Network Resource error
I am having an issue with Network Resources. These all used to work fine. I get a TCP client resource moved error. This is true for all Network Resources that access a specific IP address. All other Network Resources work fine. I tested the TCP command locally on a mac and it works fine. Any ideas? ISY99i running 3.3.8.
ISYerror.tiff
It is an iMac that I do a lot of scripting on and is currently offering web services on the local LAN. I use the exact same Network resource to a Mac mini with the same setup and it is currently working fine. This just starting happening within the last two months. I haven't paid much attention to it and am now focusing on the issue at hand.
Michel,
In trying to figure out what is going on, I looked at comparing the server functions on my iMac vs. the Mac mini. I noticed that the iMac now redirects all http requests to https by default with a self signed certificate. This must have been updated with one of the many MacOSX updates. I was able to fix this by turning OFF SSL certificates on my home server (I'm comfortable with that). When using Safari directly, one gets prompted to accept a certificate. I guess with all of the hacking these days, things are becoming more secure. Thanks for pointing me in the right direction. Your prompt response is sincerely appreciated.
Joe
