Garage door control with KPL and Mobilinc
Hi Xathros,
Due to the quantity and length of these programs, can you suggest the best method of posting?  I somethines use the "Copy to Clipboard" or just the "Export"  function.
dave
Copy to clipboard is the way to go.  Paste them into code blocks using "<>" on the toolbar.
Xathros
Code as follows:
One other note. I have the keypadlinc button setup as a controller and responder for a scene "GaragedoorMain"
The iolinc is set as "Momentary B" with "LED on TX" checked. No other options checked. I have a momentary hold time of 0.2 seconds which seems to work OK.
Main Garage Door - [ID 0046][Parent 0024]
Folder Conditions for 'Main Garage Door'
000 ButtonOff - [ID 002E][Parent 0046]
$i.GDM_Dontwatch is 0
And Status 'A Mud Room Entry Keypad / B OpenClose Garage Door (GDM)' is Off
$i.GDM_Requestedstatus = 0
$s.GDM = 1
Function:
When the button state is changed, remember if it was changed
to on or off and start up the state machine.
Details:
All the '000' programs monitor the status of the KPL that is tied
to the GDM Scene. We only have to monitor one of them, since when the
scene is changed by any of KPL or Mobilinc it will affect all of them.
The main state variable for all GDM programs is s.GDM, which tells
us where in this state machine we are. We do not monitor that
state variable in the 000 programs because other programs within
this state machine will toggle the scene on and off, which in turn
changes the button state, so while the state machine is running we
ignore running the 000 programs using the i.GDM_DontWatch integer variable.
The i.GDM_RequestedStatus stores if the request was to close (0) or
open (1).
from :http://forum.universal-devices.com/topic/11099-garage-door-control-with-kpl-and-mobilinc/page-3#entry152166
000 ButtonOn - [ID 002D][Parent 0046]
And Status 'A Mud Room Entry Keypad / B OpenClose Garage Door (GDM)' is not Off
$i.GDM_Requestedstatus = 1
$s.GDM = 1
See '000 ButtonOff' for a description.
001 DoorStateFalse - [ID 002F][Parent 0046]
$s.GDM is 1
And (
$i.GDM_Requestedstatus is 0
And Status 'Garage Main Door IOLINC-Senso' is On
Or (
$i.GDM_Requestedstatus is 1
And Status 'Garage Main Door IOLINC-Senso' is Off
$s.GDM += 1
Function:
We have just entered the state machine from a KPL button changing
state. If the requested door status does not match the door sensor
status then go to the next state.
Info:
It seems that we could tie the check of the sensor status into
the 000 Button* states, but that does not work correctly because
it would trigger the 000 state when the sensor status changes
but the button status has not changed yet. This is because I
have the sensor as a controller for the GD scene because I want to
see the sensor as part of the scene in Mobilinc.
001 DoorStateTrue - [ID 0030][Parent 0046]
$s.GDM is 1
And (
Or (
$s.GDM = 10
Function:
state. If the requested door status matches the door sensor status
then we are done.
Info:
See DoorStateFalse for info.
002 Init - [ID 0031][Parent 0046]
$s.GDM is 2
$i.GDM_Dontwatch = 1
$s.GDM_Counter = 10
$s.GDM += 1
Function:
The door was requested to move, so initialize variables used in
the state machine and go to the next state.
i.GDM_DontWatch: 1=Don't watch the state changes of the KPL's
s.GDM_Counter: Loop counter for '002 Loop' program
s.GDM: Main state variable, go to state 2
002 Trigger - [ID 0032][Parent 0046]
$s.GDM is 2
Set 'Garage Main Door IOLINC-Relay' On
Function:
The door was requested to move, so trigger it.
Note:
This could have been done in the Init program, but that delays
the flashing of the scene for longer than I like...
The IOLinc relay is in Momentary B mode so it is triggered
by both on and off. I think this is important since I don't
turn it off, although I could, but I don't care what state
the relay is in.
003 DoorStatusClosed - [ID 0033][Parent 0046]
$s.GDM is 3
And $i.GDM_Requestedstatus is 0
Set Scene 'GarageDoorMain' Off
$s.GDM = 10
Function:
While in the state and the door was requested to close, when
the door is closed we are done. Make sure the scene is
off and go to the cleanup state.
Note: Logic "And Status" inverted due to my switch location
003 DoorStatusOpen - [ID 0034][Parent 0046]
$s.GDM is 3
And $i.GDM_Requestedstatus is 1
Set Scene 'GarageDoorMain' On
$s.GDM = 10
Enable Program 'Garage Lights SubRoutine'
See DoorStatusClosed for a description.
003 Loop - [ID 0035][Parent 0046]
$s.GDM is 3
And $s.GDM_Counter > 0
Wait 1 second
Wait 1 second
$s.GDM_Counter -= 1
Function:
Toggle the scene on and off so the KPL buttons and Mobilinc icon change
state. This gives visual feedback that we are waiting for the door.
Decrement the counter s.GDM_Counter each time, which tracks our timeout
function, and causes this program to restart until the counter reaches
zero.
We could have made the counter be the s.GDM... Oh well...
(I wish the 'Wait' could use a variable!)
003 Timeout - [ID 0036][Parent 0046]
$s.GDM_Counter is 0
And $s.GDM is 3
$s.GDM += 1
Function:
If the s.GDM_Counter has reached zero while we are in the
waiting state, then the door did not reach the state that
was requested! So go into state 3 which handles the failures.
(I had a reason for not handling them in this state, but can't
remember why...)
