domotinc-customs
Everything posted by domotinc-customs
  1. anyone else? what outdoor camera are compatible with eisy and UD portal? or is it just "any camera that support RTSP protocol" thanks
  2. all, im going crazy on something that should be a 5 minutes things. I want Alexa to talk to UD. documentation states: Make sure your ISY is configured with TLS 1.2 and Strength All and Verify is unchecked for HTTPS Client settings. If you are unsure, please consult this document Network Security Configuration Guide that links mention to click on "dashboard" but all the iox launcher shows me is admin console. where is that dashboard???
  3. everything works just fine. curious to know if I have many zwave devices not in direct range of the zwave dongle. maybe I could move my eisy elsewhere for things to work better. maybe I could change the antenna for a high-gain antenna. something like this: https://www.amazon.ca/wlaniot-Antenna-External-Connector-Security/dp/B07PZFV9NK not because it works that it can't work better
  4. that what I get with the zen72 in the same room as eisy which value should I look at? <nodeInfo> <node flag="128" nodeDefId="ZY066_1"> <address>ZY066_1</address> <name>SS-Rangement-D</name> <family>12</family> <hint>0.0.0.0</hint> <type>4.17.1.0</type> <enabled>true</enabled> <deviceClass>0</deviceClass> <wattage>0</wattage> <dcPeriod>0</dcPeriod> <startDelay>0</startDelay> <endDelay>0</endDelay> <pnode>ZY066_1</pnode> <rpnode>ZY066_1</rpnode> <sgid>1</sgid> <custom flags="192" val1="0"/> <devtype> <gen>4.17.1</gen> <mfg>634.28672.40962</mfg> <cat>119</cat> </devtype> <property name="" uom="51" formatted="100%" value="100" id="ST"/> </node> <properties> <property name="" uom="51" formatted="100%" value="100" id="ST"/> </properties> </nodeInfo> and that's the zen72 that I believe to be as far from eisy <nodeInfo> <node flag="128" nodeDefId="ZY059_1"> <address>ZY059_1</address> <name>2e-Thomas-D</name> <family>12</family> <hint>0.0.0.0</hint> <type>4.17.1.0</type> <enabled>true</enabled> <deviceClass>0</deviceClass> <wattage>0</wattage> <dcPeriod>0</dcPeriod> <startDelay>0</startDelay> <endDelay>0</endDelay> <pnode>ZY059_1</pnode> <rpnode>ZY059_1</rpnode> <sgid>1</sgid> <custom flags="192" val1="0"/> <devtype> <gen>4.17.1</gen> <mfg>634.28672.40962</mfg> <cat>119</cat> </devtype> <property name="" uom="51" formatted="100%" value="100" id="ST"/> </node> <properties> <property name="" uom="51" formatted="100%" value="100" id="ST"/> </properties> </nodeInfo>
  5. good morning! been looking around for like 30 minutes. where can I see which zwave devices have direct communication with the zmatter dongle? (and also see which devices do not have direct communication with eisy) thanks!
  6. thanks Javi! that explains why it was working great last week. today it works on both ipad and iphone. seems resolved or going in the right direction! im new to UD (new ish, ran my house with it 10 years ago) and im glad to see proactive action at resolving issues thanks
  7. yeah, I realized I needed to go through state variable because every time I was touching a light switch, it was triggering 10-12 program that were setting zen32 leds. figured that created a ton of unnecessary zwave traffic. so zen32 trigger a scene on or off another program monitor the state of all the lights in the switch and turn a state variable on or off another program triggers on the state variable to change led on zen32 I realized that if you "change" the value of a state variable with the exact same value, it does not trigger a program with that variable in the IF. can you elaborate on this?
  8. hello all, when I look in the admin console, all status of everything is accurate and devices status updates within fractions of a seconds. perfect. UD mobile seems to be the exact opposite. it keeps throwing me errors, asking to delete tons of unused values one sync out of 5 (which I always agreed to delete unused values...), status don't update or simply not shown. I get the same behavior on my iphone and ipad (2 different apple account) again, admin console works flawlessly. all program execute as expected. perfect! except UD mobile is really bad right now. all z-wave (all zooz except door lock) UD mobile was working great when I was testing with 2-3 devices on my table. now with the full house UD mobile is a mess. any idea what I could have done wrong? or how to fix it?
