adambuild
  • Posts
    38
Everything posted by adambuild
  1. Thanks so much to both of you.
  2. adambuild
    How do I.....
    I have two switches that make up a virtual 3-WAY scene for hi hats in a kitchen. There is an additional single switch that alone controls a center light fixture in the center of the kitchen. Is there a way to make that center fixture go on and off along with the other virtual 3-WAY scene? If so, what's the best way to do that? I tried making a new scene but when I drag the virtual 3-WAY scene into this new scene something doesn't look right. Any thoughts? Thank you in advance! Adam
  3. For some reason my ISY Launcher is no longer working I get the following error message two times in succession every time I click on the UD icon to launch the app: Any ideas???
  4. Just curious, I have a bunch of timed events that are set to fire at 12:00am. They seem to work OK. Is it better not to have them fire at the same time? Does it matter? Is there a downside? Thank you, Adam
  5. Hi All, anyone know how to add a ZOOZ ZEN51 zwave relay to the ISY994i?
  6. Hi all, I have an old ApplianceLinc that is now dead. Would love to repair it. Tore it down and have a bad Licon capacitor at C2 on the circuit board: 470mfd / 35v. Can anyone please give advice as to what it should be replaced with? Thanks very much, Adam
  7. Hey Mr. Bill, thanks so much. I'm gonna use your methods when I have a block of time to focus on this and will report back!
  8. Hey Mr. Bill, thanks much. So I tried restoring both again and got the results shown below. The boy's bedroom switch has those green/white lines and the foyer switch had no change. Nothing has been changed recently like bulbs, electronics, etc.
  9. Hi All, Happy and Healthy New Year to everyone! I am currently getting the error message below for two switches. I've done hard resets for both and have also done "restore device" for both. Any other ideas? Does this mean the switches need replacement? Can they be repaired? 2477D's are currently impossible to find, even eBay has none. Thanks in advance, Adam
  10. Not one listing
  11. Is there some secret source to buy new Insteon 2477D switches now? SMARTHOME is saying hopefully March or April!?
  12. Never mind, I actually figured it out!!! My sincere thanks again to all those that take of their precious time to help those who are trying to learn!!! It's beyond appreciated!!!
  13. Pardon my ignorance, is there a way to access the ISY994 dashboard remotely so that I can make programming changes? I have two of the them in two different houses and wanted to change a few things while I'm out. I know that I can access them via https://my.isy.io/index.htm but I wanted to access each of the dashboards. If indeed it's possible, kindly tell me how. Thank you!
  14. Thanks so much Techman, it worked! And by the way, all the switches are controlling just regular led bulbs. Any idea what would cause this?
  15. Hi all, long story short: Wanted to have a fast-on at a kitchen light switch turn two other kitchen switches on and a fast-off turn the same switches off as shown below. Couldn't get it to work. Went into the log and the log didn't even show the initial switch being manually controlled. Replaced the switch with a new one and same thing. Put the old one back in and for some reason clicked on "start linking", waited for it to finish, and the program started working!? A few days later did a fast-off and the local switch was only beeping and not controlling the light, on or off!? Did a hard reset of the switch and was able to control it locally but it would no longer control the other two switches. Went to the admin console and tried turning the switch on or off and would get an error message saying that it could not communicate with that switch, but when I clicked on query of said switch it would give me an accurate state of the switch!? Any ideas??? Thank you!
  16. Logged out and back in again and now received this error: Any thoughts?
  17. Does this mean anything?
  18. Ah MrBill, you know me all too well..... It worked! If only I could learn to read..... Thank you
  19. Thanks again! OK I'm definitely closer, now I'm getting the following, what am I missing? :
  20. Hey MrBill, hmmm, I thought I did that, let me check and see when I get back to my desk. Thank you!
  21. Hi all, another question: Now that I've been able to get both homes up and running with an ISY994i in each, thanks to all of your help, is there a way to use or program the ISY Finder to see both ISY994i's? It would be great to be able to make changes to the programming remotely. Below is the ISY994i from my primary home but it doesn't list my second home. Is that even possible? Must you be on the specific network to be able to gain access to the Admin Console? Thanks again, Adam
  22. Hey MrBill, I just want to thank you again for all of the time and help that you sent my way today. I appreciate it very much.
  23. Feeling stupid again. I clicked on Admin Console and then Configuration but then don't see Portals or Accept for that matter! What am I missing?
  24. I'm getting the following error when I try to connect to my ISY994i in my vacation home. What am I missing?
  • Create New...
