Socket Error...
I keep getting, "Socket Open Failed Java.net.SocketTimeoutException" error. I'm running 4.0.3 and Java 7 version 21.
How can I fix this?
Hi jmed999,
If you are on WiFi, it's quite possible that you are losing network connectivity.
If not, it's quite possible that ISY is really busy and is not responding to your requests. This might happen if you are doing massive INSTEON things (such as restore, on/off) and at the same time trying to communicate with INSTEON devices via Admin Console.
What do you see in the Error Log and the Log?
I'm on wifi but this is very unusual. My wifi signal is very strong.
My error log and my log are both over 4MB as txt files. How can I get those to you?