004 FailedClose - [ID 0037][Parent 0046]
$s.GDM is 4
Send Notification to 'Daves MMS Text' content 'Garage Door Failed to Close'
$s.GDM = 10
Function:
There was a request to close the door, but we timed out waiting.
Make sure the scene is on since this state machine toggles the
scene we are not sure where it ended up. Send a notification to
tell us that there was a problem! Go to state 10 which does
the cleanup.
Note:
I wonder if there could be a race condition... If the door sensor
status happens to change after TimeOut and before this is triggered?
But I really don't think that will happen...
004 FailedOpen - [ID 0038][Parent 0046]
$s.GDM is 4
Send Notification to 'Daves MMS Text' content 'Garage Door Failed to Open'
$s.GDM = 10
See FailedClose for a description.
005 GaragedoorPowerOutage - [ID 003A][Parent 0046]
$i.GDM_Dontwatch is -1
And (
Or Status 'A Mud Room Entry Keypad / B OpenClose Garage Door (GDM)' is 100%
$s.GDM = 10
010 GarageDoorDone - [ID 0039][Parent 0046]
$s.GDM is 10
$i.GDM_Dontwatch = 0
$s.GDM = 0
$i.GDM_Dontwatch Init To -1
State machine is all done so start watching again.
Edited by BCreekDave
Yikes!  This is gonna take me some time to digest and work out whats happening.
Seems overly complex to me.
All that should be needed is:
KPL Button as a controller of a scene with IOLinc relay as responder.  Relay in momentary B mode with 2 second delay.  KPL Button in NonToggle-On mode.
A scene "GarageStatusLED" with the KPL Button as responder.
And a program like:
    Status 'IOLinc_Sensor' is On
   Set Scene 'GarageStatusLED' Off
   Set Scene 'GarageStatusLED' On
And, if you moved the switch to the other end of the door travel, you wouldn't even need the program!  You could just make the IOLinc Sensor a controller of the GarageStatusLED scene.
-Xathros
Edited by Xathros
Yes, it is a long program.
I think there is a lot of error checking with state and integer variables to verify that the door achieved the desired result and if it didn't, to be able to notify the user.  There are sub-programs for power outage etc.  I tend to like this for something like and entry door where security and safety is an issue.  This along with a well placed camera.
So, is 'GarageDoorMain​' the scene that includes the balky keypad button?  I agree with xathros that this sure seems overly complex for the stated requirement.
Since the particular scene is driven based on multiple criteria, it seems to me that it is nearly futile to try to solve this by a continuous bac,-and-forth series of questions.  I can only suggest that it is a bit of forensic analysis should yield the answers you seek.  If the KPL button is in a state that you believe to be incorrect, review the program that you expected to maintain the correct state and check the variables that make up the various conditions.  Find the one that is causing the program to run false and trace the cause of that variable being other than what you expect.  If all looks well on this front, consider the possibility that the ISY program is running as designed, but the commands are not getting to the keypad.  Have you manually triggered any of these program (THEN path) to confirm that the commands are getting through?
Are the "i" and "s" an indication of integer or state variable?
I notice that when some program execute (THEN path), they change variable value for $s.gdm.  Changing this value would subsequently trigger other programs.   I also notice a particular value (3) of this variable has the potential to simultaneously trigger multiple programs and some of those programs have WAIT statements.  Is it possible that these wait statements are being interrupted by the changing variable value and not running to completion?  Could this be a problem?
I agree that trying to trace through the code is tedious and perhaps not the best plan of attack.  Unless the author (Jimbo) or someone else has slayed this exact dragon in the past.
It may very well be a timing issue.  I am going to work on my setup to match the switch function to switch closed when the door is closed.  This is the way that the program was originally intended, and may be more intrinsically safe.
The "i" and "s" are in fact indicators of integer and state variable.
I have confirmed that the commands are getting through.  I can see the state and integer variables change, but it is hard to tell if they are changing at the right time.
I am also going to disable the lights.  While I can unhook the door, my neighbors must think I am nuts with the lights going on and off all the time while I debug.
I will work on it on Saturday.  Too many other projects going on before the weather turns.
Thanks everyone for the suggestions.  I am using this as always as a learning experience.
By the way oberkc, hello from Beavercreek.  I live close to 675.  If you are driving by, look for the garage lights flashing!
I will be watching for the light show as I travel to he Greene Town Center tonight.
I want to post a follow up on this.
Thinking the issue was my particular implementation with the door sense switch monitoring the door open rather than the typical door close position, I moved the switch to sense the door close, which also I think is intrinsically safer, given the limitation of the single input on the iolinc.
This did not result in the desired solution.  While the system worked triggering from Mobilinc or from the keypadlinc or directly from the PC via the isy admin console, triggering the door from the manual push button or the in-car button was not reflected in a status change on the keypadlinc button.
Further investigation showed that when I replaced the caps in the 2413s, the link tables became corrupted and several devices had to be rebuilt.  One of these was the keypadlinc.  Looking at the button function for the garage door showed it to be missing as a responder for the scene for the garage door, in my install this scene is Garagedoormain.  Once I rebuilt this link, than everything is back to working OK.
Thanks for the help from oberkc and Xathros.
Excellent!  I'm sure you will be happier with the switch as you have it now.  Glad you got everything working.  Thanks for posting back.
-Xathros
I have my overhead garage lights added as a participant in the scene that is triggered by the door sensor is activated when the door goes up. No coding was needed. If the door is up, the lights are on, and vice versa.
The GDO's  lights stay on for a few minutes.
