen Snack' On Else - No Actions - (To add one, press 'Action') And last night the house didn't light itself up at sunset. I verified that this worked (The last two lines are leftover from troubleshooting "long running randomness" a year or so ago. It has been working so I haven't cleaned up all of the test code. Sunset to Night - [ID 000C][Parent 0048] If Time is Sunset Then $sNight = 1 $sBedtime = 0 $sSunrise_Daytime = 0 $iAtomic_Test_Tracker = 0 Set 'Courtyard Niche Top' On Else - No Actions - (To add one, press 'Action') The fountain came on and the sNight was "1" and sHouse_Active was "1" but this never ran. Night Daily Home - [ID 0003][Parent 0001] If $sHouse_Active is 1 And $sNight is 1 And $sBedtime is 0 Then Set 'Entry Art Niche' On Wait 1 minute Set 'Dine - DR Button' On Wait 4 seconds Set 'MB Cabinet Status' On Wait 1 minute ... (shortened for space) Else - No Actions - (To add one, press 'Action') Any thoughts? Thank you
How do you get help from UD tickets?
You have a lot going on here, and I will be the first to admit that I had 90% of the same problems as I migrated from the 994 to the eisy and in fact once returned the eisy until UDI cancelled support and forced the upgrade. The Elk poly does a lot of things much better than the old UDI module but it is much more difficult to configure. As the guys stated before there are a lot of help files with the poly but I found most of them written for programmers not users. Here in the forum there are answers for everything you are looking for. As far as connections, there is a lot in this thread, but did you ever get your router to set a DHCP reservation? Without it, every power failure you might lose the connection. There is a ton of help here in the migration thread And here is where the answers for my own elk issues were solved by some others here I agree with @DennisC until you get it correct you will have difficulty. I didn't have time to do it right but I made the time to do it thrice.
Scene strangness - works via alexa or admin console
Maybe as a last resort follow the replace PLM instructions?
Dual "Controller" not working after i3 upgrade
@paulbates, Thank you, I am glad to hear it isn't just me. I will do a reset today. I realized that button 4 on the i3 4 button also is a controller/responder to another scene on the same 8 button controller. So my original post was asking the wrong question. The "dining" scene works fine, it is the "patio" scene only that is the issue. Full reset and reload of both of them today, I will test and post results.
Oh yeah, one more note, the load on the insteon switch next to the 8 button keypad flickers when they are both set to controller. The eisy indicates that all loads are on properly after pressing either button. So I added a program to query, all that did was correct to what actually turned on. I am starting to see several keypad buttons lit up and the associated device or scene not on in the house. Once upon a time I understood that if I created a scene in the eisy, the scene was loaded into the devices. Some scenes work with the eisy off line, and others don't. For today's experiment I think I will delete the scene and devices from eisy, manually create the scene with the set buttons. Find the devices and keep the links to see what it does. In another thread there is a discussion that eisy only sends the scene command. I thought Insteon devices self checked and corrected however now I see "retry" options in IoX. I also recall that when an insteon device receives a command from eisy that it treats it differently then a button press. For this situation I am talking about a button press. Maybe a program for the 8 button to launch the "patio" scene and leave the i3 as the controller?
@lilyoyo1 That's what I thought, but they are not. I've tried deleting the devices and the scene. I noticed that there are more setting levels available with i3 so I thought that may have been it. For now I am leaving the 3rd button on the i3 as a responder so the scene works.
SmartWings Shades Matter Over Ethernet and PoE
Greywinds and Smartwings blinds can use usb-c connectors. I would think that wire is easier to hide that 120v or Cat5 like wire. I have one of the solar panels just to see how they look/work. It works, but a bit too big to hide.
I have battery powered greywinds blinds. These were "easy" to install, but not eisy controllable. They work great with Alexa, Apple Home and uh the HA green, but for whatever reason the eisy sees them and I get "main" or "unavailable" for all of the devices. I can control them via alexa with the eisy, but the entire idea of the eisy is autonomous operation of my home. Thanks for the information on smart wings, I think I will buy one and see if it is worth the swap out. Greywinds are battery operated and the battery level is monitored by the HA so it alerts me to plug them in at 25% which is about every 90 days. Any idea on the smart wings battery life for the wireless versions? I have the HA as a test tool, I like the eisy better overall and have years invested learning it. Nevermind that I am too lazy to program the HA from scratch.
while going through other issues I swapped an old Powerline switch for a new custom engraved i3 four button. As a standalone the four button works fine. I have an 8 button keypad in the dining room with a "patio" key button. It is and has been the controller for the "patio" scene which turns on the main load on the new i3 and four other switches and an outdoor switched outlet. I also wanted the 3rd button to do the same thing. In the past I set them both to "controller". My understanding is this makes them both "controller/responders". so turning one on turn on the scene and the other switch. When only the Patio button the 8 button keypad is the controller, the scene works. When Only the Patio (3rd) button on the i3 4 button is the controller the scene works. When they are both set, neither work. One turns on two lights of the scene, the other turns on three. Neither turns on the outlet. Any thoughts? Is this not possible and I am approaching dual controller idea wrong? Do I need two identical scenes where the i3 is the controller for one and a responder in the other and reverse for the the second scene?
Long Running Randomness
Now over 14 days no errors. The light on the keypads not going off with the scene are an i3 outlet that comes back on. The keypad is properly indicating something is on. Both outlets set to "load sensing off" and no changes. A strange new feature of my system is that my wife's watch winder is now getting little trickles of energy from the 2456S3 Appliance Linc v.42. Instead of a constant hum it is a "click" as it tries to move about once every 6 seconds.
Insteon i3 switch support?
@Geddy, @paulbates The four button was at least 3mm deeper than the 2476D it replaced. Shoving it into one of the last 1970 original boxes left in my house was a challenge. @mfryd I don't see anyway to do it in in IOX, only the 1 address appears with all of the options as a load controller, but that isn't to say if you didn't use the hub to move the load it would not move on IoX.
DHCP Only?
@larryllix, wow, this is a new one on me, so kudos from digging up the blog. Sorry for the long delay, I work overseas for a week at a time each month. I did some more research on the Bell HH4000 and yes it appears you need to downgrade to the H3000 to turn off DHCP and create a bridge mode. Sadly I eliminated the middle man and my fiber converter simply gives me a hot RJ45 jack with a single IP address, the rest is up to me and I get zero support from Frontier. I noticed the blogger mentioned that he was going to try a double NAT and hasn't posted results. When you say Double NAT didn't work, how did you set it up? Did you force an address on the NAT table from the bell router. I used .100 after reading some other information about how Bell routers reset after power failure. .1 - .5 apparently do random things so stay away from that range. Bell Router IP Address - Bell Assigned Local IP address 192.168.1.1 DCHP 192.169.1.2-255 DNS 1 Bell Assigned DNS 2 8.8.8.8 (Google if possible) WiFi7 Router IP Address 192.168.1.100 DHCP 192.168.2.101-255 DNS 1 192.168.1.1 DNS2 8.8.8.8 Devices (DHCP ok) Fixed IP Address in range of 192.168.2.5 - 2.95 Gateway address of 192.168.2.100
Well Skip that, I restarted iOX and did a factory reset on the switch and all is well.
