Papa C
  1. Papa C replied to Papa C's topic in ZMatter
    This is what it's.sounding like. So, are you using a.switxh to turn on the hue bulbs? New or old hue hub? What kind of delay do you have? Anybody using a "smart bulb" switch? I currently have a multisensor 6 turning on a fixture via an insteon switch. While it is quick, it's still a noticeable delay by the time the sensor "SEES" a person, transmits to eisy and eisy turns on switch. On the other end of the scale I have an insteon sensor two linked to another insteon switch and it is instant.
  2. Papa C replied to Papa C's topic in ZMatter
    Yeah, have done that numerous times. Doing a.lot of reading. Hadn't done much since the the dongle came out and I installed it. Everything I read leads down another rabbit hole with all kinds of new stuff.
  3. Papa C replied to Papa C's topic in ZMatter
    As it was right under a tic box I had dismissed it. Now it sticks but in the admin console it says zmatter zigbee not responding. In mobile if I start a zigbee add it says can't start inclusion.
  4. Papa C replied to Papa C's topic in ZMatter
    Google just told me yes, I can bind the bulbs and the inovelli switch. HOWEVER, they must be on same hub.....
  5. Papa C replied to Papa C's topic in ZMatter
    As they are zigbee I should be able to use zigbee binding to turn the bulbs off and on just like linking a insteon switch and motion sensor. What I'm wondering is when the presence sensor in the switch sees nobody present, and it tell isy to turn the bulbs off.....
  6. Papa C replied to Papa C's topic in ZMatter
    Ok, plan is to have inovelli presence sensing switch bound to the bulbs in smart bulb mode so you can use switch on the wall to turn it off or on AND have the presence sensor to turn it off off unoccupied. But currently under program I sequentially step brightness down at night and up in the morning and want to continue that ALONG with warming the color at night and cooling it in the morning. Is that something handled easily with the hue app? Obviously I'm going to have to use zigbee for the switches.
  7. Papa C replied to Papa C's topic in ZMatter
    So I saw two plug ins in the store. Is this what you're talking about? Which one are you using? These allow the eisy to talk to the hue hub?
  8. Papa C replied to Papa C's topic in ZMatter
    First issue I have is I keep checking the Zigbee support box but when I reboot, it's unchecked? I did buy the ZMatter usb box when it came out. I believe I'm on all the latest firmware, I have updated all packages. What am I missing? How do I turn on zigbee?
  9. Still trying to get zigbee going on my eisy. Am wanting to add hue lights. Trying to decide if they will work fine on their own or if I'd be better with one of the plug ins or with the hue pro hub? Am looking also at wanting to add the inovelli mmwave switches in a few places linked directly to the bulbs for immediate response. Anybody used the new Blue line inovelli switches? With hue? Suggestions, tips?
  10. Maybe that's what's going on with me too? I've been trying to get zigbee working and turned it on last night in configuration rebooted and isy was working . This morning it says 503 can't connect. Portal says can't connect
  11. I'm using a pair of these: https://www.amazon.com/gp/product/B083XGZXRH/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1 for the water supply to my washing machine. It's nice in that they auto shut off on power loss (great for this application), they have others that don't auto close. I control them with https://www.amazon.com/gp/product/B0846DZJD8/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 Not knowing where your valve is, can you not get a 24v supply to the valve location? I have a shut off IN the house added when I added a water softener. I intend (one of these days) to add a controllable shut off there as well and would probably just go with another of these US Solid valves. The ones I have get quite a workout every week.
  12. I just did this very thing this past Sunday. Have an Aeon Switch 6 that won't stay on the network (even prior to eisy/zmatter) and in the course of fighting with it a Multisensor started acting up. After migrating there were "extra" nodes added for nearly everything (and named ZY instead of ZW), so said "what the hell". Blew em all away and started over. As someone said above, you need to EXCLUDE them. As I had less than a dozen devices and have removed and added some a few times they were starting with numbers in the 20's which really grated on me. So, after excluding them all, I reset the Zmatter board and then started readding them. This put them all in, in the order I wanted starting with device ZY 002. Per something I saw here that if added non secure they seemed to work faster, I added the Multisensors I had NON secure. Not sure if their faster or not, but they HAD in the past sometimes dragged to act (second or two from sensor blink to light on) and they seem to bring the light up consistantly faster. A Zooz Zen Relay also during the interview process requested "Unverified" S2 (don't remember the exact wording, but seems to be working just fine as everything else.
  13. Ok.... I had noticed SEVERAL new items with ZY (couple "weather", power, etc) and wondered what they were. Thought it was something new for the eisy. But what's with the ZY now? Is that what ZW will become? There were new items for every ZWave device I have....
  14. Thanks, yeah did the same. Went back to polisy. But wondering where along the line I wound up with the same program with two different names. Any ideas about the Query at startup check box? Wonder, should it be checked?
  15. I migrated yesterday from Polisy/Zooz to Eisy/Zmatter and all went actually very smoothly. The worst of it was dreading issues that just didn't appear. Everything that was working seems to still be working maybe even a bit better. This could be from an update as well that I did to the polisy just prior to migration I don't know. I had started having problems with the programming for the lighting in the kitchen. They seemed to be very slow. You could see when the motion sensor went off and it could be a minute or two when lights would respond. Requesting lights on via Amazon you would hear the sound from the talking tube and sometimes NOTHING would happen, others a minute or two they'd come on. It was like Polisy was just busy. However, other lighting with same programs in other parts of the house worked just fine. After migration they seem to be back to normal? Go figure.... The only things I see amiss is I have two programs highlighted in yellow: "Isy" and "Query". If I remember right, they come from the original isy set up to query settings nightly? I'm sure I just need one of them? tips on putting it right? Or if it's needed? I DO see in the system configuration a "query settings at startup) tick box that isn't checked. Should it be? The only other thing found thus far is a Aeon Multisensor 6 that I had turning on a fan if humidity got to a set level. For some reason there is no humidity available in settings? It has been changed to temperature? I'm guessing I'm going to have to reset some parameters for it? They must have changed somewhere along the jumps from 994 to polisy to eisy?
