default SSL cert
When I connect to my ISY(s), I get the warning that says: ISY is currently configured with the default SSL certificate: This is a security risk.
When I click no Request/Manage SSL Certificates nothing happens. This is also true when I select Help => Request/Manage SSL Certs from the app.
I was running is a certificate installed from quite a while back but perhaps this got removed when I upgraded my isy from a 99 to a 994? Not sure what I need to do to remedy this....
Tom
ps: this is with 4.0.5
Do you not have to be connected locally to work with certificates? Thought that was done for security reasons to prevent someone from the outside affecting certificates.
This problem happens if I am connected remotely or locally.
Tom
The problem being that certificate management cannot be accessed when connected locally?
Have you tried Help | Request/Manage SSL certificates?
Yes, it happens from the Help menu as well. I click but nothing happens.
Tom
Hi Tom,
On 994, the link should take you to:
http://www.universal-devices.com/docs/I ... 0Guide.pdf
Basically, what you need to do:
1. Read and familiarize yourself with the concepts
2. Follow the instructions on page 9 section d to create a self signed certificate
Michel,
I understand the concepts, I have a cert. How do I install it on the ISY, since I get no response to the menu item?
Tom
Hi Tom,
What type of certificate do you have? If you want to import an existing certificate, it has to be in PKCS12 format (.pfx). Otherwise, you will have to go through the whole process of sending a request to CA, and then receiving the certificate.
Hmm, I don't know what the format is. It came from my ISY99 and has no extension. I guess I will just create a new ss cert.
Tom
