chris.com
Everything posted by chris.com
  1. I just thought everyone might be interested to know... Now that Google has shut off cloud functionality to the Gen 1 and Gen 2 Nest thermostats, programmers are trying to flash the firmware to make them functional again. Louis Rossmann put out a bounty for a fix. You can hear details about it here: https://youtu.be/LsI6P2lxcHM and here: https://youtu.be/QVbUdvuSt50 There is already a github with a fix that's in early testing: https://github.com/codykociemba/NoLongerEvil-Thermostat What would be truly awesome is if we were able to flash the Nest with custom firmware that let it talk to a eisy polyglot node. Not sure I have the chops for such an endeavor, but I am tempted to see how far I can get. Is anyone else interested? I'll report back with updates to this thread if/when I learn more about the status of the various solutions that emerge in the coming weeks/months.
  2. Today, I did an update and reboot of my eisy and this problem disappeared. The dimmer slider seems to function exactly as one would expect now. Did this get fixed? If so, thank you!
  3. This is an Insteon 2477D Dual Band SwitchLinc Dimmer v.45. When I created the tile, I selected "Dimmer" from the "Create As" dropdown. I have created other tiles for other dimmers. They all seem to work the same way.
  4. Congratulations to the UD developers. Today is an exciting day! Sorry the forum $#!T the bed. Glad it's back now. I did the upgrade. So far so good. Lots to play around with and talk about. Some initial questions: 1. There doesn't seem to be support for Insteon Scenes in the new web ui. That's fine if that's the case; I assume it's coming. Or, is it there and I'm just not seeing it? 2. How do I log in to the eisy via ssh? The old method root/root no longer works and I have been unsuccessful guessing what will work. 3. Check out the attached video clip. Is this how the dimmer slider is supposed to work? When you click on a position the light does seem to go to that percentage, but the slider springs back up. And we have two values, an 8-bit value and a percentage. It gets weirder when you click the up and down arrows next to the 8-bit numerical value. Thanks again fellas. I'm looking forward to exploring all of the new possibilities. 👏👏👏👏 Weird Dimmer.mov
  5. Just curious... Any developments on the UI issues mentioned in this thread? They persist in the latest versions.
  6. For the last few days, TotalConnect has been failing with this error: 2025-01-27 07:41:40,638 Thread-996 (poll) udi_interface INFO totalconnect-poly:authenticate: Re-authenticating 2025-01-27 07:41:40,638 Thread-996 (poll) udi_interface ERROR totalconnect-poly:authenticate: Could not re-authenticate 'NoneType' object has no attribute 'authenticate' Traceback (most recent call last): File "/var/polyglot/pg3/ns/[redacted]/totalconnect-poly.py", line 124, in authenticate self.tc.authenticate() ^^^^^^^^^^^^^^^^^^^^ AttributeError: 'NoneType' object has no attribute 'authenticate' (I redacted part of the file path. It was the only part of the message that seemed like it could be unique to me so I took it out just in case.) Any thoughts?
