Everything posted by Papa C
Trying out zigbee
main reason playing with this is I want to control temp and brightness. I do step down brightness of many bulbs around the house in the evening and step them up in the mornings, but would like to also warm and cool. One reason for trying to add them as zigbee is that you can bond them with a zigbee switch for that "instant" on/off as if they were wired. I have an insteon motion sensor 2 in the utility room linked directly to the switch in that room. You can't even get your hand through the doorway but the light is on. Compare that to another that goes though isy and there is a granted small, but noticeable delay in the round trip. I have a zwave motion switch (multisensor 6) and it is a second or two from the time the led on the sensor flashes till lights come on. I have the inovelli blue zigbee switch with the MMwave I am wanting to put in a bathroom to control the lights in there. Was wanting to put the hue bulbs in there to start. Then I could do away with some of the programming and sensors hopefully relying on the mmwave to determine occupancy. I DO have the last generation of hue hub but my understanding from google is that to bond bulb and switch they need to be on same hub. If I can't get this to work I'll look in to the new pro hub but wanted to try this first. So far, not batting at all. Still can't seem to get the bulbs to actually add. They say they're there but get errors about nodes if I try to adjust color, brightness. Just tried to add the inovelli and similar results. It gets added to the list, but no info. Also, after the interview and number was added to device list, the switch flashed red then went back to blue. It should have flashed green so don't believe it was actually added. I've just started trying out zigbee. First attempts revealed that my dongle was bad from the start. I had zwave but no zigbee. Michael did replace the bad board but still stuck trying to actually successfully add anything zigbee.
Trying out zigbee
There is no zigbee network yet. I was testing, trying to add these two bulbs. Got them in a lamp plugged in near the eisy. I HAD tried the admin console before. Did it again but one of them came back. Did it again, rebooted eisy and it seems to have done it. Synced from admin, then checked mobile.and synced there. That all seem to be gone. What you said about being in iox might be part of it. Id say remove, delete, and reboot. NOW if I can get it to actually fully add the hue bulbs we'll be rolling.... Better to do that from admin mobile? Somewhere I saw someone someplace say you need to add zigbee from mobile?
Trying out zigbee
Believe I did that but will give another try to be sure. I've done this for both admin console and the app on the phone. On the phone they'll disappear until I synchronize then they're back. I've done this with zwave without issue. This zigbee is just not cooperating. First I find that the zigbee is bad in my dongle, Michael took care of that but still going nowhere fast. It's not so much changing colors, although turning red under certain conditions could be good, it's more about dimming and changing temperature. I do the dimming as it is, but I'm wanting to warm them throughout the evening and cool them during the day.
Trying out zigbee
I'm trying out zigbee. I've got a couple of hue bulbs, a white and a color. I've managed to add the white twice and the color once. None of them work. If I try to access color, brightness, or anything it gives me a message not available. I had added via eisy.and via the app. Nothing. So, try to remove from the list to see about starting over but won't let me delete. How can I remove? Tried remove, delete, even reset zigbee. What am I missing?
Eisy, zigbee and Hue?
This is what it's.sounding like. So, are you using a.switxh to turn on the hue bulbs? New or old hue hub? What kind of delay do you have? Anybody using a "smart bulb" switch? I currently have a multisensor 6 turning on a fixture via an insteon switch. While it is quick, it's still a noticeable delay by the time the sensor "SEES" a person, transmits to eisy and eisy turns on switch. On the other end of the scale I have an insteon sensor two linked to another insteon switch and it is instant.
Yeah, have done that numerous times. Doing a.lot of reading. Hadn't done much since the the dongle came out and I installed it. Everything I read leads down another rabbit hole with all kinds of new stuff.
As it was right under a tic box I had dismissed it. Now it sticks but in the admin console it says zmatter zigbee not responding. In mobile if I start a zigbee add it says can't start inclusion.
Google just told me yes, I can bind the bulbs and the inovelli switch. HOWEVER, they must be on same hub.....
