trouble w/ Switchlinc dimmmer & isy99i
Installed my first Switchlinc Dimmer, and linked it. I can turn the lights on and off but I want to ramp it to a set level. I tried adding the dimmer to a scene. When I test the scene it fails. I have tried with the switch as a responder and as a controller. If I select the switch from in the scene I can control it, but if I click on the scene itself and hit on/off I get nothing. I tried adding "adjust scene" to a program and set to 50% on, then ran the "if" statement but no go.
Any help on how to get a program to ramp up to say 50% would be great.
Dave
This is a duplicate post. User was running 3.2.6 on a 99i trying to process an I2CS device. He loaded 3.3.10 on the ISY but has not gotten the UI to 3.3.10 yet. Once that is accomplished I asked him to delete the device and add it back under 3.3.10.