  7. @dbwarner5 The nice thing is that once you have things set up how you want on your Mac, you can export the app's settings, airdrop that settings file from your Mac to the iPhone's or iPad's "Files" app, and then import that settings file into the UDMobile iOS app. It's quite fantastic. 👍
  8. @dbwarner5 From what I understand, when Apple first released desktop Macs with Apple Silicon, they opened up the App Store on the Mac to allow you to install any iOS application (since the Apple Silicon desktop processors are the same type of ARM processors that run iOS devices.) Not too long after that, some developers objected because they felt they should be in the position to decide whether their app would be available as a desktop app. Apple capitulated and allowed developers to decide if their iOS apps could be downloaded using the MacOS desktop App Store. Fortunately for us, @Javi and the folks at UD did not put that restriction on UD Mobile. And Javi has been very kind to address and fix several issues with UD Mobile running on MacOS. And I'm grateful since being able to run it on my desktop and laptop computers has really been wonderful. @dbwarner5 BTW... I do use several folders on the Favorites screen. But for the most part, I like having most items at the root level. Just a personal preference... I prefer to scroll up and down rather than drill in an out. (if you'll pardon the expression. 🙃 )
  9. Hi there. I'm running UD Mobile on my M4 Mac Mini (Sequoia 15.2) I've noticed two somewhat strange behaviors on the favorites screen. When scrolling down to the bottom of the favorites tab, the window cuts the names off the favorites that border the bottom of the window. Resizing doesn't reveal them. (This is demonstrated in the first part of the attached clip.) I feel like based on the contents of the various favorites tiles (the icons and title widths,) I should be able to get the window quite a bit narrower. It seems to have a strange an arbitrary point at which making it narrower causes everything to repaginate awkwardly. (This can be seen in the last part of the video at around 13 seconds in.) Anyway... it's not a showstopper, but I thought I'd bring it to your attention. As always, thanks so much for all the incredible work you've done and continue to do on this app. Always grateful. -Chris ud mobile.mp4
  10. chris.com replied to mmb's topic in eisy
    I do not disagree. My point is that the Java app is a significant barrier for many people. Not people like us, but to people like my friend Warren for example. He loves tricking out his home and he's got lots of disposable income. He's jealous of all of the home automation I've got running with eisy/insteon/etc and would gladly shell out thousands of dollars to do it at his house. But when I showed him the app, he started asking questions. I'm paraphrasing, but the conversation went something like this. "When you start the app, why do you have to do that thing with the IoX Finder?" "Not 100% sure. I think that if you have multiple eisys, you can pick which one to launch the Java app with." "What's Java?" "Java is a runtime that you have to install on your computer in order to be able to run the eisy app." "Runtime?" "Yeah... it's kind of like an interpreter. A developer can write just one base of code and the then the runtime for that operating system allows that single code base to run." "Why is that necessary?" "Because when they developed the interface, Java was probably the most economical way to get it running on any platform." "So it'll run on anything? Do you install Java on your iPad in order to run the app?" "No. The Java runtime isn't a thing on iOS. iOS doesn't really do 'runtimes.'" "So what if I want to use my iPad?" "You can; there's an app you can download for your iPad, but it doesn't do everything the Java app does." "Why not?" "I'm guessing it's partly because it's still being developed, but probably partly because of some inherent limitations of mobile apps." "So in order to do everything that I might want to do, I HAVE to have a regular computer." "Right." "My computer was issued to me by my job. They probably wouldn't like me installing all that on there." "I suspect that's true." "My wife has a Mac. I could install it on there, but then I'd have to borrow her computer every time I wanted to make programs and do stuff." "Yeah." "Yeah... I'm out." If Universal Devices could create an experience where my friend Warren and people like him could just buy it, get on board, and get a few things working quickly and easily, they would have a whole new market. To use a pool analogy, the deep end is great for us nerds, but people are intimidated by jumping into the deep end. There needs to be a kiddie pool and and a shallow end so that people will be encouraged to get in the pool in the first place and then work their way to the deep end. I think the Java app is part of what makes the eisy platform a bridge too far for many people.
  11. chris.com replied to mmb's topic in eisy
    Agreed. I use Ubiquiti Unifi routers, switches, and WAPs. Their web interface is a beautiful example of eisy's potential. I hope they are eventually able to deliver a similar experience. Putting a bullet through the java app will no doubt be a game changer for existing users. But I suspect it will be a game changer for Universal Devices as a company, making the platform far more accessible to many more customers. I also hope that the journey to feature parity doesn't drag on for years. (See Google Voice.) Fingers crossed. 🤞
  12. chris.com replied to mmb's topic in eisy
    There's some very exciting and welcome news in this announcement! I am confused on one thing: it mentions OS 14.1. Are we going from version 5.8.4 to 14.1? That would be quite a jump. Or is 14.1 some other operating system component I'm not clued into?
  13. All of the devices appear to have status on the home tab. I suppose it's possible for status to be temporarily lost for some reason. In my case, I don't know why that would be the case. What you're saying definitely makes sense; toggling would certainly require status. In any case, it's not a show stopper and it's fairly easy to solve. Easier now that I understand the logic behind it. Thank you @Javi!