  9. all, I have zen32 with buttons like "basement on" and basement off" pressing it triggers a scene to turn on (or off) all the lights in the basement. pretty simple. challenge is: I want zen32 leds to reflect the basement lights status. meaning if I go in the basement and manually turn on all the basement lights, I want the zen32 "basement ON" led to be lit. only solution I can think of is to have a program that IF light 1 and 2 and 3 and... and... and... 20 are ON, then set zen32 led to ON anything smarter/elegant comes to mind? thanks
  10. wow. look around for 30 minutes. cant find it. post here 30 seconds later: "what is the "users" button do all the way down? oh! lock codes!" sorry for that
  11. guys, I just added my schalge connect (zwave) lock. works great, can lock and unlock. but how do I change lock codes? I just can't find where... thanks using a eisy with the zmatter usb thing
  12. found it. not the best, but I set it to "LED always off" and "LED always on" not the most elegant way. but it work. anyone have a better way of doing it? with habitat I can set brightness to 0. no clue how they do that by looking at zen32 advanced settings
  13. hi, quick one I can't find an answer. how do I turn off a zen32 small button led in a program? (I know how to change color, brightness... but how to turn it off? no clue) program like: if "whatever" turn off zen32 button 3 led. thanks
  14. it bring memories to be back here. I was a heavy use of ISY994i many years ago with insteon. we do offer zen32 engraving! domotinc-customs.com
  15. I got the ISY to change colors of a zen32 button. when garage door is open, led to be red, when garage door closed, led to be green. having the zooz relay zen17
  16. anyone have update on this? looking at taking my isy994 to control zooz keypad and the led indicators are an important point
  17. guys, sorry of it's a repeat, but I wants blinds that will work with the insteon 2444-222. I know somfy has what's needed. a 120v motor blinds with 2 input (up and down). I have been searching for days on the web, and called about 5 stores. I can't find anything... when I call the local store for somfy, it's about $1000 CAN per blinds. I never did shopping for blinds, but to me, it's overly expensive! is there anything else that exist at a reasonable price (blinds, shades, anything...) that works with insteon 2444-222. thanks
  18. hello all, I have the ISY994 with z-wave have the stelpro STZW402+ z-wave thermostat. im a but rusty on ISY + it's getting late... so sorry for dumb question. I can't find a way to do that: IF thermostat setpoint is < than room temperature THEN turn something on (like the insteon 2450) ELSE turn that same thing off I can't compare values from thermostat set point and actual room temperature directly. so I think I need to go through a variable as I can compare setpoint against a variable that would hold the room temp. how do I do a program that store room temperature in a variable and update itself (program trigger) every time the room temperature changes? am I on the right track? any idea how to do this?
  19. guys, im looking for a 0-10 volt DC dimmer that can be controlled by ISY, so I can code stuff in ISY like: if XYZ happen, set voltage to 7 volts. so far I found qubino are doing something that might do it. any device you know that can do that and can be controled by ISY994? thanks
  20. thanks for the reply. I want to be able to control temperature remotely (mobilinc) and have program in the ISY994 that would increase and/or reduce temperature. I have been looking around for 30 minutes on the aube relay and I can't find how it would work. can you provide me more information/links that would explain how it works? thanks!
  21. Hi all, I'm looking for a convector heaters thermostat that will work with isy994i. Is there any? Can I manage multiple thermostat?
  22. I did about 70 buttons in 3 days and my NEJE died.. engraving is now super light to the point it can't go through the green laser tape did I ended up with a bad/low quality laser? or maybe I abused it? anyone had a similar issue? anyone did like like 20-30 buttons in a row?
  23. stupid question, but why would I want to paint them? I mean, if all I want is text in black. it's pretty good without pain.
  24. taking the protective layer on the laser tape just drive me crazy! is there an easy way or I have to lose my mind for 5 minutes per button?
  25. guy, years ago smarthome had a "countdown timer 8 button keypad" that was programmed as a countdown timer and sold with the buttons pre-printed (on, off, 2 min, 5, min, 15min, 30 min, 1h, 2h) it was great for bathroom fan and no programing was needed unfortunately they don't sell them anymore. anyone used ISY to code it? I would do the button A as the ON/OFF and button B to H as the timer (2 min, 5, min, 15min, 30 min, 1h, 2h) I searched on the forum and I cant find anything.... anyone did it and would share the code?
