bw23198
Everything posted by bw23198
  1. bw23198 posted a topic in ISY994
    Earlier this year I replaced my ISY 994 with a new eISY. The transition went smoothly. I now have an ISY 994 sitting unplugged on a bookshelf collecting dust. I will soon be building a new 2nd house and would like to automate some things with it as well. If I use my old ISY 994 in the new house, what functionality will I lose? I realize development has stopped for the 994 series, but I'm not looking to do as much automation in the 2nd house as my main house. (Also, there was nothing wrong with the 994 when I replaced it; I just wanted to upgrade for new functionality). Could I just purchase an additional license for the portal to get those features? (I transferred my original license to the eISY). -Brian
  2. I did notice the light was off before I unplugged it. It came back on when I plugged it back in. This PLM is quite old (at least 8yrs) and has been rock solid. It's the 2413s model. When I purchased it, I think it was either required or preferred for ISY994. Is that still the recommended PLM, or is the 2413U a better option? Most of my network is Insteon dual band devices.
  3. Ok, false alarm I guess. Unplugging and replugging in the PLM fixed it. My Insteon devices are now online and responding. I guess my PLM just got worn out and needed a swift kick in the rear. -Brian
  4. Oddly enough something similar happened to me. But in my case, eISY can't see any of my Insteon devices. All the device status are blank. And when I try to turn on my closet light (for example), I get an error message about my Rachio sprinkler system. All I can think of is that I recently added a new PG3 ratgdo module yesterday in slot 13 of my eISY. (I hesitated at first; thinking slot 13 wasn't a good choice. Maybe I should have listed to my gut!) I'm still trying to figure out exactly what the behavior is, but as of now all of my Insteon devices are unreachable. -Brian
  5. Removing the node and re adding it fixed it.
  6. I started to do that but this warning message spooked me. Does this mean I'll loose my integration with Alexa and all of the plugins I've installed from the PG3 store?
  7. After clicking on upload node definitions and allowing ISY to reboot the configuration still looks the same as above.
  8. This is what I see. I thought about just clicking the remove button and re adding this but the warning message that popped up looked like that action would affect more than just this node so I canceled that course of action.
  9. I've been following the instructions and I get stuck here: "After System is connected to Portal g to "Select Tool" > Occupancy v2.0. Click Add Geofence, in this example I use "Home Geofence", then save". When I try to add the geofence I get the "node server is not configured" error above. I completed the prerequisite steps of configuring the connection and uploading node definitions and rebooting ISY. There is a green dot next to my eISY on the main screen (and a grey dot next to my old ISY994 that I'm no longer using). If the occupancy node server is truly not needed then maybe all of this is unnecessary. However, this statement makes me think I need it: "However the Occupancy v2.0 Node Server may make tracking a locations occupancy easier if there are multiple users.". I have 4 users/devices within my house that I'd like to configure. -Brian
  10. I'm trying to set up the Occupancy 2.0 feature with a new eISY. I think I'm missing some sort of configuration somewhere but I can't seem to pinpoint it. I've setup a geofence on my iPhone but I think there's a connectivity issue with my Portal. For example, I don't see the Geofence created from my iPhone show up on the Portal. When I click on 'add geofence', I either get unauthorized or configuration error. Where is this configured? There's probably some old values somewhere from my previous installation that need to be cleaned up.
  11. After migrating from ISY994 to eISY, and reinstalling all of my node servers, I have the following two node servers "left over" from my previous installation: isylink ISY Portal Are these still needed? If not, how do I delete them? There used to be a delete button but none of my node servers had that button post upgrade.
