jjc
Everything posted by jjc
  1. Same here PG3x not starting after upgrade, ticket opened.
  2. I dont think you can install the android adb tool on a polisy. You can check with @Michel Kohanim if this is possible. This Node Server was originally written in PG2 and was ported as is to PG3, so the code is still there if you can get the adb tools installed.
  3. I had these exact same symptoms a few days ago after an update. Turns out there was a problem with the udi repositories which were fixed so this should not have happened if you just did an update today. You need to open a support ticket and have Michel determine the cause.
  4. @btreinders If you make a change from somewhere other than the NS the update is done via polling. Polling was defaulted at 60s in PG2, its the same in the PG3 port. You can change shortPoll in the GUI, but it doesnt make sense that volume updates fine but not the power state. The device drivers are all a direct copy from PG2.
  5. sudo pkg remove pg3 sudo pkg install /var/cache/pkg/pg3-3.0.48.pkg sudo service pg3 enable sudo service pg3 start
  6. Looks like version 3.0.50 removed the ability to install a Local Node server. Also Local node servers I previously installed will no longer start. I had to go back to version 3.0.48. Going forward what is the procedure to install Local node servers?
