Culvdave
  1. I did follow the procedure, first time had issues with communication, did factory reset on PLM and did it again, worked ok except for the scenes, what I ended up doing was delete each scene then rebuild them (a lot of big scenes) and all looks good. The puzzler now is my Alexa app has lost some devices and scenes and can't find scenes from ISY portal, not sure how that is related to replacing a PLM
  2. I've replaced the PLM and all devises respond to commands but scenes don't. When I bring up the scene it shows the devices involved but not on levels. Any ideas?
  3. I'm back trying to make this work, when I say "play" the Fire Cube will play content, same when I say "pause" it will pause content. I'd like Alexa to also run a lighting scene with the command. I made two ISY programs called play and pause that have the lighting scene I want for each command in the programs. When I say "turn on pause" the Fire Cube pauses content and lighting scene in that program is run but when I say "turn on play" just the lighting scene in that program runs and Fire Cube doesn't play content, I'm confused
  4. I'm trying to create a routine where when the pause command is given to Alexa it will trigger an ISY lighting scene along with pausing tv, problem is Alexa doesn't like "pause" as a phrase for the routine. Is there a way to accomplish this?
  5. I've sorted out why the admin console wouldn't open log, still working on the devices turning on randomly.
  6. I'm having an issue with two devices turning on randomly and when I check the log they don't show any activity. Then I just tried to open the log in the admin console and it says it can't open it. Any ideas on what's causing this?
  7. Culvdave replied to Culvdave's topic in ISY994
    I'm puzzled, last night I tried writing updates to the IRLinc and all the buttons with no joy, tried it again just now starting with the IRLinc itself and then the buttons individually and after I did one of those all seems fine.
  8. Culvdave replied to Culvdave's topic in ISY994
    It's a IRLinc receiver, I'm using link management to link the buttons, it was all working fine, I then added a few more links when it did this. I've tried writing updates to the IR Linc and linked buttons but the green barrel appears again after the process
  9. Culvdave posted a topic in ISY994
    I was linking buttons into IRLinc when I got an error message the ISY was trying to find nodes. Now on admin console IRLinc and all buttons linked have the green football on them. What did I do wrong and how can I fix it? Thanks
  10. That's what the problem was, the settings for the controller were different from what I had in the scene. Thanks again for your help on this guys.
  11. When I activate the scene via ISY the on level and ramp rate do what the scene is set at, it's when I use the button on the Ipad that it doesn't get the settings. The lights all react, just not to the settings in the scene
  12. Sorry, how do I do that?
  13. I,m not sure, the way I had it set up before was the Global Cache got the wifi command from Ipad, sent that via ir to the IR Linc, which had the on level and ramp speed linked to it. Now IR Linc only recognizes the button which corresponds to the scene set in ISY
  14. Actually Paul, there is an issue, the IR Linc buttons connected to the ISY with no problem but when I execute a scene linked to the button it doesn't recognize on level or ramp rate.