  14. My favorites tiles all have a horizontal white line that separates the icon from the name of the device. If I tap on the icon, it turns that device on/off. If I tap on the name, it invokes that device's dashboard. I've noticed that when an item first gets added to Favorites, it doesn't have a white line separating the icon portion of the favorites tile from the title. (See attachment.) When this is the case, clicking on any portion of the tile calls up that devices dashboard. There is no option to turn the device on/off directly from the favorites tile. Not until that device's dashboard is used to turn the device on or off for the first time does the favorites tile get divided with the horizontal line. Once it has the line, clicking on the icon turns the device on/off and clicking on the name invokes the device dashboard. Anyway... it took some twiddling to figure that out. Not sure if that's the intended behavior, but it was a bit confusing to me and perhaps it may be to others.
  15. @Ross Thank you for your post. I'm experiencing the same thing you are with the moon phase being a bit off from what I think it should be. Suppose we assume that the moon phase value in the plugin denotes the number of days since the last new moon. According to Wikipedia, a synodic month can be as short as 29.27 days and as long as 29.83 days, with the average being 29.53059 days. So let's just pretend that it's 29.53059 days every time. Right now, my plugin says the moon phase is 19.71. Would it be reasonable to calculate the moon's percentage of fullness this way? Moon Phase Value in Sun Polyglot plugin x 100 ÷ 29.53 or.... 19.71 x 100 ÷ 29.53 = 66.74568236% Timeanddate.com calculates the moon percentage in my location at 62.3%. However, nineplanets.org says it should be 69.34%. Sky-tonight says 61.4%. Not sure who to believe. I'm not entirely certain that this moon phase value really is the exact number of days since the last new moon. According to this post, the plugin calculates its values using Astral. And according to Astral's documentation: Not sure how Astral decided that 27.99 would be the number. That's definitely not a synodic month. Are they using a sidereal month? According to Wikipedia, a sidereal month is 27.321661 days. That's close to 27.99, but not quite. Maybe they rounding up? Not sure. But let's try the calculation again: 19.71 x 100 ÷ 27.99 = 70.41800643% That's off from timeanddate.com's 62.3% calculation by an even greater amount, but closer to nineplanets.org's 69.34%. And then there's this in Astral's documentation: If I'm understanding that correctly, it doesn't take your location into account when calculating moon phase. Of course your location does affect when the moon rises and sets. But, from what I've read, your location shouldn't make a noticeable difference in how full the moon looks. It can affect its orientation and its position relative to other stars however. FWIW, in my opinion the moon phase being expressed in this way (a not-quite-accurate sidereal month) is probably the least useful way I can think of. I would prefer the addition of the following values: Percentage Full: 0 - 100 Waning or Waxing: 0 or 1 Next full moon date & time Next new moon date & time Last full moon date & time Last new moon date & time Eisy allows us to schedule events based on sunrise and sunset. It would be nice if we could also include moonrise and moonset as well. (This does require latitude and longitude to calculate.) Of course, in order for this to come to fruition, Astral would have to be updated to produce these values, and/or the Sun polyglot plugin would need to find a different way of procuring and calculating the data. I guess to be fair to the authors of the plugin, it is called "Sun" and not "Sun and Moon."
  16. chris.com replied to chris.com's topic in AudioPlayer
    @TUhl01 Upon visiting the aforementioned URL to see what udx verion I was running, I discovered an interesting result: ************ UDX ************ udx-3.5.6 Name : udx Version : 3.5.6 Installed on : Sun Mar 17 07:07:29 2024 PDT Version 3.5.6 was installed on Sunday morning at 7:07:29. That's interesting since I was asleep at that time. Also, 3.5.6 seems to exceed the "3.5.5_6" version mentioned as a requirement. In @Michel Kohanim's post he also says this version must be installed before installing the plugins. Not sure if I was on 3.5.6 before attempting to install the plugins. Perhaps I shall uninstall them and reinstall them and see what happens.
