Programming with ELK integration - Not working
Grayson
Hi,
I just purchased the ELK/ISY integration module and am trying to get a simple program to work. When I open the door to the garage and it is dark outside, I want the garage lights to turn on for 5 minutes and then turn off. The program is below. The problem is the lights don't turn off.
Any suggestions on what I am doing wrong?
Elk Zone 'Garage Door' is Violated
AND From sunset - 1 hour
To sunrise + 1 hour (next day)
Set 'Inside Garage Lights' Fast On
Wait 5 minutes
Set 'Inside Garage Lights' Fast Off
- No Actions
John
The problem is that EVERY time the door sensor changes from closed-to-open OR open-to-closed, the IF statement re-evaluates.
When you open the door, everything works as expected; the light turns on.
However, when you CLOSE the door, the IF re-evaluates to FALSE, interrupting the wait statement (and therefore never getting to the OFF command).
The best course of action is to make a second program that contains your current THEN commands - with NO IF statement.
Replace the currenT program's THEN clause with an "execute second program THEN".
You will then get the desired behavior.
Sent from my iPad using Tapatalk HD
      377k
