Insteon Wireless Thermostat
I want to use the Insteon Wireless Thermostat purely as a humidity controller for a dehumidifier. Can I read the humidity and change the settings
if it is linked to the ISY?
Settings can be changed from the ISY only if it is on an external power supply. Otherwise it sleeps to conserve battery power. I have an older 2441ZTH which Humidity readings jump around, changing by a few % often. May not be an issue with later 2441ZTH firmware.
