Elk Output Naming
gatchel
I searched Elk output name before posting this so hopefully it wasn't already suggested...
In Elk programming you are only allowed to name or rename the first 64 outputs. It would be nice if in the output list that the ISY-994i shows, you could rename the output's above 64 for tracking purposes. Even if there were another column other than ID, Name, Status, maybe notes or something similar.
Sometimes in Elk programming you have to use a "phantom" output (101, 201, 202, etc) to make things happen. This would be a nice way to keep things organized between the programming of the two systems.
It would also be another way that the ISY-994i could make up for the shortcomings of other systems with a seemingly simple (not a programmer here) column add to an existing table or DB.
Just a thought!
      37.4k
      374.5k
