Basic timer, not working
Hello again,
I have a program that isn't working as expected. I have an 8 button keypad in my bathroom; button A is connected to the keypad's relay, which turns my bathroom fan on & off. Button C (right under A), I want to use as a timer to turn A off. So here's the program:
  Control 'Bathroom KP : C' is switched On
  Set 'Bathroom KP : A' On
  Wait 15 minutes
  Set 'Bathroom KP : A' Off
  Set 'Bathroom KP : C' Off
 - No Actions -
Simple enough. The timer works, turns the fan on and shuts it off after 15 minutes, but button C doesn't turn back off when it's done. Any thoughts? I tried reversing the order of the last two items, setting C off first; A still turns off and C doesn't.
I tried the same program on a different keypad that's controlling another bathroom fan and had the same results, so I don't think there's a problem with the keypad itself.
Thank you for your help!
Secondary KPL buttons cannot be controlled with Direct commands. Assign button C as a Responder in an ISY Scene. Turn the Scene Off.
