dakall
Everything posted by dakall
  1. Short version: Right after my next door neighbor put in solar power, I began to have random light flickering issues. Both of our homes are fed off the same transformer (it is located between us). Is it possible that his equipment is "dirtying" up the power on the secondary side of the transformer? Longer story: For context, my house (and Insteon switches) are five years old, and I never had a problem. Eight or nine months ago, when the flickering first started, I assumed it was something going on in my own house. I scoured this forum looking for similar issues and tried everything I could find here. I replaced the PLM, I disconnected/replaced UPS units, etc. I kept a notebook of everything I tried. Every branch circuit breaker in the house has been turned off at one point or another without any changes. So I know it most likely isn't any of my appliances or anything else internal to my house. I also watched the logs on the Admin Console when flickering would occur and nothing showed up there. Needless to say, it was maddening. I never even considered that it could be the neighbor's solar set up until a couple of weeks ago. The solar company came out to replace some parts and had his system shut down for a few days, at least that's what the neighbor tells me. But for those few days, everything was rock solid in my house. As soon as they replaced the parts and started the system back up, the random flickering began again. Is there some sort of whole-house filter I can install to potentially clean up the incoming power? Or any other suggestions of what I should try?
  2. dakall posted a topic in Insteon
    On each of my Insteon dimmers/switches there is a small sticker with the device's address and a Rev number (ie Rev 7.8, Rev 8.2, etc). There is also a version number shown on the AC page for each device. But these are totally different (ie V.44 or V.45, etc). I don't seem to be able to figure out a correlation between these two numbers. I have some Rev 7.8 devices that show V4.4 and some that show V.45. What to these numbers mean?
  3. You are absolutely correct. It has been more than a year since I originally set it up; I forgot about the numzones parameter. I had gotten a replacement eisy about a month ago. The PG3 backup I had was old and didn't have this node server. I had to set it up again, and obviously failed to read all the instructions. That's my bad. Thanks.
  4. Let me start by saying that this was working perfectly. I'm not sure exactly when this stopped, but I noticed today that the plug-in is only seeing Zones 1-8 and not 9-16. When I look at the Nodes on the PG3 page 9-16 are not listed or included. It used to show 1-16. Obviously they are not showing up in the IoX Admin Console either. I deleted the plug in and installed into a different slot and got the same results. On the PG3 page, it is showing 10 nodes: Node1 = Alarm Panel Node2 = partition 1 Node3 - Node10 = Zone 1 to Zone 8 But yet when I log directly into the EvisaLink I see 16 zones and it tells me if open or how long closed. I have not changed any of the settings since I got it working several months ago. Could a recent PG3 or IoX update be the culprit?
  5. Updated and rebooted. All seems fine. Great work, as always.
  6. dakall replied to dakall's topic in eisy
    UPDATE: I started a ticket, and after a few back-and-forth messages with Michel, he decided that a remote session was needed. After about 20 minutes of poking around in the eisy, he showed me there were 2 directories that were showing 49GB in size. He said not only should there nothing that size, he was also unable to open those directories. He said that was signs of the harddrive failing. I had also experienced 3 or 4 strange glitches in the past month, but I was able to reboot and go on as normal. I now wonder if this was the early signs of the drive failure. UD is sending me a replacement eisy, and hopefully in a couple of days I can have things back to normal. I cannot say enough good things about the service and support I received. A big thank you to Michel and the UD staff.
  7. dakall replied to dakall's topic in eisy
    Thanks. I did try the button presses, but no luck. I also cannot load the sysconfig.txt file. I will start a support ticket.
  8. dakall posted a topic in eisy
    I awoke to a notification that PG3 had stopped during the night. Made sense since none of the early morning routines didn't run. I tried to reboot it via the app. I got a notification that the eisy went offline, and then crickets. I waited about 20 minutes but could not access it via the app or the AC. I could, however, ping it on my network, but could not establish an ssh connection. I then unplugged it for 15 minutes and reapplied power. It's been 25 minutes now and still no response. I do have the blue light though. Is there some button combination I can do? Fortunately, I did back it up 2 days ago, so if I end up wiping it, hopefully I can easily restore everything. Any help is greatly appreciated.
  9. dakall replied to dakall's topic in IoX Support
    Regardless of DST, solar noon is 6 hours after sunrise in your examples. DST does not increase the times between sunrise and sunset. We as humans just offset our clocks from those times.
