Ajax
  1. Wil give that a shot thanks!
  2. Weirdest thing... Works perfect for when we are going to bed but some mornings I would wake up at 3 or 4 and notice the keypad is bright. I assumed that it lost the status and reverted back to "else" but this morning "H" was not on (Meaning door status is locked) but some other keys were lit for fan speed. I am guessing it happens when the ISY is query all at 3am. All it takes is me getting up and manually unlocking and locking the door to dim the keypad again
  3. Check out this thread https://forum.universal-devices.com/topic/31989-error-clonerepo-error-runinstallprocess-undefined/ I was told : In 99% of the cases, this is related to Polisy not having access to the internet (perhaps you configured static IP and the gateway or DNS are incorrect). If that’s not the case, and if your unit is from a long time ago, then you may need to upgrade the OS. If you know how to use ssh, then: ssh to Polisy login (default is admin/admin) at the prompt: curl -shttps://pkg.isy.io/script/update121.sh | sudo bash
  4. All, I have been trying with no luck to add the Gen 6 siren to my ISY. I have a schlage lock and Aeotec Range extender 7 that works just fine. I have tried including and excluding. doing it by the ISY or away etc. but nothing seems to work. Searching the forums you see the issue pop up once in a blue moon but they mostly resolve themselves. I did post on someone else thread but no real information either. https://forum.universal-devices.com/topic/32506-z-wave-siren-compatible-with-isy994izw/
  5. Thanks not sure how I missed that one! Also I always thought people like continuing threads with similar/same problems. I dont want to come off as always needing to create new threads like I did not put the time into searching, but will keep it in mind. I have other Z-wave devices that functions just fine, but below is the info.
  6. Any update on this? I just got a siren 6 and for the life of me cannot add it...
  7. Will give this a shot tonight:
  8. Great thanks. I do like your idea of instead of sunset to trigger use the status for lock to trigger the dimming. I can see that would work. There might be a couple times that when I come home late and the wife is sleeping that when I unlock the door the keypad will brighten back up until I lock it, but at this point might be the best option. Thanks!
  9. OK finally got a Schlage lock installed. I would like for it to turn on a keypad light "H" in the master bedroom if unlocked, as well as locking the door if button H is pushed. I have it working mostly but ran into a snag. My wife hates the glow of the switch lights so I have a program that turns the LED brightness down at night. So at night you cant see if the door is lock or not. I have tried to adjust the scene and or programming backlight but does not seem to work. Basics: I have a scene (Backdoor Lock) with the lock as responder and keypad H as controller Another scene (BackDoor Lock Light) with Keypad H as responder From searching it looks like you can adjust the keypad backlight only as one unit not individual lights? Is that correct? Current dimming program:
  10. Must be my computer it just spins with a white popup no name, will keep trying thanks!
  11. @MrBill OK went ahead and replied to that thread, reason I havent, I thought I could tackle this question a different way. Thanks for the hint @larryllix
  12. Larryllix that is what I am struggling with a while ago with the node server. Never got it resolved. Here is a link to the issues: https://forum.universal-devices.com/topic/32266-nodes-not-created-for-my-tags/
  13. OK so I have been searching but dont seem to find what I am looking for. SO for years I have had the wireless tags by themselves working great! Well I have been getting a notifications my batteries are dying and havent had a chance to replace one of them in my freezers....the freezer by kids store their popsicles in. So of course they left the door open a sliver and thawed everything. My wife blames me since I did not switch the batteries out! Well I would like to tie the tags in with Alexa. I have tried my Polisy but cannot get all my tags to show in AC. I have installed the Skill in Alexa but cannot see the tags listed as a smart device so I cannot trigger anything. I can ask the status but that is it. I would like it announce if the temp is outside the limits, door is open to long, or battery is dead, that way my wife will be in the loop as well and cant use me as the scape goat. Are there an EASY way to accomplish this? Thanks
  14. Ajax replied to Ajax's topic in ISY994
    Great thanks everyone that was the issue. The pro upgrade fixed it all.
