roopesh
  1. 5.3.4, which I believe is the last version for the ISY. I also went into Event Viewer and see [FileOpen ] Open failed for [/LOG/ERRORA.LOG] (a) I'm really starting to assume the SD card, unfortunately.
  2. Thank you @Geddy! I am very comfortable with all things command prompt telnet/ssh etc :). However, I could not figure out what to do in that telnet session. I could see the file exists, but I can't view or do anything to the file. http://192.168.10.16>mn CD - Configure delay between requests CI - Configure IR CL - Configure max log size CP - Configure protocol timeout CR - Configure Max Retries CT - Configure TCP/IP CWP - Configure Webserver Ports CWT - Configure Webserver Timeouts DI - Disable internet DT - Disable telnet EI - Enable internet ET - Enable telnet JX - Show JSON file as XML LS - List files MN - Menu RS - Reboot SM - Show memory SPU - Set Portal URL ST - Show system time SU - Show external url VE - Display Version XS - Exit the shell I couldn't cat, more, or even rm any files as those commands don't exist. I couldn't even inspect the contents of the files using the only command that seem reasonably relevant, jx: http://192.168.10.16>jx /CONF/572686.REC http://192.168.10.16>JX /CONF/3EBFE2.REC I certainly can restore from a pretty recent backup, but I'm not sure that'll fix anything at this point. I don't know if it's worth it to try to troubleshoot config, SD card, PLM... The ISY did let me backup this week, too. Should I use that to restore or an older backup? Yeah, I bought a Polisy when they first came out and, sadly, it's been collecting dust. I did buy a couple USB sticks just in case my Serial PLM died and I had to switch to the Polisy.
  3. I've tried rebooting the computer (mulitple computers), clearing java cache, and rebooting the ISY. If it's the SD card, it might be time for me to migrate from my ISY994i to my PolISY. I haven't planned that migration; in fact I have actively avoided it. I hope it's painless.
  4. I have two issues that seem to have popped up. Disclaimer: I rarely login to my ISY to do anything. It usually just works fine. And, to be fair, it's still working for everything it's doing. Issue 1: As reported here by other users, I get a "Not Found" error when launching start.jnlp. I've cleared my java cache and redownloaded the start.jnlp from UD. Still get the error. Annoying, but probably fine... I thought it was related to issue 2, but it seems like (based on reading here) they're unrelated. Issues 2: When trying to add a device to a scene, I get a "Could not write config file" error. I've tried two different devices and get the same error. What's weird is that the device seems to get added (the process runs in the background - I think the button works as well, but I'm not in front of it right now) but the ISY doesn't seem to know about it. None of the devices in the scene have any issues i.e. i can go to each one and turn on/off the lights. Any idea why I'm getting this error?
  5. Thank you! I don't know which thing helped the most, but I did the following: re-ran the package updater pointed the polisy ISY settings to itself rebooted the polisy pro 2-3x Then everything started working. And @MrBill it'll be handy to know i can just run that at the terminal and even get output! Thanks all!
  6. I upgraded my Polisy Pro using these instructions but I still don't see ISY on Polisy. It doesn't show up in my launcher and when I try to add it manually (https://192.168.10.17:8443/desc) I get a "Not Found" error. How do I get IoP installed? Edit: solved.
  7. I just sold my home and left the ISY in the old home so all the existing devices would function properly. Can I transfer my Portal license to my new ISY I bought for the new home?
  8. In Safari preferences, General tab, unclick Open "safe" files.
  9. This is an old topic, I realize, but I'm seeing similar issues. I've tried all the troubleshooting steps I've found: unlinked my Universal Devices from Google Home, made sure I only have one Google Home account linked to Universal Devices, tried refreshing from the ISY portal (Send Spoken), and by issuing "sync devices" from the Google Assistant/Home apps. However, anything new I add to the Google Home in the ISY portal does not show up in the Google Home app nor does it recognize the scenes or devices. Oddly, I did delete a switch from Google Home in ISY and it did delete in the app. I don't remember having these issues with Alexa but I really want to switch to Google Home.