  10. dakall replied to dakall's topic in IoX Support
    How are you getting those sunrise/sunset numbers? Are you converting the times somehow?
  11. dakall replied to dakall's topic in IoX Support
    That's exactly what I'm trying to do. Open up the east side shades, wait an hour and close the west side shades. I currently have the program run at 11:45 am, but I have to change to 12:45 pm when DST kicks in.
  12. dakall posted a topic in IoX Support
    Does anyone know of an easy way to compute the time of day for Solar Noon? (midpoint between sunrise and sunset) I know there are variables for sunrise and sunset, but I can't average them together successfully. Or is there a node server that does that? I use the Timedata NS which has lots of info, but not solar noon.
  13. dakall replied to dakall's topic in IoX Support
    That's exactly what I was thinking. I have 2 other dedicated circuit outlets in that closet. I can try shuffling things around if need be. I'm hoping this was a one-time event.
  14. dakall replied to dakall's topic in IoX Support
    None that I noticed. The PLM is plugged into a dedicated circuit outlet in the AV closet. The only other thing plugged into that outlet is a small UPS unit for my router.
  15. dakall replied to dakall's topic in IoX Support
    Of course the one thing I didn't do fixes it. Thanks Interesting thing is that right after I plugged it back in, all the LEDs returned to their "daytime" levels. I didn't need to do anything.
  16. dakall replied to dakall's topic in IoX Support
    PLM is less than 6 months old. I will try this.....
  17. dakall posted a topic in IoX Support
    I can no longer control the backlight LED brightness from the AC or UD Mobile app. I run a program in the evening that sets the switches/dimmers backlight in the bedrooms to 0%, and then back to 30% in the morning. Last night, only some of them dimmed. This morning the ones that dimmed did not brighten. Like I said, I currently cannot change the backlight setting from both the AC or the app. Things I have tried: Reboot eisy (multiple times) Retore most recent backup form AC Restore devices from AC I did get a notification on the app last night (which would have been prior to the dimming program executing) that said "PG3 stopped working." I ignored it since everything seemed to be working fine and all the "bedtime" programs ran normally with the exception of the LED dimming. I don't believe it's a PLM issue since I can still control everything from the AC and the app, so communications seem to be fine. I should add that I'm running PG3x 3.2.17 and IoX 5.8.0
  18. dakall replied to dakall's topic in Noyito-Relay
    I really don't want to be "that guy" but I am at a loss here. Yesterday, I was getting Authentication Error while trying to log into the PG3 homepage. I rebooted my eisy and then was able to log in normally. However, this plugin was not working after the reboot, so I followed the above steps to get it back working. After that, I got the Authentication Error while trying to log into PG3 again. Another reboot cleared it up, but then it became an unending cycle of the plugin not working, then working, not being able to get into PG3, and rebooting. So for now I have this plugin turned off and the USB cable to the relay disconnected and everything else is fine. I can start a ticket if that would be a more proper channel for this issue.
  19. dakall replied to dakall's topic in Noyito-Relay
    That fixed it. Thanks.
  20. dakall replied to dakall's topic in Noyito-Relay
    I did all that, even a couple of reboots. Now I get "Unable to open serial port /dev/pg3.noyito"
  21. dakall posted a topic in Noyito-Relay
    I installed this a couple of months ago and it worked great. I'm not quit sure when it stopped working as it only gets used maybe once a week. Could one of the recent updates be the cause? I uninstalled it and installed it into a different slot with no luck. I'm getting this notice on the PG3 page:
  22. I've never been able to figure out why people feel the need to announce that they are no longer going to use a product on the forum for that product. If you are having particular issues, ask a question. Otherwise, it all seems like a plea for attention.
  23. Use From... To... not Time Is. Patio Lights - [ID 0033][Parent 0001] If From Sunset + 5 minutes To 11:30:00PM (same day) Then Set 'Patio Lights' On Else Set 'Patio Lights' Off
  24. Yes. I do it all the time. The Ecobee node server lets you choose between comfort settings. (Although the NS calls them Climate Types) An added plus is that you can also chose if it will be a Permanent Hold or just until the next thermostat program change. I have a comfort setting called Don't Run utilizing a higher AC temp and a lower heat temp that gets switched to whenever a window or door is open for more than 5 minutes.
