dantoronto
  1. down in Toronto also NOW WORKING!!!
  2. thanks so much for all your skill and patience. I agree with the comment that we rarely see outages. But clearly many of us are highly dependent on this service. Can't imagine a life where I actually have to touch a light switch!!
  3. ISY went offline again.
  4. rebooting a second time worked. What happened???
  5. I have rebooted. Not fixed. I can log into the admin console and the devices do respond. I log into the UD Mobile app, Get an error message "Requested ISY not online". In my notifications I get eisy xxxx Notification. Node Server Free Edition Startup. Please upgrade to Standard version to get all features. All my Plugins seem to be Connected.
  6. Thanks so much to UD team for their great support. Timing was weird, came home from a new year's celebration to a dark unresponsive house. Thanks
  7. With the portal down, there does not seem to be a way to notify UD or submit a ticket. How do we know that they are aware of the problem or working on its solution??
  8. same here. Working 4 hours ago. Anything to do with 2025???
  9. For the record. The forwarding of port 3001 should be to the IP address of the ISY/eISY and not of the Rachio. Restart the Rachio node and voila, the Rachio data shows up in the Admin console. OPTIONAL: Key: 'port' Value: External port (integer) for polyglot server. Note: This port must be opened through firewall and forwarded to the internal polyglot server. Defaults to '3001' if no entry given but opening port is not optional (required for Rachio websockets). or required or used for polyglot cloud.
  10. Thanks for your response. My configuration looks right. As I said, my sprinkler zones get listed in the admin console. But no data appears. Sigh
  11. One last (I hope!!) question. Not sure if I misunderstood your instructions. In my ELK, you advised that under M1WEP Setup / TCP/IP Settings, I should enable non-secure port and set it to 2101. Which I had. And that in the configuration for the ELK Node, under host, you said to put in the IP address for my ELK with ":2101", e.g. 192.168.xx.yyy:2101". And this all now works!! My question is whether on the first page of my ELK account details, I have have for the "Port to use for connecting", I should/must have it set to the non secure port or can I have it set to the secure port. All the material I have read or seen has that setting as the secure port. Am I less secure? And will the connection work if that setting is the secure port? You had previously said: > Host: the IP Address for the ELK with 2101. 192.168.50.xx:2101 Please confirm with ElkRP2 that unsecure port is allowed and is set to 2101. That is correct. and yes, if someone is able to get onto your LAN they can connect to the unsecure port, but they still need a user code to arm/disarm. I could allow connecting via the secure port, but then would have to store the username/password in PG3 which does not yet have a secure way to store the data. Thanks much
  12. and in the port forwarding, does it matter which protocol? TCP or UDP or both?
  13. sorry, could you please explain that in less technical terms? 1. I have the API key from Rachio 2..for Host, I have the external WAN IP for my modem. from www.whatismyip.com Correct?? 3. 3001 And in my router, I port forwarded 3001 to the IP address for my Rachio. Correct? I get my sprinkler zones listed in my admin console but no data shows up. Thanks
  14. sorry. I thought you sent me a note to move this to this topic. Yes, you solved my problem. Perfectly. Thanks
  15. For years, I had my ISY connected perfectly to my ELK. I was able to create ISY programs which allowed me to tell Alexa to arm our alarm alarm, our alarm away and our alarm vacation. All was great. For whatever reason, I decided that it was time to upgrade from ISY to eISY. For no other reason than to support UD and to future proof. Migration certainly wasn't easy but Michel and his crew were amazing. I finally got most features up and running. But not my ELK module I purchased in the Polygot. I am certainly not an expert techie. Or even very good. But I read everything I could to figure out how to properly configure. The post by zorax2 was especially helpful Initial Elk Setup for eisy (Note: Elk Module for ISY-994 does not work on eisy) I followed each step. I think exactly, In my router, I port forwarded 2101 for the IP address for my ELK. I used TCP as the protocol. I could have also used UDP or Both. I created a static address for the IP address for my ELK under the MIXEP Setup / TCP/IP Settings My ELK Polyglot configuration is: Host: the IP Address for the ELK with 2101. 192.168.50.xx:2101 user_code: used the password we use to arm or disarm our ELK keypad areas: 1 outputs: 1-16 change_node_names: false light_method NONE But still I do not get the following steps in zorax2's post: 15. If successful, the Elk Controller and Elk Outputs, Zones and Controllers will show up on the left side where your devices are found. 16. At the top of the list of names of your zones will likely be “Home”. Click on “Home”. This will bring you to the current status of Area 1 of your alarm system. There is now a dropdown box that you can change to arm, disarm, etc. Choose what you would like to do and then click the dialog box “Set armed Status” to whatever you’ve selected. This process is different from the Elk Portal Module where the Armed status was listed next to the “Main”, “Programs”, “Configuration” part of the Administrative Console. On the admin console, I don't have Elk Outputs, Zones and Controllers. The Elk Controller says that NodeServe Online is "Connected". Remote Programming Status is "Disconnected" Everything else is "False". And under Programs / Actions, I can't get a pull down for ELK Controller to get ELK to arm itself in a program. Please, what am I doing wrong??!!
