junkycosmos
  1. Is there not a way to see if the device provisions as LR in the device zwave details ?
  2. following along here My own setup has a single KLF200 with 5 groups set / then I hard wired 5 Zwave I/O devices to the sense inputs of the KLF200 / assigned these 5 io sensors in my ISY as names that match my 5 groups. It's crude and it works but is only 1 way (the zwave control to KFL controlling the groups of Velux). While I did wire the KLF outputs to the input sensors on the zwave devices I found the "feedback" back to Zwave io to be unreliable. I suspect more of it being the Zwave io devices I used which are old gen1 zwave stuff. Recently was just looking at the KIX300 which would just put Velux directly on my phone w/o any home automation. Not ideal but I did want to mention if anyone picks up the effort to code a plugin interface with the KLF200 would be great since it has the flexibility but the KIX300 seems to be velux's "modern" gateway. Completely different hardware any no idea if there is an open API interface to call etc.
  3. Figured the search showed at least a year old on the topic. Wanted to share that in last 3 months I have had 4 more ISY994 power supplies all die. All had been running continually for 8+ years, all were in ranging envs of heat but all in dry env. Last one was funny in that is browned out - ISY would periodically reboot every 3-12 hours for the last week. After doing an unplug and replug it ran for 3 more hours then died completely. Really kinda speaks to how well the ISY994 was build and its ability to be browned out on power then restarted multiple times with ZERO impact to long term run health. Such a bummer that the new hardware really cannot tolerate power cycles !!
  4. Am I missing something here ? In UDI mobile I can edit or create Program Automations but do not see how to set with a variable. such as IF variable X is set to 1 i know we can do this on admin but not via UDI Mobile ?
  5. Thx and for the 1st time in 15yrs the timeout should be tweaked to be 5 sec instead of good old default 1 sec. Good thing we can handle a potentially extra 4 sec delay in mail messages showing up.
  6. EDIT:: FIXED .. change SMTP timeout from 1,000 to 5,000 is fix for SMTP on 5.9.1 Was there any fix for the SMTP issue? I just updated the EISY today (update went smooth, just used the update package button in AC). I have tried changing the default timeout from 1,000 to 2K, 5K and 20K. Using smtp.comcast.net, was working on 5.8.4 and is still working on my ISY994 on 4.9.1. In the AC, if I go to Configuration > Emails/Notifications > Settings/Groups and click on Test, several seconds go by and then a window pops up with "Mail server failure" and "[[SMTP_ERRORS--1]]" (same as reported in this thread 2/15) EDIT: For me changing the timeout from 1,000 to 5,000 and ensuring I retyped the password correctly (uumm ya, that part is on me..) fixed it. So .. still outstanding Q on what changed for SMTP with 5.9.1 but the work around is to up the timing as prior noted in this thread.
  7. thanks much, do appreciate it - my post here was only after 30mins hunting around on the forums coming from long time ISY994 new EISY user. Not meaning to give anyone a hard time but the branding here needs work ... are these PG3 Nodes, EISY Plugins, or perhaps EISY Integrations .. I suppose part of that is are we running EISY or PG3 and ISY .. or ya we just lost 95% of the new market in this line .. OK for others .. (correct me here if wrong please) ISY -> EISY -> hosting PG3 (which loads NODE SEVERS) as plugins and which the ISY can then pickup. Now is the ISY actually running as a NODE on the PG3 or as image on EISY ? UDI Integration Store / PG3 Node Servers / EISY Plugins https://polyglot.universal-devices.com/ also the store could use some work too example Home Assistant integrations gives https://www.home-assistant.io/integrations/#all
  8. Where is the best place to see the list of available plug-in programs for the EISY?
  9. Interesting idea here. I agree about the confines of Java and also long allegiance to Team UDI. This is an interesting project here - ultimately, I agree. It would be nice to be able to run both in parallel on the EISY - but portability is key for redundancy… Can we talk redundancy here for a minute? How portable is the back up of Home Assistant in this configuration? I.E if the EISY has a hiccup can you get your Home Assistant back up, running on another piece of hardware easily?
