arf1410
Everything posted by arf1410
  1. I have a powerline interface that I'm using with my ISY994i. can I use the same one with an EISY, or will I also need to purchase a new/ different one?
  2. More reading... it appears I may have to pay a $125 fee to "transfer" it to me if I buy a used ISY994ZW? on the other hand, I thought an advantage of ISY if it worked totally self contained... it didnt need to communicate with UD?
  3. Does the EISY really gain me anything over finding a cheap used z-wave dongle, or i994zw ?
  4. Got the ISY 994 , controlling Insteon and original smarthome X10 switches, but stray signals are occasionally causing strange things to happen with X10 controlled lights. Rather than replace the older X10 switches with Insteon, it seems like Zwave may be in my future. At a different location, I have a few Z-wave devices controlled by a Ring base station, and Alexa... but no X10 or Insteon at that location. If I go with an EISY, will I also need that $152 bridge, and my existing Smarthome powerline adapter? And when that 15 year old powerline adapter dies, then what? Is the EISY programming / software still similar to the ISY 994? In other words, 1970s?
  5. Was hoping to continue my previous post, but its been closed. As stated, I got the 3-way to work fine, via 4 short programs. Why would creating a scene be better? (which I dont really know how to do). Wouldnt insteon's method be better, without getting the ISY involved at all? one less thing to screw up?
  6. forgot to hit the "save" button. Wrote 4 short programs to keep the 2 switched in sync.
  7. Finally needing to replace a Smarthome X10 switch, and happens to be a 3-way, with a master and slave. Its unfortunate, as physically, those are the best switches I've had. So replaced the main switch with an Insteon, and capped the red traveler. works just fine to control Kitchen. I have removed the X10 "slave" switch, capped that traveler, and installed another Insteon there, attaching the white and black wires. lets call this switch Kitchen 3-way. ISY 994 recognizes both these switches fine, and I can use ISY to control Kitchen. Was going to write a program.. If kitchen 3-way is switched ON, control Kitchen to ON... and a similar one for off. But it doesnt work. What am I doing wrong? Edit: solved
  8. The QNAP power cycle schedule only allows for daily / weekly events, best I can gather. Wouldn't this really simple routine work fine with much less complexity than other proposed solutions? It could power on my QNAP for 24 hours each quarter, allowing time for backup. I prefer a copy of files, rather than the synology proprietary backup system. Its really simple to duplicate those dates, so I could easily add 4 or 8 more, to cover a few years.
  9. Was just about to delete my post, as I too found that box! So now will my general logic work OK? It really seems by far the simplest approach: I could say IF time is from 12 am to 11 59 pm on 3/15/23 or 6/15/23 or 9/15/23 etc, turn ON, else turn OFF.... and I would list 8-12 quarterly dates, to cover the next 2-3 years?
  10. I got that screenshot from YOUR post on 12/9/2020!
  11. Both Firmware, and UI are 5.3.4. updated java, cleared cache, and now the ACTION button appears, but no calendar. My thought would be. if that calendar appears, and functions like I want, I could say IF dae = 3/15/23 or 6/15/23 or 9/15/23 etc, turn ON, else turn OFF.... and I would list 8-12 quarterly dates, to cover the next 2-3 years?
  12. I think I successfully upgraded to firmware v 5.3.4 from the above linked post there should be a screen like below, however, I dont have that "Action" button, nor do I have the calendar/date function at the end of each line. what am I doing wrong?