As they are zigbee I should be able to use zigbee binding to turn the bulbs off and on just like linking a insteon switch and motion sensor. What I'm wondering is when the presence sensor in the switch sees nobody present, and it tell isy to turn the bulbs off.....
Ok, plan is to have inovelli presence sensing switch bound to the bulbs in smart bulb mode so you can use switch on the wall to turn it off or on AND have the presence sensor to turn it off off unoccupied. But currently under program I sequentially step brightness down at night and up in the morning and want to continue that ALONG with warming the color at night and cooling it in the morning. Is that something handled easily with the hue app? Obviously I'm going to have to use zigbee for the switches.
So I saw two plug ins in the store. Is this what you're talking about? Which one are you using? These allow the eisy to talk to the hue hub?
First issue I have is I keep checking the Zigbee support box but when I reboot, it's unchecked? I did buy the ZMatter usb box when it came out. I believe I'm on all the latest firmware, I have updated all packages. What am I missing? How do I turn on zigbee?
Still trying to get zigbee going on my eisy. Am wanting to add hue lights. Trying to decide if they will work fine on their own or if I'd be better with one of the plug ins or with the hue pro hub? Am looking also at wanting to add the inovelli mmwave switches in a few places linked directly to the bulbs for immediate response. Anybody used the new Blue line inovelli switches? With hue? Suggestions, tips?
How much longer until the portal reconnects?
Maybe that's what's going on with me too? I've been trying to get zigbee working and turned it on last night in configuration rebooted and isy was working . This morning it says 503 can't connect. Portal says can't connect
Best ISY supported "smart" water main shutoff valve?
I'm using a pair of these: https://www.amazon.com/gp/product/B083XGZXRH/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1 for the water supply to my washing machine. It's nice in that they auto shut off on power loss (great for this application), they have others that don't auto close. I control them with https://www.amazon.com/gp/product/B0846DZJD8/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 Not knowing where your valve is, can you not get a 24v supply to the valve location? I have a shut off IN the house added when I added a water softener. I intend (one of these days) to add a controllable shut off there as well and would probably just go with another of these US Solid valves. The ones I have get quite a workout every week.
Insteon is working fine but ZWave has troubles. Should I just start over?
I just did this very thing this past Sunday. Have an Aeon Switch 6 that won't stay on the network (even prior to eisy/zmatter) and in the course of fighting with it a Multisensor started acting up. After migrating there were "extra" nodes added for nearly everything (and named ZY instead of ZW), so said "what the hell". Blew em all away and started over. As someone said above, you need to EXCLUDE them. As I had less than a dozen devices and have removed and added some a few times they were starting with numbers in the 20's which really grated on me. So, after excluding them all, I reset the Zmatter board and then started readding them. This put them all in, in the order I wanted starting with device ZY 002. Per something I saw here that if added non secure they seemed to work faster, I added the Multisensors I had NON secure. Not sure if their faster or not, but they HAD in the past sometimes dragged to act (second or two from sensor blink to light on) and they seem to bring the light up consistantly faster. A Zooz Zen Relay also during the interview process requested "Unverified" S2 (don't remember the exact wording, but seems to be working just fine as everything else.
Polisy/Zooz to eISY/ZMatter Migration
Ok.... I had noticed SEVERAL new items with ZY (couple "weather", power, etc) and wondered what they were. Thought it was something new for the eisy. But what's with the ZY now? Is that what ZW will become? There were new items for every ZWave device I have....
Thanks, yeah did the same. Went back to polisy. But wondering where along the line I wound up with the same program with two different names. Any ideas about the Query at startup check box? Wonder, should it be checked?