  10. @johnstonf - how goes your process here? I can relate, I think I’m in the same spot you posted. I’ve had my EISY for a year now…. My second attempt migrating was following the directions just to move the Insteon on Network with plans to manually reset and manually add all of the Z wave. Glad I did it that way because it was very easy to roll back from and go back to my ISY994. (just moved the PLM back to the ISY994 and plug it back in) Which Z wave locks do you have ?
  11. oh I didn't mention but the cross roads I am at 1x isy994 with 300+ devices = willing to dump all off the Insteon devices for something like Lutron casita OR keep and do EISY 12x other locations with ISY994s in them - some with 2-3 devices or simple setups like monitor for flood / control a light or lack of motion etc. Kinda spendy to buy a bunch of EISYs .. but honestly would IF the readability was close to ISY ... without needing ongoing hobby support .. (wish that was better understood by UDI) .. if we wanted hobby devices we probably wouldn't have bought ISY994 in the 1st place and have been running HomeSteer, HA, or the other junk which was on market. Could do some of these on Home Assistant with cheap Raspberry Pi units to meet the needs and that maybe the way we roll here.
  12. Also long time user here, just trying to count, ummm 16yrs here. Started with ISY99 .. Here this will date me .. ONE OF THE FIRST users to have the ALL ON events after moving to the ISY994 and battery powered devices. RIGHT not UDI's fault on the ALL ONs .. just same as the bad SD cards (use of fake SD cards permitted the market and killed many products) .. but I would put it this way. When someone steps out into a busy street - do you try to avoid them if you can or do you just say 'oh not my fault' and mow them down. Right, even if you are one of those guys you probably chicken out last minute and do the right thing. So to Michel's credit UDI did a crap ton to hold up Insteon over the years. I am not in the position to say if more could have been done on the topics of: ALL ON, random link losses, PLM deaths due to overheated capacitors, poorly implemented firmware options in devices. Enter Zwave - huge credit on to UDI for jumping in - a solid jump in, how many different Zwave boards did they do? Ok now ISY hardware often struggling on larger setups but super reliable - yank the power and you can always expect your ISY to restart (ok if your power supply hasn't overheated, your SD card isnt fake) .. and, as a user with 300+ devices, 15 minutes for startup and query all but you could count on it. Honestly that is the amazing ISY brand rock - solid. Only thing I have ever seen better are some elevator control boards from the 90s running in their isolated environments. Now enter EISY - during a market time of a very useable Home Assistant community device - dropping prices of the extreme commercial systems (have you seen the Lutron Caseta system) or even drop in price of the RA2 pro stuff. Oh yeah then let's mention Alexa of the casual user requiring nearly no "hobby support time" / Insteon goes bankrupt with a nice community support pickup but long overdue. Again, I am outside here, with have a ton of respect for the Gang at UDI, all of whom I would give a large hug but their world they are operating in has changed a ton / ummm the world us users are asked to navigate which @Toddimus opening post had me think of. I bought a EISY with wellness to send the $400 just on principle to support UDI - but my efforts to test it out over the last year have been sadly challenging. First issue was after pulling power from it when moving it around my network cabinet - completely corrupted free BSD and EISY needed to be shipped into UDI - but noted that was only after Michel spent 3 hours on a Sunday night remotely connected to it attempting to fix .. dang! However that doesn't make up for the loss in reliability hit - when designing EISY (or in testing) was a requirement missed -users will yank power - device needs to live through random power outages... Curious where others land on this too. I get the ISY994 is outdated hardware wise .. sad but true - although some of your favorite elevators are probably running firmware from 1999 on them still today ..