  12. And that fixed it! The key was to look for that option within the eISY under Configuration | System. I was looking everywhere in the PolyGlot web interface. -Brian
  13. I found the 'upgrade packages' option. I'm trying that now and will report back.
  14. I figured I'd start a new thread in case my issue turns out to be different than others. I installed a new eISY today by backing up my ISY994 and restoring it on eISY. I was previously using a Raspberry Pi to run PolyGlot 2, and had the Kasa NS installed. I took the Raspberry Pi offline and have been reinstalling all of my NS within PG3. So far I've gotten most of them to work. However, Kasa is throwing the following error in a loop: 2023-12-26 19:38:29,958 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2023-12-26 19:38:29,958 MainThread udi_interface INFO __init__:<module>: UDI interface initializing 2023-12-26 19:38:29,958 MainThread udi_interface INFO __init__:<module>: User=0021b9026812_8 2023-12-26 19:38:29,958 MainThread udi_interface INFO __init__:<module>: Home=/var/polyglot/pg3/ns/0021b9026812_8 2023-12-26 19:38:29,958 MainThread udi_interface INFO __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/0021b9026812_8 2023-12-26 19:38:29,959 MainThread udi_interface INFO __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MjE6Yjk6MDI6Njg6MTIiLCJwcm9maWxlTnVtIjo4LCJsb2dMZXZlbCI6IldBUk5JTkciLCJ0b2tlbiI6IkpGdzhoVGY4VW9aNSohMEkiLCJtcXR0SG9zdCI6ImxvY2FsaG9zdCIsIm1xdHRQb3J0Ijo4ODgzLCJzZWN1cmUiOjEsImlzUEczeCI6dHJ1ZSwicGczVmVyc2lvbiI6IjMuMi4xNiIsImlzeVZlcnNpb24iOiI1LjcuMSIsImVkaXRpb24iOiJGcmVlIn0= 2023-12-26 19:38:29,959 MainThread udi_interface INFO __init__:<module>: Loading interface module 2023-12-26 19:38:30,003 MainThread udi_interface INFO interface:<module>: Loading MQTT module 2023-12-26 19:38:30,450 MainThread udi_interface INFO interface:<module>: MQTT module loaded 2023-12-26 19:38:30,674 MainThread udi_interface INFO __init__:<module>: Loading udi_interface module 2023-12-26 19:38:30,674 MainThread udi_interface INFO __init__:<module>: Loading node module 2023-12-26 19:38:30,675 MainThread udi_interface INFO __init__:<module>: Loading custom module 2023-12-26 19:38:30,675 MainThread udi_interface INFO __init__:<module>: Loading isy module 2023-12-26 19:38:30,675 MainThread udi_interface INFO __init__:<module>: UDI interface initialized 2023-12-26 19:38:30,675 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.2.6 Starting... 2023-12-26 19:38:30,677 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): File "/var/polyglot/pg3/ns/0021b9026812_8/kasa-poly.py", line 12, in <module> from nodes import VERSION,Controller File "/var/polyglot/pg3/ns/0021b9026812_8/nodes/__init__.py", line 9, in <module> from .SmartDeviceNode import SmartDeviceNode File "/var/polyglot/pg3/ns/0021b9026812_8/nodes/SmartDeviceNode.py", line 8, in <module> from kasa import SmartDeviceException ModuleNotFoundError: No module named 'kasa' I'm running 5.7.1 of eISY and 3.1.4 of Kasa. I've tried rebooting eISY, deleting/re-installing Kasa, restarting Kasa. I'm not quite sure what "recently run an update packages so you have the latest release" means. I looked for 'update packages' but can't seem to find that setting. Any ideas?
  15. Did this get resolved? I seem to have the same (or very similar) issue. I just installed a new eISY (formerly using ISY994 and ployglot running on Raspberry Pi). I'm trying the trial version of Kasa. I can start a new thread if needed. I'm just doing my due diligence by searching the forum for similar issues before I open new topics (already fixed a couple of unrelated issues by following other threads).
  16. bw23198 replied to bw23198's topic in ISY994
    Following back up on this for reference... It turns out the Micro SD card had some bad sectors. I replaced it with a new SD card and followed the instructions above for the ISY-99i/ISY-26. Restoring the 5.3.0 backup onto the newly installed 5.3.4 ISY994 was not a problem. Thanks all for the help!