  13. It appears my task may be easier to accomplish with Firmware 5.X, but I am still on firmware 4.9. Best I can gather, there is no clear, concise changelog available for the version differences? also, it appears there is no simple way to upgrade firmware, and I run the risk of having to start over with all my programs? ugh
  14. OP here. Appreciate the input. Let me add a bit more context. My ISY programming, and network management skills are much more basic than 98% of the folks here. Terms like "node server" don't have much meaning to me. here's more of the "Big Picture"... I was hit with a ransomwear attack last summer, where the bulk of the files on my old QNAP 2-disk NAS were encrypted, and I came close to loosing lots of important things, until I managed to find an old hard drive in a closet to bail myself out. Because these were files I dont access regularly, I didnt even notice the encryption until 3 months after the attack. Trying to avoid that again, so bought a new Synology as my primary NAS, and was going to attempt to automate its backup about once a month (or 2?), via windows task manager, and FreeFileSync, to the QNAP. For added security, that QNAP was going to be mostly powered off. It is in a mode such that when power is restored (after power outage, etc), it boots back up. So, using a basic insteon module, have the QNAP turned on for, say, 24 hours on the 15th of every month (or every other month?), then turned off. I would assume is the QNAP is powered off, it will be nearly impossible to hack into. I would schedule the backups to happen during that 24 hour window of being powered on. thanks.
  15. I can see how to use the ISY to execute a program on certain days of the week, but I want to know if I can use it to turn an insteon module on for say 24 hours, once a month, or even every other month.
  16. My system is X-10 & Insteon... thinking of adding the Z-wave dongle to my ISY. Can I replace the Insteon 6 button controller with this, and use the ISY to "translate" the zen32 signal, to control a insteon or X10 switch?
  17. Edit - noticed in the File section, there is an Enable Internet (ISY) selection... which I try... but it fails. the Console itself is communicating with the cloud, because it prompts me to install the update...
  18. Am attempting to use the 30 day free ISY portal trial... I am trying to install it after being prompted in the console ... but I keep getting TCP Client DNS error... what am I doing wrong?
  19. To enable my ISY to control Insteon or X-10, I need a functional PLM device (so far, so good, knock on wood)... but if I get the z-wave dongle... will the ISY control Z-wave without a PLM?
  20. Havent used my Insteon Hub in ~ 2 years... but I vaguely remember there were 2 ways to access it. One, via a web portal, that I guess went via insteon servers...but wasnt there a second way that was directly from my network, to the Hub?
  21. Have a mix of X-10 and Insteon switches... and likely a spare insteon switch or two. I had used an Insteon Hub, but replaced it with an ISY. Not really clear what the (now shut down) Insteon servers do? Why should I care? And is the only risk, to someone like me, is my PLM device - which typically has a short life span - can't be replaced? Note - I've got some unrelated home automation stuff, related to a wired home alarm system, and a repurposed Kindle Fire tablet used as a control panel... and as I was configuring it, based on internet instructions, this system requires 3 tiny companies, that few have heard of, to remain in business, for it to continue to be functional. In the likely event one goes belly up in the next few years, I'll have to start again with this project. Point being, any sort of home automation project that relies on just about any else's server, just seems like a bad idea. While I certainly dont expect Apple, or Amazon to go out of business, they could indeed shut down some product / service / division.
  22. I only have one wired router... but multiple "daisy chained" switches. I moved the ISY one switch closer, and now I've found it at the same IP address as always. Though, as I think about troubleshooting my network communication issues, it seems like neither the ethernet drop, nor AC outlet of the ISY should matter at all... but the AC outlet this PLM is plugged into is the issue... dealing with a network that about 50% remains X10... and am hesitant to invest more $$ into X10 or even insteon, as it appears now the future is Zwave.
  23. I was going to move my ISY to a different ethernet drop on the other side of the house, to attempt to address some signal issues. It appears by moving it, my ISY console can no longer find it. I dont want to have to do a factory reset or other major action. Can I assign it a static IP address? I thought I had done that years ago... maybe not. Is simply moving the ISY a major issue for a novice like myself?
  24. Should, for some reason, the UDI server be down, will the launch work to start the admin console? And if not, what is the "plan B" eluded to above?
  25. I've had my ISY for ~5 years, and mostly happy... apologies for this basic question. Is my system "stand alone" or does it require a Universal Devices server somewhere? I was thinking the Admn Console was software I installed... but maybe not?
