Everything posted by aeroRC
Possible EISY-UI Migration Issue?
Although I have a Powerwall 3 which does not support Local Access, the plug-in appeared to automatically fall back to Cloud Access even if the configuration for Local Access was set to True. However, after migrating to EISY-UI, the plug-in no longer appears to fall back to Cloud Access after rebooting. Now the configuration setting for Local Access must be set False for the plug-in to successfully connect to Cloud Access. Did the EISY-UI migration somehow affect the automatic fall back for unsupported Local Access? RC
IoX 6.1.1 let's discuss it!
After upgrading, the Synchronization with UD Mobile (iOS) produces these errors. However, all the Insteon nodes show up and appear to be fully functional. RC
In testing UD Mobile, the Synchronization finishes with Insteon errors " with "...could not match CMD paramName: ______". The paramNames that could not be matched were: VAL-NAME, MAX-NAME, MIN-NAME, START-NAME, BRT-NAME, RR-NAME, ON-NAME, and OFF-NAME. RC
Rob, deleting the apps from the java console fixed the problem. Thanks for the tip! I have not had any problems with seeing and editing my programs so far. RC
Upgraded to the new release with no apparent problems. Logged into the EISY-UI without any problem. All Insteon, Z-Wave, and Zigbee, and PG3 nodes appear to be working. Successfully edited and saved one program using the EISY-UI. Problem: Although clicking the Admin Console button downloads a new admin.jnlp file, I get an error that Admin Console v.6.0.4 is not compatible with IoX Firmware v6.1.1 RC
ZMATTER-LOG Terminating = frozen EISY
I’m running into this situation as well. Have you discovered a possible solution or explanation for this? RC
Sync error after upgrade
’m also having sync errors since upgrading to 6.0. These 2 errors occur during sync when “Getting family Nodeserver” (running UDM 1.3.4 on iOS). I have tried re-installing Notificaitons, but the errors remained. I then tried reinstalling all the plugins and rebooting the EISY without success. Any thoughts on what is the source of the errors?
after update to 6.0, UD mobile won't sync.
I’m also having sync errors since upgrading to 6.0. These 2 errors occur during sync when “Getting family Nodeserver” (running UDM 1.3.4 on iOS).
Failed to refresh oAuth token: 401 Client Error
Great, thanks!
Yes - the plug-in is online, but all nodes are offline until re-authenticated.
Device Nodes Missing After Updating to 1.4.21
Got it. Thanks!
I am still a novice with the PG3 plug-ins and have only installed from the Polyglot plug-ins page which only has 1.4.21 as the current release. How would I download and install release 1.4.22 instead?
Only one node (YoLinkSetup) now appears after updating the plug-in to 1.4.21 even after restarting the plug-in many times. Then tried rebooting the EISY and deleting/reinstalling the plug-in and reentering the hub credentials -- but got the same result. Am I missing something to get all the YoLink device nodes to reappear?
Alexa routines not working - Fix made
My Alexa routines triggered by a contact sensor variable stopped working yesterday. The Alexa routines work when played from the Alexa app. I have tried changing the contact sensor to a motion sensor and having Alexa re-discover it, but that did not fix the problem. Is there a workaround to this issue?
Zigbee - Device Support Requests
Please include support for Somfy Zigbee Shade Motors.