  17. bw23198 replied to bw23198's topic in ISY994
    I have a follow-up question now... The instructions below say to install the latest version on a blank SD card, then restore the last backup that was taken before the corruption. I'm currently running 5.3.0, and that's what my backup was taken under. The latest version is now 5.3.4. If I install 5.3.4 on a fresh SD card, can I then restore a backup taken from 5.3.0? ISY-99i/ISY-26 INSTEON:Replacing/Formatting an SD Card - Universal Devices, Inc. Wiki (universal-devices.com)
  18. bw23198 replied to bw23198's topic in ISY994
    So, I think it is, indeed, a bad SD card. I removed the card and connected it to my PC. I saw the corrupted file in the filesystem. I tried to delete it but couldn't (confirming corruption somewhere). I ran chkdsk and it found/fixed a number of errors. However I still can't delete that file and still can't backup the disk due to the file. Strange. I think the path forward is to replace the disk. I may give it a shot next weekend when I have some time. Thanks everyone! -Brian
  19. bw23198 posted a topic in ISY994
    Recently my ISY994 lost everything Insteon. All my scenes, devices, etc. were mysteriously gone from the admin console. So I decided to restore a backup. My most recent backup was from a few months ago and I hadn't done much since then. The restore went well and all of my devices were back again. I added the delta node servers back since the backup was taken. When done I tried to make a new backup. However, it keeps failing around 71% saying it could not retrieve file /CONF/XXXXX. I saw from other postings that the fix is to telnet to the ISY and type RF /CONF/XXXXX. However, the filename is also corrupted and I'm not sure how I would type it at the keyboard. I'm attaching the error I'm seeing. Any idea how I can get past this error and make a new backup? -Brian
  20. MrBill your logic worked perfectly. Thank you! -Brian
  21. Thanks MrBill. I'll give it a shot.
  22. This should be a relatively easy task to accomplish but for some reason I'm struggling. My Christmas tree has 2 strands of lights; each connected to a separate Kasa wifi outlet. One is colored and the other is white. I can control each strand through ISY just fine (using a node server). My issue is with programming them on a timer. I would like to alternate colored lights vs. white lights every 15min from 19:00 until 03:00 the next morning. I've created 2 programs to accomplish this as follows. The first program should take care of the timing. ($s.Christmas is a state variable that is set to 1 at 19:00 and then set to 0 at 03:00 the next morning.) Schedule tree - [ID 00C8][Parent 00EF] If $s.Christmas is 1 Then Wait 15 minutes Run Program 'Alternate Christmas Tree' (If) Run Program 'Schedule tree' (If) Else - No Actions - (To add one, press 'Action') The second program alternates the lights. Alternate Christmas Tree - [ID 00C2][Parent 00EF] If 'Kasa Controller / Color Christmas tree lights' Status is On Then Set 'Kasa Controller / White Christmas tree lights' On Set 'Kasa Controller / Color Christmas tree lights' Off Else Set 'Kasa Controller / Color Christmas tree lights' On Set 'Kasa Controller / White Christmas tree lights' Off The problem is that the lights alternate every 30s or so. Additionally, this continues even after $s.Christmas is set to 0. What am I doing wrong here? -Brian
  23. Thanks. I own a PC so naturally rebooting the ISY was the first thing I tried. I also tried viewing the event viewer but didn't see anything interesting there. Turns out you were spot on with the error log, though. In the log the ISY was failing to resolve the DNS name for the portal. (I guess I missed a checkbox on the router after upgrading to allow the DNSMasq option. Not sure why it didn't affect my other devices). After resolving DNS for the ISY I'm now able to conserve calories and have Alexa manage the lights once again. Thanks!
  24. My portal integration has been down for a couple of days. I upgraded my router firmware about the time that I lost the portal integration. Coincidence? I've not had any Internet issues (that I'm aware of) since the router upgrade and my ISY seems to be working fine otherwise. I just can't ask Alexa to control my lights and I actually have to walk to the switches to control them like it's 1999. ? Does anyone have any suggestions as to where I can start troubleshooting? -Brian
  25. +1 Thank you @randyth! I was bored over the holiday and decided to upgrade all the node servers on my Pi. Many hours of troubleshooting later I came across this post and am back up and running again. -Brian
