Programming with ELK integration - Not working
Hi,
I just purchased the ELK/ISY integration module and am trying to get a simple program to work. When I open the door to the garage and it is dark outside, I want the garage lights to turn on for 5 minutes and then turn off. The program is below. The problem is the lights don't turn off.
Any suggestions on what I am doing wrong?
Elk Zone 'Garage Door' is Violated
AND From sunset - 1 hour
To sunrise + 1 hour (next day)
Set 'Inside Garage Lights' Fast On
Wait 5 minutes
Set 'Inside Garage Lights' Fast Off
- No Actions
John
The problem is that EVERY time the door sensor changes from closed-to-open OR open-to-closed, the IF statement re-evaluates.
When you open the door, everything works as expected; the light turns on.
However, when you CLOSE the door, the IF re-evaluates to FALSE, interrupting the wait statement (and therefore never getting to the OFF command).
The best course of action is to make a second program that contains your current THEN commands - with NO IF statement.
Replace the currenT program's THEN clause with an "execute second program THEN".
You will then get the desired behavior.
Sent from my iPad using Tapatalk HD
