TheFallenAngel
Everything posted by TheFallenAngel
  1. Well first do regular ones After that can play with the 'hacked' option Sent from my SM-G935W8 using Tapatalk
  2. When you look into it tho - the low, medd, high as default must be a choice. I mostly have my fans on MEd, and one can't even be handled at high.. And I am sure there will be people to prefer low as default too.. Sent from my SM-G935W8 using Tapatalk
  3. In any UI red X is also indicative of "remove", "delete" and "close"... Sent from my SM-G935W8 using Tapatalk
  4. I don't see I point of less than a minute even, environment can't change that fast.. Sent from my SM-G935W8 using Tapatalk
  5. That means you have messages just say Alexa, what did I miss.. Here to see all: https://www.amazon.com/gp/aw/help/id=201601790 Sent from my SM-G935W8 using Tapatalk
  6. They will do it by going to alexa.amazon.com in any browser on any desktop or tablet (not the phone apps) Sent from my SM-G935W8 using Tapatalk
  7. If you read the description of the Alexa App in the store, it says : "The new capabilities are available to customers with phones on Android 5.0 or later." Also, it was said here many times that the new features are not available in a browser (any browser) but only in the phone app. Sent from my SM-G935W8 using Tapatalk
  8. It doesn't.. I have 3 android devices and even tho on one I had sideloaded US apk (it was geo-restricted in Google Play Store before) on the other 2 (phone and tablet) loaded from the app store when became available a week or do ago.. They all have all the functionality right now.. They do however base some things on country settings in one's amazon account (like country based skills and language).. Sent from my SM-G935W8 using Tapatalk
  9. Yeah the language is pointless to me In fact I am using UK English on couple dots for the cool accent Sent from my SM-G935W8 using Tapatalk
  10. But Larry the app is in the Google store this is why you getting Geo restriction.. You seam to mix things between Google and Amazon.. Sent from my SM-G935W8 using Tapatalk
  11. You first forget all the devices until you see nothing showing, then disable the V2, then enable V3 and rediscover. OR disable V2, enable V3, then forget all devices until see nothing left and then do rediscover. Have duplicate devices clearly shows old devices were not all forgotten.. Sent from my SM-G935W8 using Tapatalk
  12. I am not sure why are you so stuck on that Google thing?! I have 2 Google accounts and they are configured on ALL my devices (PCs (3 Windows 10), tablets 1 win 10 and one Android 4.4) and Android phones (2 OnePlus and Samsung) - Alexa works EVERYWERE Perfectly fine l for me with those google accounts and OP independent since I traveled all over the world! There is no IP blocking and there is nothing to do with Google! What IS relevant is Amazon store (.ca vs .com) and Amazon account address - don't know how but my Amazon Prime works perfectly fine for both (.ca vs .com).. Sent from my SM-G935W8 using Tapatalk
  13. I assume you don't use Harmony Skill for that since it only supports single hub. So how are you doing it for 4?i really need this cos I have 2 and sucks that I can only use one with Alexa [emoji20] Sent from my SM-G935W8 using Tapatalk
  14. I assume you don't use Harmony Skill for that since it only supports single hub. So how are you doing it for 4?i really need this cos I have 2 and sucks that I can only use one with Alexa Sent from my SM-G935W8 using Tapatalk
  15. Have you (with the APK loaded):1. Forgot all devices, 2. Disabled Skill V2, 3. Enabled ISY skill V3, 4. Discovered all devices. The App it self has no IP restrictions what so ever. The Geo location restrictions are in the Google Play store, and on the alexa.amazon.com (vs. ca) I've tested that from dozens of IP addresses in Canada, US and Europe (during my last travels). If there were any IP restrictions in the app it self I wouldn't able to use it from Italy or Greece or Israel.. Sent from my SM-G935W8 using Tapatalk
  16. This has NOTHING to do with UDI, Amazon controls who can see what.. Sent from my SM-G935W8 using Tapatalk And I am also in Canada and always see both V2 and V3 Sent from my SM-G935W8 using Tapatalk
  17. Yeah the harmony skill responds with delay from couple seconds to couple minutes.. The other very wonky on is Magic Home skill.. ISY skill has been mostly stable.. So I also believe these issues are Amazon related, not the skill.. Something in the framework.. Sent from my SM-G935W8 using Tapatalk
  18. Don't, they haven't added English (Canada) yet.. Use US English or UK for now, doesn't make any difference but the accent After all the official support of Canada begins Dec. 5th.. Sent from my SM-G935W8 using Tapatalk
  19. Actually I would think the Smart Home Skills would be the (or should be) the first ones allowed. One reason is endless user case and no potential for abuse since the notifications should be anti rely end-user driven. So let's hope UDI will apply asap and when they get it - they get it.. I don't think this is a "roadblock", just a step in the right direction.. Sent from my SM-G935W8 using Tapatalk
  20. #AWESOMESAUCE Sent from my SM-G935W8 using Tapatalk
  21. Because you don't have the proper app (we figured that out) not sure why.. Hence my suggestion to try the APKPure route. On 1 device I had the app trough APKPure for more than a year, on another device, installed 10 days ago (from Can store and still says latest) it's like yours, and in a third one, installed 5 days ago from Can store is the same as the in US store.. So go figure.. Eitherway you must have the proper app for that work. I also sent several screen grabs for you to compare with the app you have.. Sent from my SM-G935W8 using Tapatalk
  22. Well that was my OP, the response sadly was that it's not on the road map. I am really hoping this will change Sent from my SM-G935W8 using Tapatalk
  23. Well that's part of the notifications frame work.. Sound and color ring flashing.. Sent from my SM-G935W8 using Tapatalk
  24. I said ONLY in the App, not on computer Sent from my SM-G935W8 using Tapatalk
  25. Pay attention Larry, it does not work on computer, just in the proper version of the Android App... Sent from my SM-G935W8 using Tapatalk
