Notify not working
TimWing
My text & email notifications stopped working a couple weeks ago. I have gone to Configuration-->Emails/Notifications and tested, all notifications work fine when tested but not when used in a program. I created a new program with text & email notification, I tested the program and get nothing.
Any suggestions?
Tim
I had the same issue with my rules that ran the notification inside the then section. Even manually executing the then did not send a notification. I "updated" the notification run in that command to exactly what it already was, then saved all programs and it started working again.
I just recently added notifications and updated to the latest 4.0.5 release, but I can't remember what order they were done, but it could have been an issue with updating.
- Jim
  iostream212 said:
Not enough info to review as we need to rule out that the program is not being triggered. Can you post your code?
       Control 'Office / Office 1st Floor' is switched On
       Send Notification to 'Tim - Text' content 'Garage Door Open'
I am running v.4.0.5
I had the same issue, and due to another post, took a look at my error log and found my dns was tossing errors to the ISY a LOT. Changed the dns from my router to google at 8.8.8.8 and the notifications came through again.
Alan
But if there was a problem with my dns then why does notifications work just fine when tested from "Settings/Groups" tab but not from my programs?
  Michel Kohanim said:
Hi Tim,
Please note that if either the subject or body is empty then notification will not be sent.
Well what do ya know....Self inflicted! :roll: I had no text in the body of the message.
Thank you Michel!
