Admin Console asks me to login again
When ! leave the Admin Console running, I often come back to it after a few hours and it wants me to login again. Once I login again it looks like it restarts everything. Is this normal/expected?
Can't delete Email/Notifications Customizations
Support said that it was some sort of firewall issue and/or a bug with eisyui which is weird since I don't have a firewall and I don't use eisyui. I was given a workaround which was to add the following to the IoX Launcher: https://eisy.local:8443/desc and use that to start Admin Console. Then I was able to remove customizations. But I was told this is a temp solution and will be removed since they are working on a fix
I cleared the java cache and downloaded a fresh start.jnlp from https://isy.universal-devices.com/start.jnlp I'm pretty sure I am logged out of eisy-ui and PG3 sessions...I don't have any tabs open with either of them. I restarted Admin Console and tried deleting a customization again and it came back again even after rebooting. I tried using the customization I deleted in a test program and it worked. The version from the Help->About menu is 6.0.4 for UI and firmware. Is that the IoX version? I am running Windows 10 I've opened a support ticket
No that didn't work. Every time I reboot the deleted customization is back again. If I try and delete it again and save and immediately reboot, it comes right back again.
I recently migrated from ISY994i to Eisy and I was trying to clean up some old customizations that I no longer use. I used the Admin Console, went into Configuration->Emails/Notifications->Customizations I select one of the customizations, select Delete and it seems to go away. I also click Save. Then I switch to Settings/Groups and then back to Customizations and lo and behold the customization which I delete is back again. I made sure that the customization is not used by any program. Is there a "proper" way to delete customizations or is this a bug?
Verify I have an Eisy R2
I just purchased an Eisy R2 and I want to verify that is really what I got. Is there a way to tell from the Adminstrative Console?
leadfoot
Joined
Last visited