I migrated yesterday from Polisy/Zooz to Eisy/Zmatter and all went actually very smoothly. The worst of it was dreading issues that just didn't appear. Everything that was working seems to still be working maybe even a bit better. This could be from an update as well that I did to the polisy just prior to migration I don't know. I had started having problems with the programming for the lighting in the kitchen. They seemed to be very slow. You could see when the motion sensor went off and it could be a minute or two when lights would respond. Requesting lights on via Amazon you would hear the sound from the talking tube and sometimes NOTHING would happen, others a minute or two they'd come on. It was like Polisy was just busy. However, other lighting with same programs in other parts of the house worked just fine. After migration they seem to be back to normal? Go figure.... The only things I see amiss is I have two programs highlighted in yellow: "Isy" and "Query". If I remember right, they come from the original isy set up to query settings nightly? I'm sure I just need one of them? tips on putting it right? Or if it's needed? I DO see in the system configuration a "query settings at startup) tick box that isn't checked. Should it be? The only other thing found thus far is a Aeon Multisensor 6 that I had turning on a fan if humidity got to a set level. For some reason there is no humidity available in settings? It has been changed to temperature? I'm guessing I'm going to have to reset some parameters for it? They must have changed somewhere along the jumps from 994 to polisy to eisy?
Polisy vs Eisy???
I'm kind of in the same boat. Seems like I just got the polisy pro what a year ago maybe (whenever it came out). I just got the new board for the polisy and was waiting on the fixes to install it and BAM! Here's a whole new system to buy.... But every time I start to load all that in my cart for purchase I look in here and it sounds like one big hair ball of heart burn... I've had a few issues with the Polisy that I didn't have with the isy and it sounds like there's lots of bugs to iron out of the Eisy. Not sure I want to retire yet another UD device in favor of the new shiny till maybe it's a bit more polished? In the mean time I've got an Isy IR pro with the 500 board that not sure what to do with and not really ready to add a polisy pro to the pile.
Programming window resize?
Is there a way to resize the program content window? It was always more or less maximized with the "Add to program" being just large enough to see everything and the "Program Content" occupying the rest of the screen. Somewhere along the way, don't recall if it was the move to a new laptop along with win 10 to 11 or the jump from ISY to IoP but every time when I initially log into ISY and load the programming windows the Content window is just a couple of lines at the top of the screen and Add to occupies the rest. I can grab the bar in the middle and drag it down, but is there some way to make it stick?
What's the correct URL to access remotely?
"@Michel Kohanim tells you the super secret trick" Now if I did that it would loose it's "super secret" status! ......
Right, I DO hit save. That's what I've been referring to. Isn't that what saves the finder file? I save it on the desktop so it's right there with the launcher file. I KNOW this works because I've done it before and has worked for quite a while. Was even working when I first migrated from ISY to IoP. It just stopped after the upgrade from 5.4.2 to 5.4.3. I'd seen the reference to adding a port number to it pop up and was searching back trying to find it to see if that was something I was needing to do when I ran across your post about it. But it really sounds as if that is only for local access which works perfectly for me. It populates the launcher just fine when I'm local, it's only when I'm remote that those extra lines don't show up.
Yes, that's it exactly. I use a laptop. As before I wipe all the launcher info, go to the portal as pictured above and copy and past the info line into the finder (I've done this both at home and in the office). I've then saved the info and can log into IoP. However, if the next day I try to again log in from the office I cannot, I have to go to the portal and get the info again. I CAN log in via launcher any time I'm home (on the same network). It's like it isn't saving the info from the portal?
Question: Does this: Enter https://polisy:8443/desc into the dialog Apply for trying to access IoP via the portal? Initially everything worked fine. Could access IoP from home directly and via portal. Then after upgrading to 5.4.3 it's like it keeps loosing the portal logon. It finds and logs into it fine from the local network, but if I'm remote and run the launcher it only has the first line without a type. If I ADD the info line from the portal it I can log in fine but saving seems to do nothing. It DOES create the finder file but obviously something is off. I've redownloaded the start file multiple times, deleted everything, even rebooting pc afterward, to no effect. Do I take the info line from info, and replace the "/isy/ portion with the above line?