  17. chris.com replied to chris.com's topic in AudioPlayer
    I attempted to use an Amazon Echo Show. After a dozen failed attempts to get it to pair, it finally did. Not sure what I did differently. While it was working, sounds were glitched and sometimes had static. Other times, sounds were cut off at the end. It quit working spontaneously and I couldn't get it to work after that. The announcement I received via e-mail only mentions needing eisy firmware 5.8.0 and above, however it sounds like it may not actually be fully baked quite yet... In this announcement for AudioPlayer Version 1.1.0 - Professional, @Michel Kohanim mentions the following:
  18. chris.com replied to chris.com's topic in AudioPlayer
    The two main ones we use in our household are: "The garage door is opening." "Front door" (There's motion activity at the front door. It's nice to know exactly when those packages get dropped off or if someone is approaching.) I can think of several more.... If it's after a certain time in the evening, alert you that your front door is unlocked. "Back door" (possibly modify the wording) Announce motion sensor activity at any point of ingress or egress. Using the geo fence feature on UD Mobile, you could announce when certain family members are leaving or arriving. "It's after midnight and your teenage daughter's bedroom window has opened." The possibilities are endless. Of course, everyone will have their limits on how much they want to listen to a speaker squawk stuff at them.
  19. chris.com replied to chris.com's topic in AudioPlayer
    Thank you @garybixler. That does give me somewhere to start. Much appreciated! 🙏
  20. chris.com replied to chris.com's topic in AudioPlayer
    Thank you very much for the help. I think I'm more clueless that you might realize. Some questions: 1. Where can the audio player config page be found? In the Polyglot dashboard, in the UD Administrative console, or somewhere else? 2. "It should show up on the play list." Where is the play list found? 3. I'm seeing that MP3 files can be played. Where are these files stored and how does one transfer these files to that storage area?
  21. chris.com posted a topic in AudioPlayer
    I was delighted to learn about the Audio and Bluetooth plugins. I have numerous events I would like the eisy to announce. I have installed the Polyglot 3x plugins and started poking around and found myself wondering what to do next. Sorry for being a bit dense. Is there some kind of tutorial or step-by-step guide on setting up and configuring audio and bluetooth and making an announcement happen? I looked and looked but couldn't find anything.
  22. What would be even more useful to me would be to have a small palette (maybe ten) of my chosen colors. I actually don't mind using the existing hex system to define what those colors are since I'll probably only have to do that once. Once I have chosen the colors I want, I would like to be able to easily select them from my favorites palette when necessary. Thanks again @Javi for all your hard work on the app. It has passed the "wife test" for usability which is a very high bar. Congratulations.
  23. Thank you, @paulbates. This was a very educational read. 👍
  24. We're coming up on a year since the last post in this thread. If someone with an appropriate knowledge base would be willing and magnanimous enough to do so, I would love to get a "state of the union" when it comes to eisy and Matter support. The curated answers to general eisy questions says, "Since there's nothing in the wild to test with, no one can say how it will work or what can/cannot be done." I would have to believe that's changed at some point in the last year. I do see a few Matter compliant products on the market. There are a few forum posts with questions about Matter products, but very little information to be found. ARS had an interesting article on Matter recently which would lead me to steer clear of it for the time being. Anyway, some recent thoughts on the "matter" from guru-tier forum members would be educational and appreciated. (Merry Christmas, BTW.)
  25. chris.com replied to bmercier's topic in UD Portal
    Thank you for the update. This had me spinning my wheels for a while last night. After checking everything up one side and down the other, I concluded that the problem was unlikely to be on my end. And it must have been quite challenging on your end when all your services are running fine but only a portion of your users are having issues. What would have been nice for me is to be able to see if other users besides myself were experiencing outages. Perhaps there could be a forum section where users could report their outage so others can see that they're not the only ones. One other thought... When I looked at the help->about in the admin console, "Internet Access" is shown as "Disabled." After chasing that down, I found a forum post in which @MrBill explains that's a bit of a red herring. It might be helpful to change the verbiage on this as he suggests.
