johnmalachowsky
  1. after multiple update with interview tries..the energy monitor only had one leg and no totals, i removed it factory reset, and tried to do it as new. Can't add it. I hope it gets fixed. I know this is a beta version, so I am willing to wait until everything gets fixed. Perhaps a option to add zwave device without interview.
  2. I just changed from Zwave to ZMatter running 5.55 and have a few problems. 1) Everything is in Celsius even though it was in Fahrenheit before the transfer 2) my zw095a Aeotec energy monitor will not install, it never finishes the interview 3) My Fibaro fgbs-222 installs but is a mess. None of the external sensors work. They have a page, but no boxes for values
  3. I am running 5.0.2. I installed a Linear GD00Z-4 (This is a z wave plus garage door controller, shows up as a barrier). On the console it shows correct, open and closed. When I add it to my echo, it shows up as a lock, which would be okay, except that it is backwards. When the door is closed, it is shown as unlocked, and when it is opened, it is shown as locked. This is backwards, because as configured I need a security code to close the door, but anyone can open the door by voice without any security code. This could be a problem. John Malachowsky
  4. Alexa now supports the "lock" command. When I use it on a light, alexa says that command is not available for that device. However, when I try to use it on one of my locks, alexa says it cannot find the device. However, when I say "tell isy to lock the ....." it works fine. Is it because the locks appear as locks and not devices in my portal. I assume it requires an update to the alexa skill. Do you have an estimated date for the update? John
