ISY dashboard - Power Management settings?
KenN
Soooo ... playing around tonight, and I discovered that if I click on the little tool symbol to the top right of a device pane on the dashboard, then select the "Device Properties", a window opens up with the normal slider bars for setting device up (brightness, ramp rate). But there's also a whole subsection called "Power Management" with settings for device type, device load in watts and duty cycle.
I entered known loads for a couple of lights and saved, the system retains the info, but ... how can I use this? It doesn't seem to tie into anything that I can use through the ISY admin console, eg. in a program or through the power management interface. This seems to have fantastic possibilities, as I'm focusing a lot on reducing energy consumption.
Is this something I can use to trigger load shedding or is it a work in progress?
      37.6k
      376.4k
