Missing button from 8 button keypad, backup issue on file
So I have two issues.. for the first, I updated to the newest stable version 3.31? going into the admin console, I see my 8 button keypad is missing a button, and that button has dropped from the scenes it was in (was used for the garage door). I decided to try to update to the 4.03 beta, and it's still missing.. any ideas?
Also, during this upgrading I tried to do a backup. It always fails with file /conf/2 (I think it's supposed to be /conf/2.und?). I read on another post for different file to telnet in and run rf command on this file, but it errors out as well. Ideas?
I've only upgraded this new isy twice and never gotten into the file system. Don't remember seeing this error before. It was restored from a 99i (to 994i). Any backup I may have that may contain this would be very old, if I could find it, and several versions ago.. Any other options? Suggestions?
Yeah tried that and didn't see it. Will re-adding it replace that file? I see the file there with ls command and says -1 next to it (if that means anything).
2.und does not exist but just 2 does. Is there a command to rename this file?
Done. Keep in mind it errors with "cannot retrieve file /conf/2" and "cannot create zip". It does however create a .zip which I sent
