Dead, blink'in ISY-99i
Howdy all,
I noticed that all my lights were no longer coming on at dusk and found the ISY99i with the error led blinking. I tried to log-in and found I could communicate with the ISY, so following the lead from others with the same problem, I rebooted both my router and the ISY99i. Still nothing. I tried to start the console the multiple ways shown in the manual and still nothing. The ISY finder shows nothing. When i start the Admin Console I get two error messages. "XML Parse Error http://192.168.1.5:60143/0/d.xml" and on a separate Error message "Socket Open Failed java.net.ConnectException:Connection refused:no further information".
Okay, after "re-seating" the SD card (1Gb Mini in a full size SD adapter) I am able to log-on but I'm still getting error messages of "Could not create the zip file" and "Socket Open Failed java.net.socketTimeoutException"when trying to run a back-up.
OUT OF IDEAS. Please help.
phil
The ISY User Guide indicates a blinking Err LED indicates a possible problem with the ISY file system and/or SD card. The User Guide suggests powering down the ISY, and reseat the SD card. The SD card may have to be replaced.
Thanks Lee. I was just updating my post with that info. So I time to replace the SD card? Maybe I'll splurge and get a 2Gb.
