rafarataneneces
  1. I had no idea Hunter Douglas PowerView is IFTTT compatible! Wow, I love it! I'm going to buy it today!
  2. Is ISY Portal compatible with Google Home?
  3. Dear Michel With SO MANY people having problems with ISY Portal, have you thought that the solution is not that the ISY Portal will 'retry incessantly'? It's 100% obvious that rebooting solves the issue, so have you thought of officially name this a bug and work with us towards a solution? Do you know if V4 has this problem or is it only V5?
  4. Michel recommended me to reboot the ISY and it works
  5. Dear Michel I sent you the error log
  6. Dear Michel My ISY Portal says it's offline since 3:13 AM I don't know why Do you know if it's because of me or is the server down?
  7. Anybody has bought the Philips Hue 3rd Generation yet? it was supposed to be released yesterday
  8. My ISY Portal says devices is offline since 5:05 AM. I checked it around 5:20 AM I can use Network Resources just fine In my Configuration / Portals tab I see Portal Integration - UDI Online Registered Active Services Myusername Registered
  9. But I've read that with AC power, Insteon Wireless Thermostat reports temperature every time it changes. Without AC power, it only reports every hour. Do you know anything about it? I LOVE the fact that now it's always on! Before, ISY would just show a blank page. It definitively feels like EVERYTHING is now reported in REAL TIME (except temperature). Temperature reports immediately after changing. So far it is working flawlessly.
  10. It didn't worked out. Temp on the display was 84, temp on ISY was 83, no matter if I press the SET button on the Wireless Display. I guess this device is wonderful, but you CANNOT query, and it ONLY works if you plug in the USB AC 5.0 V positive and negative cables. I am so happy with my purchase, I will use it to control ceiling fans and change the speed.
  11. hmm I haven't tried, I would need to reboot since I see the temperature as 83F now. but the Thermostat with USB power is working rock solid, it sends the variable to the ISY every single time the temperature changes. I love it! I hope I remember to do this next time I reboot the ISY. I created a program that stores the temperature and humidity, and also with 'Int to' so it survives reboots.
  12. I bought an Insteon Wireless Thermostat. I installed it with USB and did some investigation so it's always powered on. I connected it to a power outlet that already has USB. It looks so good! however, it's been almost 1 hour and ISY won't see the temperature. So, from what I understand, ONLY when it changes temperature, it will send a 'report' to ISY correct? So you can't Query the device from ISY to see the temperature? So far, I love that it's always on!
  13. Would you please let me know if you can find in Amazon the power supply with 5v 200mah that you used? the only thing I found was USB chargers and I don't know if USB cables have one positive and one negative Sent from my iPhone using Tapatalk
  14. I want to use it so if temperature changes 1F, then change the ceiling fan speed
  15. The wireless thermostat can report temperature changes when temperature changes 5C, 1.5C, 1C, or 1F I don't know or even 0.5F