  13. @Nitemare - indeed you are on path here trying to add slightly different lock (ZP which is on v.11 vs my older nonZP on v5.8). Main difference is that indeed EISY flow for you is S2 (secure) vs mine being older non secure S0. I did have easy success in adding a BE469ZP v11.0 from the admin consul - I did not try mobile. My EISY is in crowed (electrically noisy) rack about 20 feet from where I did the initial enrollment. However the settings change (compatibility mode and validation, parameter change) and all other testing of unit have been done with unit 60 feet from EISY. Noted my test was a "new" lock out of the box which had never successfully enrolled on my ISY. I note never successfully since I had tried but learned my ISY on 4.9 would not support ZP devices. I never migrated from v4.9 up to v5.x (which I recall was required to run ZP devices). Also note sure what version my Zwave board is on the my ISY v4.9, I know it was one of the 1st mass sale units but early on. Given your note that you were running BE469ZP on ISY I am guessing you were on V5.x Interesting what @Javi notes about doing a factory reset; that would not hurt but I would suggest ensuring to do a Zwave \ Remove a device - then on lock clicking enrollment button - just help clear prior association attempt. As for my own issues on BE469v5.8 move from working great on ISY994 v4.9 to over to EISY on v5.8 where it will not enroll - just tried new enrollment attempt with same failure after ensuring ISY994 was unplugged, doing remove/exclude, setting interview time to 2 mins and comm speed to 20 (all per suggestion of Mr Chris who is working my ticket) - he noted Zwave library Team to have a look after I had sent lower level diagnostic from SSH session. Part I am perplexed on is how well this lock works on ISY994 but fails on EISY.
  14. hi @Nitemare - are you 100% sure that our locks are BE469ZP and not BE469v5.8 ? Reason I ask is that your comment of only getting a single entry, no control for the lock on EISY but worked fine on ISY is the exact same I am running into with my BE469v5.8 Also I tested a BE469ZP unit and they add into EISY fine, it asked for ZP security code, adds multiple nodes as expected. After that does require additional steps after enrollment of turning on compatibility, turning off confirmation, and rewriting links (see several posts above). I can understand how people are likely confused on which version of the BE469 the might have (as the locks look identical on the outside of the units) AND most retailers just started selling the new version w/o much notice.. BE469v5.8 = S0 device, worked on ISY994 v4.9 older Zwave board, when attempting to add into the EISY the EISY does not ask for security code, removing battery cover of the lock there is NOT and enrollment button (instead Zwave enrollment is done by typing 8 digit code then 0 on the lock keypad BE469ZP (Zwave Plus)= S2 device, does NOT work on ISY994 running v4.9 (might work on V5.x not sure), when attempting to enroll on EISY will ask for Secure code (code is sticker on part of lock that mounts to door that holds outside keypad on -remove lock to see it), to enroll the lock there is a button under the battery cover. Please reply back to confirm which version you have. Also if you have other examples in forum of those stuck getting the single node you mentioned and can easily find pls reference here. thx cheers
  15. Sure .. agreed the newer Zwave Plus stuff has security. Those add to EISY with S2 while the non security devices add as S0. These BE469v5.8 are before z wave plus was a thing and add as non secure. The ISY994 v4.9 was indeed non secure non zwaveplus (on the 1st non beta board) .. and the BE469v5.8 are very happy there. Now onto EISY where S2 (secure) and zwave plus is the norm.. however it does claim support older non secure S0 enrollment or at least it tries to and has options to …but that is crux of the space I’m stuck in. Given roll out timing of EISY and when Schlage updated their own BE469 models from v5.8 to ZP (zwave plus) years ago .. I really suspect most users and testing probably skipped this use case (older be469v5.8 on EISY). Also most on forum posts on Schlage in EISY all focus on lack of status change alerts .. which again confirms those users were on BE469ZP - since we know fix for that (in post) At least the EISY is not asking for s2 code on the be469v5.8 and does start the interview, but then it fails to communicate properly with the lock and enrollment fails.
