beninsteon
  1. Hi @Jimbo.Automates I know it's depreciated, but thought I'd ask. I've been using my isy 994i for years without problems, including your pg2 ecobee plugin. Unfortunately the ecobee plugin has stopped working lately. It crashes about 10 minutes after startup. The first 10 minutes work perfectly. Here's the log. Anything I can do to fix this at my end? 2024-04-28 20:43:43,955 Controller polyinterface INFO Controller:_endRefresh: cleared lock 2024-04-28 20:43:44,084 Controller polyinterface INFO Controller:getThermostatSelection: Getting Thermostat Data for 411966560035 2024-04-28 20:46:41,463 Controller polyinterface INFO Controller:getThermostatSelection: Getting Thermostat Data for 411966560035 2024-04-28 20:49:41,460 Controller polyinterface INFO Controller:getThermostatSelection: Getting Thermostat Data for 411966560035 2024-04-28 20:52:41,465 Controller polyinterface INFO Controller:getThermostatSelection: Getting Thermostat Data for 411966560035 2024-04-28 20:52:41,634 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver t411966560035 - CLIHUM: 50, uom: 22 2024-04-28 20:52:41,636 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver s411966560035 - CLIHUM: 50, uom: 22 2024-04-28 20:55:41,472 Controller polyinterface INFO Controller:getThermostatSelection: Getting Thermostat Data for 411966560035 2024-04-28 20:55:41,639 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver t411966560035 - CLIHUM: 49, uom: 22 2024-04-28 20:55:41,641 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver t411966560035 - CLIFRS: 1, uom: 80 2024-04-28 20:55:41,663 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver s411966560035 - CLIHUM: 49, uom: 22 2024-04-28 20:58:41,484 Controller polyinterface INFO Controller:getThermostatSelection: Getting Thermostat Data for 411966560035 2024-04-28 21:01:41,502 Controller polyinterface INFO Controller:getThermostatSelection: Getting Thermostat Data for 411966560035 2024-04-28 21:01:41,668 Controller polyinterface INFO polyinterface:reportDriver: Updating Driver t411966560035 - CLIFRS: 0, uom: 80 2024-04-28 21:01:41,683 Controller polyinterface ERROR polyinterface:write: Exception in thread Controller: Traceback (most recent call last): File "/usr/lib/python3.7/threading.py", line 917, in _bootstrap_inner self.run() File "/usr/lib/python3.7/threading.py", line 865, in run self._target(*self._args, **self._kwargs) File "/home/pi/.local/lib/python3.7/site-packages/polyinterface/polyinterface.py", line 854, in _parseInput self.longPoll() File "/home/pi/.polyglot/nodeservers/Ecobee/nodes/Controller.py", line 159, in longPoll self.updateThermostats() File "/home/pi/.polyglot/nodeservers/Ecobee/nodes/Controller.py", line 502, in updateThermostats self.nodes[address].update(thermostat, fullData) File "/home/pi/.polyglot/nodeservers/Ecobee/nodes/Thermostat.py", line 168, in update self._update() File "/home/pi/.polyglot/nodeservers/Ecobee/nodes/Thermostat.py", line 278, in _update self.check_weather() File "/home/pi/.polyglot/nodeservers/Ecobee/nodes/Thermostat.py", line 113, in check_weather self.weather.update(self.tstat['weather']) File "/home/pi/.polyglot/nodeservers/Ecobee/nodes/Weather.py", line 50, in update 'GV6': windMap[currentWeather['windDirection']], KeyError: ''
  2. This won't work - monitoring the status of an Ecobee thermostat. All I can use is Status, and this triggers the IF.
  3. Thanks. Just to make sure I understand what you're suggesting, the disabled program will still run and conditions in the IF statement evaluated when called from another program (Run if), but since it's disabled ISY won't use those conditions as triggers?
  4. Hi, Can anyone suggest how to use the state of a device as a condition for program execution, rather than as a condition and trigger, which is the default IoX behaviour. I've managed this problem in the past by using integer variables to track device states, but this is overly complex. Wondering if there are other ways to achieve this. Thanks.
  5. The solution to the all on trouble is simple. Replace old switches/dimmers with newer versions that don't respond to the all on command. Most importantly don't use the iolinc relay for critical or security related actions (garage doors, fireplaces, etc). Use another relay the isy can control with network resources (eg global cache ip2cc).
  6. That's what I thought for the first 5 years or so before I had my first All On experience. Then it happened, and I learned 😃 B
  7. You should *never* use an I/O link for critical applications (like controlling your main water supply). They are subject to the "Insteon/ISY All On" bug and can be triggered without cause. I replaced all my I/O lincs relays with Global Cache Ethernet relays after I came home a few years ago and found my garage door open and gas fireplace had been turned on. I still use I/O lincs as Insteon sensors.
  8. I would recommend against anything that is cloud dependent/connected. Additionally, given the importance of what this is doing, zwave or even wifi are not ideal. I am using a hard wired motorized valve (eg. https://www.amazon.ca/Motorized-Stainless-Polarity-U-S-Solid/dp/B06XWG6ZLS) controlled via a Global Cache GC-100 (IP2CC would work also https://www.amazon.ca/Global-Caché-Ip2Cc-P-Contact-Closure/dp/B002ZV8FVI), connected to my network via Ethernet. Using programs/network resources in ISY to trigger valve closure when water detected where it shouldn't be.
  9. @bmercier I have the same problem. Has been an issue for many months, if not years. An update would be much appreciated. Here's a previous post I made about this issue without any resolution
  10. glad to hear nodelink is working with polisy. i presume this will be this same with eisy what about polyglot 2? i understand that i can't run polyglot 2 on eisy, but can i run it on a rpi and use its nodeservers on eisy?
  11. Hi, I'm thinking about making the jump from my ISY994i to an eisy. I have several nodes with Polyglot 2 and NodeLink (both servers running on a RPi3 for years without issue). I understand that I can't run Polyglot V2 or NodeLink on the eisy itself, but will these nodeservers continue to work with the eisy and my RPi3, like it has been with the ISY994? Thanks
  12. Has anyone successfully gotten home assistant running on eisy? If so, please share steps
  13. Great question and I look forward to the reply. I don't think docker is compatible with freebsd though.
  14. Just submitted a pull reqest to the PG2 NS on GitHub to allow direct access to high/med/low fan speeds through admin console and programs. Hopefully this can be merged for PG2 and updated in PG3 version as well. Thanks
