Everything posted by Timehub
Total Beginner ..First Steps , Help and Requirements
After checking the Admin and Entering Diagnostics >> PLM Info , It returns connected , so I thinks its a go , So thanks for the Info I will probably need a helping hand with the other stuff that arrives next week . Im more of a php programmer and web designer so developing a front and backend to the system adding from the existing Library located at GITHUB
Well i followed what was here http://www.universal-devices.com/docs/production/Quick%20Setup%20Guide%20994i.Rev%207.pdf upon following your advice with the small ethernet cable attached to PLM from Port A This is what the Log says ..., , how do I know if it worked or not ? Sat 03/26/2016 06:27:24 PM : Start Insteon Device Linking Mode Sat 03/26/2016 06:27:24 PM : [LNK-BGN ] 02 64 01 00 06 Sat 03/26/2016 06:27:46 PM : [sET-BTN ] 02 54 03 Sat 03/26/2016 06:27:51 PM : [sET-BTN ] 02 54 04 Sat 03/26/2016 06:28:08 PM : Stop Insteon Device Linking Mode, Final processing to follow Sat 03/26/2016 06:28:08 PM : ---- Start: Generate Scenes from links ---- Sat 03/26/2016 06:28:08 PM : [LNK-END ] 02 65 06 : : Unexpected, ignored (65) Sat 03/26/2016 06:28:08 PM : ---- End: Generate Scenes from links ---- Sat 03/26/2016 06:28:08 PM : [All ] Writing 0 bytes to devices Sat 03/26/2016 06:28:08 PM : [All ] Writing 0 bytes to devices Tnx again
Hi there , Im about to delve into the world of home automation and have purchased a ISY994i/IR Pro along with a 2413S, , I also have 2 FilterLinc Coming soon and also 2 ApplianceLincs also ( still awaiting their arrival) as this is something I have never before done Im wondering if some person could lend a helping hand , I must admit im totally stumped :/ , I have pulled down the Manuals both quick start and the full comprehensive from UD and truthfully im still a little puzzled I have the ISSY994i/IR pro system that does not have the RS232 slot and only have Port A , the Ethernet Is set to the Local 192.x.x.x IP and I have succeed in connecting to the Admin , reset the user/pass ... but now its time to setup the PLM The PLM Device 2413S Ver 2.2 , contained a DB9 to RJ45 , I also currently do not have a rs232 port with my pc , is this something 100% a requirement if so at first that's not very clear ... though it does also says the PLM can be connected to the UD ISY Device , including powering the ISY , if so how does that Connect and work .. the question is how and what is the best way of setting this up . , so I can test the PLM before anything else ... and finally what if any other Equipment do I need what #ProductID,additional pc Cards / accessories , Thanks Martin
