MorningLinc after PLM replace and restore
I just completed PLM replace and the only device refusing to be updated is a morninglinc v.3A. When it refused to restore initally and after several attempts to write update, I did factory reset on MorningLinc (held set button 10 seconds while and after plugging in) and then selected Restore Device. May have made things worse since in thinking about it I'm guessing the original PLM link replacement "commands" are still in queue to be written. What should I do now?
ISY 994i IR/Pro
3.3.10
Following is level 3 event log of attempting to select "Write Updates"
Thu 03/14/2013 07:04:12 PM : [iNST-TX-I1 ] 02 62 16 AB EA 0F 0D 00
Thu 03/14/2013 07:04:12 PM : [iNST-ACK ] 02 62 16.AB.EA 0F 0D 00 06 (00)
Thu 03/14/2013 07:04:13 PM : [iNST-SRX ] 02 50 16.AB.EA 21.31.C0 2B 0D FF (FF)
Thu 03/14/2013 07:04:13 PM : [std-Direct Ack] 16.AB.EA-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Thu 03/14/2013 07:04:13 PM : [iNST-TX-I2CS] 02 62 16 AB EA 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6
Thu 03/14/2013 07:04:13 PM : [iNST-ACK ] 02 62 16.AB.EA 1F 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 F6 06 LNK-ON (01)
Thu 03/14/2013 07:04:13 PM : [iNST-SRX ] 02 50 16.AB.EA 21.31.C0 27 09 FF LNK-ON (FF)
Thu 03/14/2013 07:04:13 PM : [std-Direct Ack] 16.AB.EA-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Thu 03/14/2013 07:04:14 PM : [LNK-BGN ] 02 64 01 00 06
Thu 03/14/2013 07:04:18 PM : [LNK-END ] 02 65 06 : : Unexpected, ignored (65)
I also just replaced my PLM, and had a hiccup with my Morninglinc. Please recall that the Morninglinc has special security (since it controls entry to your home.) You must link the device MANUALLY by pressing the set button on the device. I successfully re-established the link by selecting "Start Linking" under "Link Management" with the option to "...keep existing links." then pressing and holding the button on the Morninglinc box for 5 seconds. It gave a message that the device was already there; but afterwards it was working fine. Hope this helps!
medicmjc, it worked like a charm! The ISY product, support, customer service, ongoing updates, and UD in general are the very best. User community is very knowledgable and always ready with quick help -- doesn't get any better.
